Modifying Dust Collection System
I am looking to improve my dust collection, right now I have a HF 2HP DC. I like the unit but I hate changing the bag and in my 9’ x 11’ shop it takes up valuable floor space. Here is my solution:
I would like to modify the system by mounting the DC motor to the wall and connecting it to a Spun Bond Cartridge Filter (http://www.oneida-air.com/inventoryD.asp?item_no=FCS186200&CatId={4E3492E2-FDA2-470D-A725-CFD615650270}) and use a trash can with a Thien separator lid. I would be a able to store the trash can outside when not using the DC freeing up space. Has anyone done anything similar to this and do you think it would work?
I should have said that I already the filter, it was a $75 CL find
can i suggest instead of a garbage can using a 55 gal drum with a sealable lid. we put one in the shop and except where the hose goes in we lose no suction or have sawdust come out. it holds alot of dust and big chips. plus since we have a hose going into the drum and then another going out of the drum all our big chips fall into that instead of into our dust collector fan.
looks good i just hooked up our dust collector to a barrel with a hose to make the suction and a second line comes out to hook up to the pipes not the most best solution but it works since i made it spending 0 dollars i do need to make a better seperator inside the lid though.
Hi Ben - I think that's a good plan. Changing out a barrel would be much easier than the bags.
Do you have any ability to locate the unit outside? This way you could run just the pipe through the wall, and with a little shed around the DC system to protect it from the elements (and knock down some of the noise) you'd have that shop space back permanently.
I cant vent outside because I live in a townhouse/rowhouse.
:) vent into the townhouse next door
Here is a quick video of the completed system. I am happy with it, but may make a thien baffle at some point.
http://youtu.be/2l5ii1ey1Ns?hd=1
Does anyone know if putting a baffle on a box instead round drum or can would kill CFMs being pulled? It would save me a ton a space.
  • 3 years later...
Duck, instead of hijacking the existing thread that is going on about dc systems, after a search, I found this one and thought it would be ok to hj a 4 yo thread? I'm wanting/planing on including a drum of some sort prior to my HF dc system using the elbow connections from Rockler. Since a 55 gal. drum will increase the footprint considerably, I was thinking of using a 30 or so gal. fiber or plastic drum. Now I'm seeing that height makes a difference in the performance. Having read your post here, how did you end up making yours. And to all, aside from the added convenience of not having to empty as often, is it best, performance wise to use a larger or taller drum?
Are you talking about making a chip separator before your HF collector? If so look into a homemade Thein Baffle. I just made one and it was really easy it also works very well.
I am and thanks. I will investigate the Thein Baffle.
4 hours ago, Just Bob said:
Here is another option https://www.youtube.com/watch?v=RpUbhA-6fbM  I almost did this, but changed my mind and went with a super dust deputy conversion.
Thanks. She's not only talented but cute! Now I forgot why I went to this link:huh:
sorry did not get back to you havent had internet for about a month since i moved just got it up and going. when i first started we needed something right away so i had a large purple 55 gall drum that has clips on the lid to lock it in place and a seal on the inside.  i cut a hole and fed my shop  vac hose into one side added a elbo on it that is the feed in so it sends the chips towards the wall, and a intake is near the lid after 4 years i would totally do it different and go with the thein and mount that to the lid of the drum.  in my personal shop that i just set up ill do that when ever i have 5 min to dedicate it to that project. instead of doing a harbor freight DC and fit to the lid of my drum ill instead build one out of pvc and plywood and mount to the bottom of my lid then lift it off when i empty the drum. why inside because the drum i have is a double layered plastic container so if i mount to the top and cut a slot in the lid it will put dust inside the inside and outside layer of my drum.
ps i agree april is cute and talented
  • 26,009 Total Members
  • Joseph b Newest Member ·
