jmaichel Posted February 21, 2013 Report Posted February 21, 2013 Probably a dumb question but this is my first new tool. My table saw a cosmoline all over it including the inside underneath the table where bare iron is exposed. I know that a lot of people recommend kerosene but I don't have any. I do have mineral spirits and some Hoppes no 9 that I use for gun cleaning. Will either of those work? How about just plain old degreaser, like grease lightning? Quote
dwacker Posted February 21, 2013 Report Posted February 21, 2013 WD40 for cosmoline. Rewax with paste or even better waxilit. Don Quote
jmaichel Posted February 21, 2013 Author Report Posted February 21, 2013 okay thanks Don, even on the internals where the hand wheels mechanisms are covered with the cosmoline. Quote
dwacker Posted February 21, 2013 Report Posted February 21, 2013 You can use WD 40 everywhere, just do the best you can. I use waxilit in liquid on all my machines for lube and rust prevention every place. Paste on table because it last longer. Thinners and stuff like that can take off the paint. Don Quote
jmaichel Posted February 21, 2013 Author Report Posted February 21, 2013 Thanks for the help Don!!! Quote
mwatkins Posted February 21, 2013 Report Posted February 21, 2013 I liked mineral spirits better than WD40...for me, it cut through the cosmoline better and left less of a residue. Quote
Eric. Posted February 21, 2013 Report Posted February 21, 2013 I use WD40 to get up the bulk of the mess, then use mineral spirits to get the rest. Then T9, then wax. Then wax. Then wax. Then wax again. Quote
dwacker Posted February 21, 2013 Report Posted February 21, 2013 I got lucky. Only my bandsaw had cosmoline the rest just had machine oil, they were real easy to get cleaned. Don Quote
Trip Posted February 21, 2013 Report Posted February 21, 2013 First, congrats on a new tool --- having to remove cosmoline is ALWAYS a good problem to have.... I was is the automotive store the other day and it looked like WD40 had become as much a brand as a product -- i counted 6 different WD40s... Some 'WD40s' are kerosene w/ a carrier and some have heavy amounts silicone and a carrier... In general, I like to keep silicone away from my tools to minimize cross contamination with finishes... Whatever you buy to remove the cosmoline, read the label. Quote
stahlee Posted February 22, 2013 Report Posted February 22, 2013 I've used both WD40 and mineral spirits for cosmoline. Hehe, always fun to get the new machine but damn I dread removing the cosmoline. Don't forget to post picks when it's up and running! Quote
pghmyn Posted February 22, 2013 Report Posted February 22, 2013 I am in the same boat as James now, just receiving my new Grizzly tools. However, I have never purchase tools like this, thus I have never had the pleasure of cleaning them off. What exactly is the goo on my jointer (picture below)? Also, is this stuff beneficial if left anywhere? Should I leave it anywhere, or should I remove all possible? Quote
smythts Posted February 22, 2013 Report Posted February 22, 2013 Pghmyn, Having just purchased a few new Grizzly tools myself, I just went through the pain of removing all the "goo". I don't know what the actual product is they use, but per the manual, it's just there as a rust inhibitor prior to it arriving to you. You should remove it from all the cast iron surfaces prior to actually using your jointer. They have a product they recommend in their manuals (I can look it up if you don't have a manual). However, I used mineral spirits on my tools and it worked just fine. The trick is to let the mineral spirits sit for a few minutes before wiping it off with a soft rag or towel. A little time consuming and a little elbow grease but should come off fairly easily. Quote
jmaichel Posted February 22, 2013 Author Report Posted February 22, 2013 Glad to see you got your tools too pghymn! I still have to finish putting the TS together. Right now I am trying to make sure the CI wings are flush with the top. I did end up just using WD40, worked like a charm. I am going to follow up with T9 and Johnson's paste wax. Quote
Eric. Posted February 22, 2013 Report Posted February 22, 2013 It's cosmoline, pghmyn. Get it all off and coat your naked surfaces with some kind of rust protection product immediately. That cast iron will rust if you fart near it. Quote
stahlee Posted February 22, 2013 Report Posted February 22, 2013 Eric is right, make sure when you finished cleaning the iron off you get some T9 and paste wax on there. Also other options and there is plenty of discussions if you do a search. Quote
tim0625 Posted February 22, 2013 Report Posted February 22, 2013 When I got my new TS, I wiped it with lacquer thinner to clean it. Cut right through it. Then paste waxed. Quote
Freddie Posted February 22, 2013 Report Posted February 22, 2013 When I got my jointer, i took a plastic spreader commonly used in the auto industry to squeegee the cosmoline off the tables, then a light spray of wd-40 and a rag finished it off with ease. Using the spreader to remove the bulk of the cosmoline was the best choice in my opinion. I kept myself clean, and didnt gum up my rags or spread the goo around instead of removing it. 2 Quote
