collinb Posted June 14, 2017 Report Posted June 14, 2017 A local camera store has asked me about building 2 or 3 display cases. Width is about 4' t 6', but only about 8" deep. The back will have pegs so that he can mount them where & when he wishes to suit the equipment currently in stock. (I would do something else, but it's what he wants.) The top will have a header that looks like a strip of 35mm film. These pics are of my mockup/prototype to win the job. He loved it. In production I'll probably use maple pegs and a maple veneer plywood. What I'm lacking for my cost estimating are two things 1) a source for sliding glass doors/hardware. 2) a source for long pegs (of various styles), about 6", in order to hold some of the larger lenses and bodies out there. I've found lots of vendors of 4" pegs but nothing much longer. Thoughts? Quote
RichardA Posted June 14, 2017 Report Posted June 14, 2017 A little bump, and camera gear all over the place. 2 Quote
collinb Posted June 14, 2017 Author Report Posted June 14, 2017 23 minutes ago, RichardA said: A little bump, and camera gear all over the place. That's why the case gets a glass front. Quote
drzaius Posted June 14, 2017 Report Posted June 14, 2017 Even so, it wouldn't be a stretch for an employee to bump something while reaching in there. Gotta be a better way. What about some small shelves secured to the pegs? 2 Quote
Eric. Posted June 14, 2017 Report Posted June 14, 2017 How about simple glass shelves? Keeps the interior of the case well lit and all the contents in visible display. I agree the pegs are a perilous situation and ill-suited for this purpose...especially considering the value of the contents. It's the craftsman's job to educate a customer about why their idea is a bad one. Quote
collinb Posted June 14, 2017 Author Report Posted June 14, 2017 1 hour ago, drzaius said: Even so, it wouldn't be a stretch for an employee to bump something while reaching in there. Gotta be a better way. What about some small shelves secured to the pegs? I like that. He might, too. If I make them in such a way that the shelf can rest on the pegs ... maybe with a cove cut into them ... More time ... alas Quote
collinb Posted June 14, 2017 Author Report Posted June 14, 2017 1 hour ago, Eric. said: How about simple glass shelves? Keeps the interior of the case well lit and all the contents in visible display. I agree the pegs are a perilous situation and ill-suited for this purpose...especially considering the value of the contents. It's the craftsman's job to educate a customer about why their idea is a bad one. Agreed on the education part. With about 30 yrs in IT I've gotten used to acting more as a consultant than just a developer. My first suggestion to him was a wood shelf that is embedded into the back, but tipped up just slightly (just 2-3 degrees) for product safety. He understood why I used the pegs that I did because they cradled the bodies and lenses that we put on it. He wants something unique. My one concern about the peg approach is the short life of the unit. Just move them around a dozen times and the holes will start becoming enlarged. That's not good for either the unit or the product. I'm going to steer him another direction. I'm thinking of adding LED strip lighting along the side edges where things could get dim. What I might to is make another prototype with some dowel-edged boards that are spaced to match exactly the holes on the back piece. That might persuade him, especially since they would be both strong and versatile. Still has the potential wear problem, but there are ways around that since they'd be hidden behind the shelf edge. Got more designing to do ... ... and I'm NOT about to turn my own pegs. Quote
wtnhighlander Posted June 14, 2017 Report Posted June 14, 2017 No one has dowel stock in the size you need for pegs? Alternatively, what about a french cleat wall for the back, with cleated cradles for various types of gear? Quote
Janello Posted June 15, 2017 Report Posted June 15, 2017 Sorry, I couldn't resist. On a serious note...I am looking forward to see the finished product. I really like the glass idea on pegs. 2 Quote
collinb Posted June 16, 2017 Author Report Posted June 16, 2017 After some thought about the wood pegs I'm going to try to steer him away from them. The main reason is wear. After a few inserts & removals the holes will change size. Unless I put in a bushing of some sort it's going to be difficult for them to maintain position after not too many changes. And I've found insertion-removal too difficult to do without a lot of effort (pounding & pushing) -- not a situation that one wants a 400/2.8 to suffer through. If he decides that the still wants them, I'm going to build the case so that the back board is easily removed and a new solution can be inserted without having to replace the whole cabinet. This modularity will be a selling point. The business need is to be able to adapt to varying piece sizes and display layouts with minimal effort. He really likes the wood pegs. I'll do it if he demands it but I'll make it so that, for modest cost, he may change his mind later and get something different/better. I'm leaning toward a threaded stud solution with a wood shelf that slides over them & a small block on the back edge to limit torque from weight as it extends out (I want to maintain the shape over years of use). Some of the lenses to be displayed (like a 400/2.8) are quite heavy. Though I did a test with a cleat variation the other night ( @wtnhighlander -- we are thinking alike). If I give it a 1 degree bevel the shelf sits securely and may be easily moved/removed. @Janello -- what's that box above the camera? Quote
RichardA Posted June 16, 2017 Report Posted June 16, 2017 You're making it more complicated than necessary... KISS is the way to go. Keep it simple s.....d. Go for The simplest solution. 1 Quote
collinb Posted June 19, 2017 Author Report Posted June 19, 2017 On 6/16/2017 at 10:58 AM, RichardA said: You're making it more complicated than necessary... KISS is the way to go. Keep it simple s.....d. Go for The simplest solution. You are right, after all. Talked to the client today. Will know in a week if I get the job. He appreciated the information that removing/inserting dowels too many times would weaken the holes. He also likes the french cleat idea but with permanent dowel pegs on it instead of a shelf. Versatile and clean looking. Comes with the added benefit of no open holes. Quote
