SawDustB Posted July 31, 2017 Author Report Posted July 31, 2017 This is good stuff, SawdustB. Good call on the Batman t's. Thanks Iceman - not exactly fine woodworking, but with a three year old for a client she loves everything. I can't take credit for the shirts, they were her idea (although I bought them). We also have a full set of super shirts, and she and I have Ghostbusters and a couple others. She likes us to match. 1 Quote
SawDustB Posted July 31, 2017 Author Report Posted July 31, 2017 We have 4 legs attached. It stands: And it folds up to slide away under my workbench: I'm still going to add the stretchers, but I think I'll cut them in by hand given how uneven some of the leg pieces are. I'm now thinking I'll keep it simple for keeping it open, and it may just be a stick that drops onto the stretchers. It'll make more sense to see it. This prompted much squealing from my daughter, who kept telling me it was done. I convinced her it at least needs finish, although she told me I'm not allowed to use the oil/varnish finish that's on my workbench because it's too slow. 2 Quote
wtnhighlander Posted July 31, 2017 Report Posted July 31, 2017 Shellac time! I think you have the right idea, just make a notched board to drop over the short end stretchers. Could even do 2 notched boards an some ply to make a lower shelf. Quote
SawDustB Posted August 5, 2017 Author Report Posted August 5, 2017 I had a bit of shop time last night, so I drilled the mortises for the stretchers and cut the tenons by hand. I figured I'd get some sawing practice before I think about trying dovetails. One is completely fitted, but the other needs a little more rounding over on the tenon to fit properly. I think we may try giving my daughter the little palm sander today and we'll see what happens . 1 Quote
Popular Post SawDustB Posted August 5, 2017 Author Popular Post Report Posted August 5, 2017 All of the mortise and tenon joints are fitted, but I decided to do a bit more surface prep before gluing them. My daughter decided she wanted to try sanding. I put some 220 on my detail sander and let her go to town. She lasted about 10 minutes before she decided she was just done, and I should use the random orbit on it. Her little sister also wanted to help. I smooth planed the legs and stretchers, so they're now ready to glue. I think we'll be pegging the joints, not for structural reasons but because she wants it to look more like my bench. There may be some wild rainbow painting that will occur on the legs, after assembly... I don't seem to remember that on my roubo. 5 Quote
Chet Posted August 5, 2017 Report Posted August 5, 2017 The bench is coming out Great! And that is a couple of real cute workers there. Teach them early. 1 Quote
Popular Post SawDustB Posted August 6, 2017 Author Popular Post Report Posted August 6, 2017 Glue up time! If I was doing the project again, I would have glued these up and squared them before I attached the brackets to the top. We're a tiny bit out of alignment, but it's ok. I had help with gluing: And we installed the legs to keep them in alignment while the glue dried. She learned to use a socket wrench this week too. Everything's now glued up and in place. Once it dries, I'm going to keep rounding edges and prepping the surface. 4 Quote
SawDustB Posted August 11, 2017 Author Report Posted August 11, 2017 So I thought we were almost done, but someone wanted pegs so it looked more like my bench. I made pegs from some scrap walnut, and pegged the leg brackets along with the stretchers. I've also made the solution to holding the legs open. I notched the cross piece and have it sitting down on the stretcher. Even with it just sitting there, everything feels very secure. I've chamfered all of the edges, and adjusted the leg lengths so there's no wobble. We're now down to just sanding a bit more, and applying finish. I think I might be using enduro var, since she wants to paint part of it and I don't know if that would be compatible with arm r seal... Anyone know if you can use arm r seal over acrylic paint? I suppose I could always put a layer of shellac if necessary. 1 Quote
Chet Posted August 11, 2017 Report Posted August 11, 2017 Did you try to explain to her that when you do fine woodworking you don't cover it with paint? Quote
SawDustB Posted August 11, 2017 Author Report Posted August 11, 2017 Did you try to explain to her that when you do fine woodworking you don't cover it with paint? Yes... I've tried... I convinced her not to paint the top, but I think I've lost the argument on painting the legs. She just tells me that she needs to paint it so it'll be pretty. 1 Quote
Popular Post Chet Posted August 12, 2017 Popular Post Report Posted August 12, 2017 1 hour ago, SawDustB said: needs to paint it so it'll be pretty. Its hard to argue with logic like that. 3 Quote
SawDustB Posted August 12, 2017 Author Report Posted August 12, 2017 Its hard to argue with logic like that. I know, right? I looked around and I only had arm r seal, so the whole thing now has a coat. I figure I'll tape and put shellac on the parts she's painting and go that route. I do like how it's looking with some finish. 2 Quote
Popular Post SawDustB Posted August 31, 2017 Author Popular Post Report Posted August 31, 2017 I realized I never posted final pictures in here. We still haven't 100% settled whether there's going to be any paint on the bench, but she's starting using it for now. I may have told her that if she painted it, it would be a couple more weeks. Here's how it turned out with 3 coats of Arm r seal. Here's my daughter working on her "project". She's been randomly gluing scraps onto this thing since the start of her workbench, so it's growing kind of organically. I have no idea what it's supposed to be. You'll also notice a small vise that I added on the far end of the bench, which just clamps to the table top. I may install it permanently later, but she's happy for now. Unless we get a wild paint job on it later, I think that wraps this one up. Thanks for following along! 4 Quote
collinb Posted August 31, 2017 Report Posted August 31, 2017 On 7/15/2017 at 3:54 PM, shaneymack said: Planer step stool, that is amazing. It's got that non-slip, corrugated top for a reason. Doesn't it? 1 Quote
collinb Posted August 31, 2017 Report Posted August 31, 2017 Imo, this project would make a fine magazine write-up. It's got that family appeal. Quote
Chet Posted August 31, 2017 Report Posted August 31, 2017 She certainly looks like she knows what she is doing. Hopefully the paint stays away, after the Arm-R-Seal, paint on top of that might give it a slippery work surface. Quote
SawDustB Posted August 31, 2017 Author Report Posted August 31, 2017 She certainly looks like she knows what she is doing. Hopefully the paint stays away, after the Arm-R-Seal, paint on top of that might give it a slippery work surface. Well, I only ever agreed to consider paint on the legs. I don't want it to get on whatever she's working on. The top has a pretty good film of finish on it, so it's already slick. That's proven to be useful already for wiping up glue spills, but that's why I did it. I'm not too concerned about it for hand planing or anything, since I expect this to be mostly used for decorating and gluing projects. 1 Quote
