ok some of you know i have moved into a new space.....very tiny space by the way. well now im going to have to invest in some new tools rather then folcus on wood turning as i have for the past year. with that in mind i had thought to do carving, inlay, Marquetry and any other small space wood working. so i had thought that i should invest in a decent set of hand tools.
first i want to get some carving gouges so i can start doing some real carving instead of just wittling in the basement. still have to decide what tool i need. going to do some research now to decide. but i will basicly be doing carving in the round and i want to be fairly small charictures. and i had also thought to carve masks. (any recomendations would be helpfull)
http://www.lie-nielsen.com/catalog.php?cat=559 texfire sugested these but he refered to them as being used for releaf carving so i dont know if they will work.
thought that i would need to get a range of saws
some different types of planes
want some card scrapers
dont know what else im missing so please make some recomandations to add to the list
I don't do much carving so I can't help out there but I have a Lie-Neilsen dovetail saw and a Veritas Carcass saw and both of those work very well. For the price I'd suggest a set of Veritas rip and crosscut carcass saws as being useful and reasonably priced. Card scrapers are very useful and very affordable so no need to stint on those, a full set can be had for $30 or so... Veritas just came out with a set using their new steel and Lie-Neilsen has a nice set as well.
For planes, it depends how rough the wood you use is. If everything is S4S and you don't need to dimension it a #5 jack and a #3 or #4 smoother may be all you need. I have a 6" electric Jointer and an electric planer so I don't do much flattening or dimensioning by hand and just use the hand planes to fine tune and detail so those work well for me. If you are getting rough wood and doing everything by hand a #6 Fore plane and a #7 Jointing plane are pretty much necessities as well.
I'm just starting to get into specialty planes but those are heavily dependent on what sort of work you are doing...
I'm sure you'll get lots of responses (and a few conflicting answers :) )
Oh yeah, almost forgot. Don't forget about sharpening whatever you get. Set aside a little extra cash for whetstones or whatever. There are a ton of options for sharpening so do a search and find whatever you think works best for you. I use water stones, some people like oil stones, some use scary sharp or Tormak or any of a dozen other sharpening systems. Carving tools may require specialized sharpening tools/techniques.
-Jim
-Jim
well jim thanks for the info talked to a few profesional carvers and one guy said that #2 30mm gouge, #16 3mm v tool, #15 6mm v tool, #11 3mm gouge, #11 4mm gouge
#12 10mm vtool, #11 10mm gouge, #11 16mm gouge. those would do me for most things im going to carve looking at the pictures they seem to cover a wde range of small detail to big flat surfaces that would be good for cleaning out lots of wood. the carver said that those would work for 90 percent of my work and its just a matter of techneque.
i plan on using jointers and planers for most of my jointing needs just thought it would be nice to slim down a board in my basement rather then go to work to use a electric jointer and planer. if need be ill have my miller cut my board down to size first or work with a budy in his shop. i have a #7 and few smaller planes that i dont know what they are since i just picked up at garage sale's.
This is the list I assembled when designing semester 1 of The Hand Tool School. http://www.renaissancewoodworker.com/getting-started-hand-tool-list/
This would cover any eventuality and is even a bit bloated for convenience. Truly if you want a bare bones tool list try this:
Jack plane (do all your milling with this)
Crosscut saw 26" preferred in the 8ppi range (break down stock to manageable size)
Carcass saw (10-12" crosscut filed in the 12-14 ppi range for all joinery)
Brace and a couple bits, 1/4, 3/8 (drilling peg holes and starting mortises)
1/4, 3/8, 1/2, 1.5-2" chisels
Coping saw
Cabinetmakers rasp
That's it, the rest if layout tools like dividers, knife, square, etc. Truly this is a bare bones kit and sacrifices will need to be made. If you want to dramatically increase the joinery ease then add a router plane.
I like a Japanese pull saw for small work. Thin kerf and amazingly quick cuts, rip or crosscut. The inexpensive plastic handled ones with a removeable blade are a good place to start. Low angle block plane is another multitasker.
