Watco Danish Oil question
i am working on a chest of drawers and was wondering how it would work with a danish oil finish....   i like the idea of the product but have never used it and really dont know much about the finishing process to begin with so if you have any comments or concerns i would greatly appreciate your feedback
Great stuff for a beginner. Just follow the directions on the can. Make absolutely sure you put oily rags outside spread out to dry ! There is a slight chance of spontaneous combustion! It takes a combination of circumstances , wadded up oily rag in a warm place etc.
Nothing to be afraid of , just precautions to prevent disaster.
Another thing great about Watco is once it has cured you can top coat it with almost anything at a future date. Easy to touch up dings and scratches as well.
I really like to use General Finishes Oil & Urathance Top Coat over danish oil.  Both are very easy to work with and forgiving for beginners...and seasoned veterans too!
If you like the look of natural wood colors and grains, then DO is going to be a staple in your finishing arsenal.
Tony, I just wanted to emphasize what Steve said...."Follow the directions on the can." If you try to short-cut the drying time, or you don't follow the application routine they suggest, it just doesn't turn out right. They know their own product and how to get the best out of it. Take this from someone that tends to read the directions as a last resort.
i know you probably dont HAVE to put a clear over it but what are the advantages either way?
also do i need to do the interior parts that wont be seen or can i leave those raw?  seems to me that the danish oil would make its way through am i right?
also   should it be sanded after it has had time to dry or once its dry you're done kind of thing?
Hi tonydem,
I totally agree with the posts above. Danish oil is a lovely finish. I also like hardwax oils . I find the hardwax has allot less odor and it it is more resistant to dirt and grime.
You don't have to do the interior parts if you don't want to. Depending on your timber choice raw timber can provide a nice background scent within the drawers.
I tend to apply more thin coats than described on the tin but best stick with the advise on the tin.
When totally finished and happy with the coverage and it is totally dry I lightly rub the work down with a piece of paper (just normal office paper) folded in to a square. It de-nibs the work without leaving scratch marks and leaves a perfect finish
+1 on the paper rub. A brown paper sack is about the equivalent of 8000 grit sandpaper I think, or maybe it's 800. Anyways it will buff out a surface and you can't beat the price.
Was wondering what the chest of drawers is made from?  Generally, Danish Oil is great, but it leave on uneven finish on some species without prior prep.
thanks for the +1 wdwerker
all Appalachian Red Oak....   flat sawn for the case,  quarter sawn for the legs and exposed edges on front(of course) and rift sawn for the drawer fronts
DO and red oak is a great combo!
 Very little pre-prep needed to get a nice finish.  As previously hinted, read the can.
I just pulled a can from my shop and can only add one thing... Red Oak can seep oil after about 30 minutes and continue for several hours (sometimes a full day).  Start finishing in the morning so you can monitor the surface for oil emerging from the grain and wipe back.  The can says it's ready in 8-10 for second coat -- I've typically had to let it dry for about 12-24 on red oak before it was really ready for the next go....
should the coats be liberal or thin?   term liberal being used loosely of course...  i just know some things say to flood the surface before the waiting period and wipe away is done.....
The problem is semantics -- one person's liberal is another's flood...  i apply a  liberal 1st coat avoiding pooling -- so it's not 'dry' and it certainly isn't a flood -- it's somewhere in between.  i'm not saying an initial flood won't work -- it's just i don't like the loss of control -- for some, a flood may be fine....  so for me, it's a liberal first coat until the wood doesn't take any more, wipe back, then monitoring the surface for seeping every 15 minutes...
I would put a clear (topcoat) over the top of the oak. Reason is the deep grain pockets collect dirt and dust and if someone places a drink or a spill, will go straight down into the grain. The oils and dirt from your hands will make the finish punky around drawer pulls. Watco is a very thin oil and offers little protection.
As far as the interior, I like to get a finish or stain...something on the opposite side of the wood to stabilize it, not likely the wood will pull the watco all the way through to the other side, just not enough time because it gases of from the applied side. Yes, I like to coat the inside of drawers with a clear water-based topcoat. Again, makes it a whole lot easier to clean or wipe a drawer out. Take a look at the inside of an old drawer that was left natural, they get funky looking.
-Ace-
-Ace-
thanks for the insight....   going to get started on it in a few days..  will post pictures soon
  • 26,009 Total Members
  • Joseph b Newest Member ·
