Popular Post Tom King Posted June 17, 2018 Popular Post Report Posted June 17, 2018 I've been using these cheap pump sprayers from Tractor Supply for a couple of years now. They aren't heavy duty enough for normal commercial work, but if you are careful enough to keep the tops clean before filling, and not be too heavy handed with them, they do fine. I especially like the pressure release. The best thing is the price, which makes them cheap enough to keep multiples. I have one dedicated to each mix I use for different things. The shelf is in the tractor shed, out of the Sun. I keep one with soapy water, and wash out the wand after use. By doing that, I have not had one trigger, or nozzle to clog up yet. By releasing the pressure, the wand is easily taken off the hose with fingers, yet still seals completely after you put it back on. I don't store them with pressure in them, but leave the mix in the tank between uses until it's used up. The rack for the wands eliminates any inadvertent siphoning, so no spills, and keeps the wand empty after cleaning, until the next use, so no clogs. I think the camera strap pads I use on a couple of them cost more than the sprayer. The only problem I had was one handle breaking at the locking slide. https://www.tractorsupply.com/tsc/product/groundwork-pump-sprayer-2-gal-capacity-pack-of-2 If you wonder about the good gas can spouts: https://www.ebay.com/itm/SPOUT-FITS-BRIGGS-STRATTON-WEDCO-GAS-CANS-FOUR-GALLONS-PER-MINUTE-FREE-SHIP/132640914352?hash=item1ee203bbb0:g:Vm4AAOxyeglTWqf6 2 1 Quote
Chestnut Posted June 18, 2018 Report Posted June 18, 2018 My dad uses these to fill our boat from gas cans. Removes having to lift the can it leaves a tiny bit in the bottom but that doesn't concern him he usually goes through 20 gallons a week or so. Boats are thirsty devils. https://www.amazon.com/Hopkins-10801-FloTool-Shaker-Anti-Static/dp/B000EH0ORI Quote
mat60 Posted June 28, 2018 Report Posted June 28, 2018 I guess I don't no anything about farming so I have to ask what you are spraying Tom. Also if you don't mind could you recommend a oil to use in my 24 HP diesel tractor. Quote
Tom King Posted June 28, 2018 Author Report Posted June 28, 2018 We have 163 acres to keep up, so I do a lot of spraying. If you need to know something specific, for a specific thing, I probably have it in a sprayer. The 40 gallon sprayer is welded onto the 7' rotary cutter with a short boom, that doesn't stick out either side of the cutter, but will cover a 30 foot wide swath. I hate to use poisons, but we gave up the fight without them decades ago. I run Mobil 1 in every gas burner, but diesels get Rotella. It's even available now in 2-1/2 gallon jugs, which changes the oil in the truck, and also one tractor, out of one jug. I'm still running two tractors that are 35 years old, were both used when I bought them, and I've never done anything to either engine. The truck has over 300 on it. Sometimes the truck has used Mobil 1 when the synthetic Rotella wasn't available in time, but mostly Rotella. https://express.google.com/u/0/product/18146876271719809625_15565243357657989993_8175035?utm_source=google_shopping&utm_medium=tu_cu&utm_content=eid-lsjeuxoeqt,eid-sgcwhwqgok&utm_campaign=8175035 2 Quote
Tom King Posted October 17, 2018 Author Report Posted October 17, 2018 I needed to get some smaller fuel containers for diesel fuel, so I bought some 5 gallon Midwest jugs from Tractor Supply. The red cans in the picture earlier in this threaad are old Blitz jugs. I don't remember how old they are, but probably not that old because they didn't have the vents in them to start with. The guy on ebay that sells those nice "nozzles" didn't have them specifically for the Blitz jugs, but the ones he makes for B&S gas cans work. You have to use the washers that come with the stock spout. The ones on the Blitz cans worked for a while, but I ended up having to make some new ones out of Viton material I got off ebay. Those work great, but one of my Ph.D. friends borrowed one of the cans, and lost the gasket when he did me a favor and refilled the jug up for me with ethanol gas. The Midwest gaskets slip around the end of the spout, so are not something else you have to keep up with. The spouts he Makes for Midwest jugs are machined to accept the gasket that you take off of the aggravating stock "leak free" spout. These machined aluminum with 1/2" high quality fuel hose are much more leak free than the stock leak free ones. In short, if you need to buy a gas can, get a Midwest, and one of these spouts off ebay. I put two vents in each of the diesel cans, and it does seem to empty some faster. Second picture is the stock gasket installed on the machined aluminum end. This is now as gas cans should be. Here's the link to the spouts for Midwest jugs on ebay: https://www.ebay.com/itm/SPOUT-FOR-MIDWEST-JUGS-4-GALLONS-A-MINUTE-EXTRA-HEAVY-DUTY/132548373407?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649 He includes one vent with the spout, but I had already bought a batch of vents. His are black. The package I bought was yellow vents. 1 Quote
