The Finnish Guy Posted October 17, 2011 Report Posted October 17, 2011 So i was looking at the DeWalt DW735X 13-inch Planer, that comes with Tables & Extra Knives. http://www.toolking.com/dewalt-dw735x-13-inch-planer-package-with-tables-extra-knives Im not on a huge budget here, and this is going to be my first. BUT, it should handle your basic needs that you are looking for in a thickness planer. So would this be a good planer to start with? Ofc, you cant feed so wide stock trough it (lets assume you are making your dinner table top), so you have to do it in multiple passes, maybe in 4 pieces, and joint the pieces together afterwards, lets say with, dominos to get the full width. Good's and bad's are welcome. Quote
dwacker Posted October 17, 2011 Report Posted October 17, 2011 The size is not limiting and the cut quality is great, better than most twice its size. FWIW you dont want to send glue ups through the planer anyways due to alternating the grain. Normally you would plane them, glue them, then run through a wide belt or drum sander if wanted to used a machine for the whole job. Don Quote
blkdiamond Posted October 17, 2011 Report Posted October 17, 2011 I have had this planer for about 6 months now and it was my first planer as well. Since this is the only planer I have ever used I don't have anything to compare it with, but I can say that it is easy to use. I have built my own stand for it out of 3/4 plywood as it is a beast to move around. For a basic planer, I don't think you can get much better. Quote
mikem Posted October 17, 2011 Report Posted October 17, 2011 I have DW734 and it is great planer. I don't think you could go wrong with either of the dewalt planers. Quote
Jfitz Posted October 17, 2011 Report Posted October 17, 2011 I have the 735 and it was also my first thickness planer. It has performed well for me, no complaints. FWIW that looks like a great price for the planer with extra knives AND extension tables. The tables are fairly necessary with this planer to help control snipe. 1 Quote
jmaichel Posted October 17, 2011 Report Posted October 17, 2011 I think any planer that thicknesses wood effectively is a good first planer, truth be told the Dewalt 735 is probably a better planer than most people start off with. I guess it is all relative and part of the woodworking/tool buying experience. I think it's really hard to know what one wants or needs until they have some experience with that type of tool. I have heard nothing but good things about the Dewalt 735, so imagine it will suit your needs just fine. Good luck! James Quote
duckkisser Posted October 17, 2011 Report Posted October 17, 2011 we use it at work and ya its pretty great only thing i don't like is how hard it is to get to the space under the shell if you need to see if anything is jammed in there. but it works great and is wonderfully simple. Quote
nateswoodworks Posted October 18, 2011 Report Posted October 18, 2011 I had bough the dw733 shortly after they came out and for over 10yrs I worked it HARD!! I ended up replacing it with a 15" Grizzly a couple yrs ago but I was very pleased with it, but I don't know if they have changed anything on it since to make it cheaper. A buddy of mine has also had his for about 10yrs and has been very pleased with it. Nate Quote
Jim DaddyO Posted October 18, 2011 Report Posted October 18, 2011 I have a Makita and it's big shortcoming is that the bottom table moves to adjust the thickness instead of the top power head. This makes it impossible to have in/out feed tables with out a lot of mucking about for each adjustment. Other than that, the machine is a champ. Quote
aggie4you Posted October 26, 2011 Report Posted October 26, 2011 You can get the same planer from amazon for $569. Plus, if you use This Link to access Amazon, Mark will get credit as well. Quote
CessnaPilotBarry Posted October 26, 2011 Report Posted October 26, 2011 I've been flogging a 733 for 11 years and see no reason to replace it... Something to think about that was mentioned earlier in the thread... Very rarely will a typical woodworker need a planer wider than 12 1/2' - 13". Glued up boards are very difficult to machine plane, and wide lumber is hard to find. In my shop, the 733 does rough thicknessing only. I finish thicknessing panels with a Performax 22/44 sander and/or hand planes. That said, the 735 may not be your starter planer, it may be the last planer you ever need. Quote
knotscott Posted October 31, 2011 Report Posted October 31, 2011 The 735 is an excellent first planer...especially if you don't already have a DC unit. If you do have a DC, then the DW734, Ridgid R4330, Delta 22-580, 223-590, or Makita 2012 would also be great choices in a portable planer...most for a bit less than the 735. Quote
