Ken, I would lean toward lower pressure and higher flow. Many of those touting 3000+ psi don't spray enough water to wash cut grass off the driveway, yet can cut grooves in your wood deck or siding in a hearbeat. Some will even erode stone or concrete!
i have a Mi-T-M  2500 psi at 4.4 gpm, and it works great for work on, and around houses.  I have a bunch of different nozzles, for different purposes.  The nozzles are rated for different pressures, and flow rates, but I don't just use the ones that came with the washer.   I use some rated for more flow rate that put out less pressure per fan width for my pressure washer.
This is a pro unit, and far from cheap, but it's run Many hours in the 20-some years I've used it.  I wore out the B&S Industrial motor that came on it, and replaced it with a 13hp Honda, but I've never been in the pump.
edited to add:  It takes two strong Men to keep this thing running continuously though.  I pushes back with maybe 40 pounds of pressure, so we have to take turns to keep it running.  Especially if using a long, telescopic wand hitting the high parts of a house.  For one person, home use, I'd look for one at the same pressure, but maybe not over 3 gpm.  I'd still stick with Mi-T-M though.  I was planning on getting a lower flow one for high work, but then my rental place started renting towable man lifts.
Pressure washers should be rated by cleaning units. Psi x gal per minute= cleaning units.
The more cleaning units there are the farther away you can be, and the larger the swath, with the same striking force.
Example: 2500 psi x 4.4 gpm= 11000 cleaning units
Example: 4000 psi x 4.4 gpm= 176000 cleaning units... By using the same width nozzle (say 15 degree), you can back away and cover a much larger area and cover a given area much faster.
By using this formula, you will compare apples to apples... as to its cleaning ability.
Mi-T-M is a very well built long lasting brand, due to the quality of the parts used.
1 hour ago, Tom King said:
We have several old museum houses we keep up, and they get pressure washed most years.  You can't turn just anyone loose on these with a pressure washer, or they can blow water up under the siding, and in around the windows.  I feel like the 2500 is about as much pressure as we should use on those.
That’s any house. Cannot begin to describe the frustration of homeowners who had true leaks, but sprayed hoses all sorts of stupid ways for windows or doors, causing themselves to complain about leaks weather would never cause. Sort of like thinking a weather proof car could withstand immersion.
I have one I wouldn't recommend... Ryobi. I just wanted a cheap washer as I was renting, and although I've had it 5 years it does leak oil form somewhere. Never bothered to look. When it dies, I'll get a real one (now that I am once again a homeowner).
Depends on if you want electric or gas powered too. I imagine by now they have battery powered ones like the newer lawn mowers. I'm still into fossil fuels for portable power though. Honda probably makes the top of the line for home use.
We used an old 110hp jetski for a pressure washer this afternoon.  We were pressure washing the bottom of a cove though.  It worked great.  I used a muck razer to stir up the bottom, while my friend manned the jetski that I had tied to some trees.  We had such a current going that I couldn't roll the muck razer back against the current.  I had to roll it out of the water, and carry it back to start another pass.
https://www.amazon.com/gp/product/B07RVCXV1H/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1
  • Haha 2
Thanks guys. I have a 15 yo or so Troy Built with a B& S engine that has finally given it up. Probably the carb. Did’t know whether to buy a new carb or replace the whole unit.
Check the compression on it.  If it still holds compression, it's probably worth a carb.  The B&S motor that was on my pressure washer got harder, and harder to start.  The last time it wouldn't start, I checked the compression.  It was 28 psi.  I don't know how it ever ran the last time it did.
I think it should be pretty good.  I've had good luck with stuff from Northern.  I checked to see what Mi-T-M had in that range, and it's a Lot more money.
https://www.amazon.com/Mi-T-M-WP-3200-0MHB-Wp-3200-0Mhb-Pressure-Gasoline/dp/B00N6X9BJY/ref=sr_1_4?crid=3TIE29D5U37QP&dchild=1&keywords=mi-t-m+pressure+washer&qid=1589716192&sprefix=mi-t-m+pr%2Caps%2C228&sr=8-4
2.5 gpm should be a lot more manageable than my 4.4 one, which is very tiring to use for hours at the time.
11 hours ago, Coop said:
I think you would be happy with this unit. Northern tool has been a major supplier for many years. With moderate care I am sure this will far outlast your last pressure washer. I like that they use "no flat tires also".
  • Who's Online   1 Member, 0 Anonymous, 45 Guests (See full list)
