trz Posted January 29, 2020 Report Posted January 29, 2020 I bought an older Grizzly G1023Z right tilt. Max depth of cut is supposed to be 3 1/8” but, it’s actually only 2 1/4”. Does anyone know how to adjust that so I get the Mac cut I should be getting? Quote
Popular Post curlyoak Posted January 29, 2020 Popular Post Report Posted January 29, 2020 is your blade 10"? 4 Quote
drzaius Posted January 29, 2020 Report Posted January 29, 2020 Search online for a manual. It's probably a matter of grease/sawdust gunk that's causing interference. Quote
Isaac Posted January 29, 2020 Report Posted January 29, 2020 4 hours ago, curlyoak said: is your blade 10"? I agree, that sounds like an 8" blade. Otherwise some obstruction is preventing the full lift height. Quote
fcschoenthal Posted January 29, 2020 Report Posted January 29, 2020 Are you using a blade stabilizer? That will reduce the cut height. Quote
Chet Posted January 29, 2020 Report Posted January 29, 2020 Also if all else fails, Grizzly has some pretty good customer service, give them a call. Quote
trz Posted January 30, 2020 Author Report Posted January 30, 2020 Yup, it’s a ten inch blade, tried to raid it with just the blade ( no stabilizer) didn’t help. Made sure there was no saw dust or anything obstructing it. I’m thinking the previous owner may have had it apart. Wondering if position of worm gear in relation to the mating gear may be off. (just a thought from. looking at it and trying to see what could cause it). Called Grizzly CS and talked to a “technician “ I think she was looking at the same manual I was looking at cause she couldn’t tell me anything I couldn’t already see in the blow-up! need to call them back and see if I can talk to someone that might know more. Still think it might have something to do with how the hand wheel, shaft, worm gear are installed! Quote
drzaius Posted January 31, 2020 Report Posted January 31, 2020 You might need to remove the table so you can really see what's going on down there. If you do, watch for shims that may be present at each corner. They need to go back on in the same place each one came off or it will screw up the alignment when the blade is tilted. 1 Quote
Coop Posted January 31, 2020 Report Posted January 31, 2020 I would have bet on the blade, with the 1” difference. Quote
