Regarding the Rigid oscillating belt sander:  There is left hand threaded knob that holds the large roller onto the drive spindle.  It's a left hand thread to keep it from loosening during operation.  Unfortunately it becomes extremely tight during even brief use.  Even with a drop of oil on the threads I find I have to use pliers on the rubber knob.  In an attempt to forestall eventually tearing the rubber knob, I wrap it with blue tape.  The knob is a 5 point star shape, so there is no wrench will fit.  Maybe I'm the only one who has this problem,  but does anyone have a better solution to this?
Use epoxy putty to mold a larger knob to fit over the factory knob. It might not be pretty, but it should do the trick. Use some packing tape on the rubber to keep the epoxy from sticking while it cures.
Do the threads look okay? I can't recall mine being that hard to loosen. Certainly never had to use pliers on it. Maybe some anti seize would help prevent it from getting stuck?
My biggest problem with that knob is I always forget it's left handed, even with the graphic on top.
You could try a left hand nut and a wrench if it's that much of an issue.
It appears enough people have an issue with it that there are multiple 3D printable models: https://www.thingiverse.com/thing:3871548
I'm sure you could find one on Etsy if you don't have access to a 3D printer.
I often use channel lock pliers for leverage, but I don't need to squeeze very hard.  It never occurred to me that I might damage the rubber.  I might put some tape on the jaws of the pliers.
My three big problems are people over-tightening before they remember that it's a left hand thread, people turning the tracking knob thinking that they need to remove both to remove the belt, and remembering that the spindles have a top and bottom.  If I put them on upside down, then the sand paper rides up no matter how hard I tighten.
17 hours ago, wtnhighlander said:
I had the same issue with mine, and finally just stopped tightening it more than 'snug'.
Even if I just barely tighten, it gets over tight when running. :wacko:
15 hours ago, legenddc said:
$10 on Etsy
Option 1
Option 2
Thanks for your shopping help, legenddc.  I think I'll be buying the double headed one as the maker is actually near by.
In case anyone else is looking for one, check with your local library. Our library system has 3D printing services available. I've used it a few times and sent a file from Thingiverse and picked it up a week or two later.
I like the shop-made wrench idea above.
also, I would inspect the threads and seating surface to see if there are any deformations or defects that might be causing it to bind up.
On 9/16/2024 at 3:29 PM, Mark J said:
The wrench came in the mail today.  Looks good, fits the knob.  I think it will work great.
I also ordered one and agree. I also impulse bought some router corner templates and DeWalt battery holders and all seem good though I can't claim to have given anything a real test yet.
I have a set of corner templates from Rockler, and they're great! I use them often.
  • 4 months later...
I ran across this post and wanted to see overall how you liked this tool. I have a grizzly belt sander with cast iron surface I can use for heavy belt sanding but I was looking at finally getting an oscillating sander instead of using the drill press for this operation.  The comb belt / spindle seems to be a newer option from when I looked at getting one of these a long time ago. I was interested to see if you thought the combo was better or if you thought just getting the stand alone spindle had some advantages if I already have a belt sander.
It's the only stationary sander I've owned so all I can really say is that I've had no complaints and it's a big improvement over what I used to do, which is make a jig/stand for my hand-held belt sander.
  • Thanks 1
  • Who's Online   3 Members, 0 Anonymous, 46 Guests (See full list)
    Bob44
    Bob44
