Ok, complete novice here. (which will become obvious as you read!) Wooden doors on a rental property were damaged by a large dog with deep scratches. Instead of doing the necessary research, I followed my wife's AI instructions by filling the gashes with an epoxy filler. Might not have been that bad but I failed to take into account the color difference. AAAGGHH! I've sanded it down and as crazy as it looks visually the surface is actually smooth. What if anything can I do at this point to save the look of the doors? Is my only recourse to paint them at this point? I'd really rather not if at all possible but I've really screwed this one up royally!
Hi @Darren W. And welcome aboard!
A picture would sure help to understand the extent of what you're dealing with - but i think you have to have a few posts before you're able to post pictures. Can you estimate how deep the scratches are?
The other guys will probably have additional thoughts, but the see it, you can either sand or plane past the depth of the scratches, which would require refinishing, or the path of least resistance would be painting. On the other hand, if you can get the filler you used out of the scratches, the other guys might have some advice to hire to try to get it to match your existing finish a little better.
Best of luck to you on this and welcome to the forum
 The scratches are quite deep. Enough so that I would be hesitant to try to sand it down and I don't have access to a planer. I thought of trying to scrape out the epoxy but there is just too much of it to be realistic. Would a gel stain be a possible path here?
Ooof. That's ruff. (Pun intended and apologized for.) The other guys in here are more knowledgeable than me on finishing, so a grain of salt here...
Matching any stain with the existing finish is going to be difficult. I'd bring the door down to Hirschfields or similar and see if they can match it. But... Unfortunately no stain is going to go into the filler the same as it will the surrounding wood of the door. So you're probably still going to still see the scratches through the stain. Gel stains are good for species that don't take stain evenly, as well as use on vertical surfaces. A gel stain wouldn't hurt you here, but i don't think it will provide much benefit over what a regular stain would give you.
I probably would've started by bringing it into a finishing/furniture repair shop to get their thoughts. Which still might be your best bet.
Seamless repair of that magnitude is an art all unto itself.
We'll see what the other guys have to say though.
On 4/29/2026 at 3:53 PM, Darren W. said:
I appreciate your input! If all else fails I could paint it I guess. Such pretty wood though
Yep, keep that in your back pocket for a nuclear option. There's some pretty smart fellers in here, they might have some better ideas.
Scratches that deep, even in solid wood, will never disappear under a translucent finish. I can't tell from the photo, but even 'solid' wood doors are often constructed with a laminated stave core, and covered with a veneer. Those scratches seem deep enough to penetrate the veneer, meaning you could not even plane them away without altering the surface if the door. In all honesty, I think paint is your best recourse for salvaging that door. Possibly you could replace the veneer, but it sounds like you aren't tooled up for that sort of task.
Sorry to agree, the epoxy won't take strain once set, so paint would seem your best choice. I didn't know how you could have done better.
You might have used a dark tinted epoxy, but honestly even a perfect color match would not hide this level of damage.  Color matching the stain & varnish to the original un-sanded part of the door will be a challenge, too.  As suggested, maybe a furniture repair shop can offer some suggestion.
the Great Google Machine says the denatured alcohol may soften cured epoxy but that methylene chloride solvents (like found in MEK) are more effective. It'd be potentially tedious, but thoughts on trying to soften the epoxy and then scraping it?
Before I did that, I'd figure out what I'm going to replace it with which would be a significant enough improvement to warrant the effort.
18 hours ago, Darren W. said:
Maybe painting it using that simulated wood effect?! Never done it but what the heck.....
That's worth a try. I've seen it done professionally and the results were impressive.
Paint is the only logical choice for me. The underlying wood is Douglas Fir. I think. So it is not precious wood. Are you the  landlord?  Tenant or landlord, either one, I'd go with paint.
  • 2 months later...
Don't give up yet. If the epoxy is smooth, you can carefully tint it with gel stain, graining markers, or touch-up pigments to better match the wood. If the repair is too noticeable, replacing the filler with a stainable wood filler may be worth it before resorting to paint.
  • Who's Online   1 Member, 0 Anonymous, 36 Guests (See full list)
    32k
    437.5k
    26,007
    FurniCore
    FurniCore
