I've had this Rigid oscillating spindle & belt sander for several years, but this is the first time I've ever attempted to set it up in spindle mode.  CS is closed for the day.  I'll try them tomorrow, but maybe someone here knows the secret.
The sanding sleeve is loose on the rubber drum, such that it's never going to oscillate, and probably won't spin much, either.  These are the original drums and sleeves and I followed the installation directions in the manual (I believe).
I know sometimes with a rubber drum you're supposed to tighten down to force the cylinder into a barrel shape,  but that would take a heck of a lot of "tightening" with these drums.  And the directions explicitly say not to over tighten.
Am I missing something, or is there some work around?  Anybody else had this problem?
@fcschoenthal - is on target.  there are a variety of washer sizes.  the washer in use needs to be slightly smaller than the drum to assure it does not press directly against the abrasive sleeve.  It needs to compress the rubber drum and expand it against the sleeve.  One exception may be the 1/4" sleeve.  I believe it is retained by a metal clip at the base of the shaft.
  • Thanks 1
Yes I have the top washer in place.   I'm using the second largest drum (1 1/2"?).  According to the instructions that uses the 7/8" washer.
I cranked down pretty hard on the threaded knob, enough that I was concerned.  I can examine the setup again, in light of your comments.
I might also try wrapping some painter's tape on th drum.
My biggest beef with the Rigid sander is that the knob requires so much force to squish out the rubber spindle, I need tools to break it loose again. If I used the spindles more, I'd be looking for a replacement nut to embed into a big, honkin' knob. Or a wrench.
There was a whole conversation on finding a 3D printed wrench to fit the Ridgid sander. I printed my own, but several bought ones off of Etsy.
  • Who's Online   3 Members, 0 Anonymous, 46 Guests (See full list)
    Bob44
    Bob44
