Coop Posted October 7, 2021 Report Posted October 7, 2021 I think I taught you that? But given that you are so much older than me, I doubt it? 1 Quote
Woodworking_Hobby Posted October 30, 2021 Author Report Posted October 30, 2021 So I am getting ready to clean my blades and one of them looks to have a little rust on the face, can you just a green scouring pad and some mineral spirts and rub out the spot similar to cast iron? Is there anything you have used with success to stop rust on the blades? I am assuming you cannot use just the normal stuff so saw dust does not stick or so the lubricants don’t transfer to the wood. Quote
Jonathan McCully Posted October 30, 2021 Report Posted October 30, 2021 9 minutes ago, Woodworking_Hobby said: So I am getting ready to clean my blades and one of them looks to have a little rust on the face, can you just a green scouring pad and some mineral spirts and rub out the spot similar to cast iron? Is there anything you have used with success to stop rust on the blades? I am assuming you cannot use just the normal stuff so saw dust does not stick or so the lubricants don’t transfer to the wood. I haven’t dealt too much with rust on my blades, but typically I use a green scouring pad with some Simple Green which cleans up my blade pretty nicely. Quote
wtnhighlander Posted October 30, 2021 Report Posted October 30, 2021 Scouring pad should be fine. I usually apply wax after cleaning my blades, either cheap floor wax, or leftover beeswax & mineral oil blend that I use for wooden kitchen ware. 1 Quote
Woodworking_Hobby Posted October 30, 2021 Author Report Posted October 30, 2021 27 minutes ago, wtnhighlander said: Scouring pad should be fine. I usually apply wax after cleaning my blades, either cheap floor wax, or leftover beeswax & mineral oil blend that I use for wooden kitchen ware. Yea I was thinking I could use the same wax I used on my cast iron was just not totally sure 1 Quote
Woodworking_Hobby Posted October 30, 2021 Author Report Posted October 30, 2021 I cleaned this blade about a week ago; dried after I was done; and then sprayed it with blade coat. So was not sure if this was just normal when you cleaned the blade or if I did not get fully dried and the wax would help next time. Quote
gee-dub Posted October 30, 2021 Report Posted October 30, 2021 If that is rust it is most likely from residual moisture. If you live in an area that has actual weather compressed air can help you get things dry as a bone. 1 Quote
Woodworking_Hobby Posted October 30, 2021 Author Report Posted October 30, 2021 59 minutes ago, gee-dub said: If that is rust it is most likely from residual moisture. If you live in an area that has actual weather compressed air can help you get things dry as a bone. Thanks I will give that a try next time to make sure I got everything bone dry on the blade. Quote
Coop Posted October 31, 2021 Report Posted October 31, 2021 Or, when the carbide tips finally wear down to the thickness of the blade, trying to cut thru some good hard maple will wear that residue right off. What you’re seeing in the pic shouldn’t be a concern. 2 Quote
Woodworking_Hobby Posted January 23, 2022 Author Report Posted January 23, 2022 On 10/30/2021 at 3:01 PM, gee-dub said: If that is rust it is most likely from residual moisture. If you live in an area that has actual weather compressed air can help you get things dry as a bone. I just cleaned my blade again this weekend as they had some good buildup from a few of my last workbench cuts on that deadman where you have to cut that v-notch in the bottom. The compressed air was a good call!! I was surprised how much water came off of the blade even though it looked dry and was dried off with a towel. A lot of water came out of those little stress relief cuts in the blade and I will do this with them from now on!! 2 Quote