pghmyn Posted February 22, 2013 Report Posted February 22, 2013 I hope I didn't hijack your thread, James. I was assuming any questions I had would help you as well since we are practically in the same boat. So, I will remove the cosmoline from the surfaces, and wherever else I can see, but is it necessary to remove as much as possible? I mean getting into all the small parts and crevices that will never see the light of day or wood? I'm not looking forward to removing the stuff on my cutter head. Does this part need anything rubbed on when it is cleaned off? When I got my jointer, i took a plastic spreader commonly used in the auto industry to squeegee the cosmoline off the tables, then a light spray of wd-40 and a rag finished it off with ease. Using the spreader to remove the bulk of the cosmoline was the best choice in my opinion. I kept myself clean, and didnt gum up my rags or spread the goo around instead of removing it. Great idea. Thank you I have one of a squeegee in the shower, that should work. Quote
jmaichel Posted February 22, 2013 Author Report Posted February 22, 2013 I hope I didn't hijack your thread, James. I was assuming any questions I had would help you as well since we are practically in the same boat. So, I will remove the cosmoline from the surfaces, and wherever else I can see, but is it necessary to remove as much as possible? I mean getting into all the small parts and crevices that will never see the light of day or wood? I'm not looking forward to removing the stuff on my cutter head. Does this part need anything rubbed on when it is cleaned off? Great idea. Thank you I have one of a squeegee in the shower, that should work. Not at all we both benefit from questions being asked and answered. I am almost done setting up the my saw. The wing extensions were harder to get aligned than I thought they would be. I finally said "screw it they don't have to be perfect!" Quote
Trip Posted February 22, 2013 Report Posted February 22, 2013 ==> I have one of a squeegee in the shower, that should work. I'd think twice about that one... If I tried that, my wife would run me across the jointer... Quote
Eric. Posted February 22, 2013 Report Posted February 22, 2013 Not at all we both benefit from questions being asked and answered. I am almost done setting up the my saw. The wing extensions were harder to get aligned than I thought they would be. I finally said "screw it they don't have to be perfect!" As long as they're lower than the main table. Quote
pghmyn Posted February 22, 2013 Report Posted February 22, 2013 As long as they're lower than the main table. I lined mine up last night, and the edges are perfect. However, there is a few thousandths of a difference between the middle on both sides. I mean, barely enough to catch a piece of paper. I am fine with it for now, but I will eventually fix that. I am new to this style fence, and I was wondering how much of a gap at all should be between the bottom of the fence and table? A comment on my saw so far, the table is PERFECT. The miter slot is PERFECT. The fence was perfectly adjusted in about 5 minutes to be absolutely parallel to the blade. I have to put the fence on the jointer, line up the belt, take of all the grease on both machines, and get them running. Should be an eventful bit for that. Probably wont get that all done tonight, seeing as I have a lot to do otherwise Quote
TRBaker Posted February 23, 2013 Report Posted February 23, 2013 pghmyn, in reference to your question about how much of the goo to remove, just think how well sawdust will stick to that stuff and ask yourself which surfaces you can allow to have that sort of finish on. If you leave it on threads, like for your adjustment screws on the TS blade, it will gum up the works fast. Quote
Vic Posted February 23, 2013 Report Posted February 23, 2013 It may not be what is commonly recommended, but I used Simple Green to remove the residual cosmoline after using a squeegee to get the bulk of it off my tools. Then paste wax on the surfaces and a dry gun lube for the moving parts. Quote
pghmyn Posted February 23, 2013 Report Posted February 23, 2013 pghmyn, in reference to your question about how much of the goo to remove, just think how well sawdust will stick to that stuff and ask yourself which surfaces you can allow to have that sort of finish on. If you leave it on threads, like for your adjustment screws on the TS blade, it will gum up the works fast. That makes sense. Thank you. I found a bottle of "auto degreaser" that is used on engine blocks and such, I assumed it would be safe on the tables. It worked like a charm. I took off the majority of the stuff with a card, and then sprayed them down with the degreaser. The jointer and table saw look so much better. I was looking for a wax for the surface, and $24.00 for the T9 stuff seems expensive. Is there a cheaper alternative? Quote
