walidantar Posted April 3, 2019 Report Posted April 3, 2019 if i have a rabbeting block plane would i need normal block plane? Quote
Tpt life Posted April 3, 2019 Report Posted April 3, 2019 Totally depends on a few things. Chances are, no. However, in a work flow like mine...you may find yourself planning on multiple block planes just to have them set up for different tasks. Quote
drzaius Posted April 3, 2019 Report Posted April 3, 2019 I have an LN rabbeting block plane & it does work as a block plane. But the rabbeting plane has the blade spanning the full width of the sole & must be hone perfectly straight so there is more chance of leaving tracks on a surface that's wider than the plane. But if you can only have one, I'd get the rabbeting first & then get a block plane when you can. 1 Quote
walidantar Posted April 4, 2019 Author Report Posted April 4, 2019 the thing i was really wondering about is the chance of leaving tracks , i looks like as each pass it with totally dip down the wood as a dado Quote
Tpt life Posted April 4, 2019 Report Posted April 4, 2019 That’s setup and technique. Any plane can leave tracks. I don’t use blocks as smoothers, so I am rarely planing something wider than a block plane with s block plane. Quote
walidantar Posted April 4, 2019 Author Report Posted April 4, 2019 @Tpt life @drzaius thanks you this point is now clarified to me, instead of another block plane, a smother /small plane/ would be a better option for smaller stock Quote
riqmar Posted April 9, 2019 Report Posted April 9, 2019 There is a small dilemma here: a rabbet plane blade should be sharpened to a straight-line edge so as to facilitate crisp, square-cornered rabbets. But a block plane should be sharpened to a VERY slight arc or sharpened to a straight-line edge with the corners eased to minimize leaving tracks............ Quote
Tpt life Posted April 9, 2019 Report Posted April 9, 2019 That’s an opinion. Again, I don’t regularly plane anything with my block planes that is wider than those planes. I am not cambering any of my block planes. Quote
pkinneb Posted April 9, 2019 Report Posted April 9, 2019 5 minutes ago, Tpt life said: That’s an opinion. Again, I don’t regularly plane anything with my block planes that is wider than those planes. I am not cambering any of my block planes. I agree. I do not camber block plane blades. Quote
Tom King Posted April 9, 2019 Report Posted April 9, 2019 I keep two sets of block planes. Both Stanley 9-1/2's, and 60's. The burgundy set, that I bought new in the '70's, I keep the irons straight across. The older, dark blue pair have their irons kept with slight cambers like you would on smoothers. One stays in a custom made pocket on my tool belt, when I'm wearing it, and which one depending on what I'm doing. The thing that always worries me about rabbeting planes, whether a block , or a full sized rabbeting plane, is that you need to be a lot more careful that they don't get dropped, or knocked off of something, because the sides of the bodies are much more subject to be broken, than a standard plane. You see a fair number of the old ones that have been brazed back together. I don't do much sanding, so if I'm making some cabinets, or shelves with banded edges, the cambered irons are less likely to mar the surface of a shelf when trimming the edge banding. Quote
Chet Posted April 9, 2019 Report Posted April 9, 2019 1 hour ago, pkinneb said: I agree. I do not camber block plane blades. +1 Quote
