Vic Posted February 23, 2013 Report Posted February 23, 2013 I use Johnson's Paste Wax. It's not expensive and works well. I do need to add the caveat that I live in a dry climate. Quote
pghmyn Posted February 23, 2013 Report Posted February 23, 2013 I use Johnson's Paste Wax. It's not expensive and works well. I do need to add the caveat that I live in a dry climate.What happens in a "less" dry climate? Will it become sticky? Quote
Eric. Posted February 23, 2013 Report Posted February 23, 2013 He's saying that his equipment is less susceptible to rust, so it requires less protection than those of us who live in more humid climates. Quote
pghmyn Posted February 23, 2013 Report Posted February 23, 2013 He's saying that his equipment is less susceptible to rust, so it requires less protection than those of us who live in more humid climates. That makes sense. I don't think that my basement is too humid, but I will absolutely put a coat of wax on my tools. Are there any instructions I should specifically follow for applying to cast iron, or is it pretty straight forward? Quote
jmaichel Posted February 23, 2013 Author Report Posted February 23, 2013 I have some T9 that I am going to put on the top, followed by a coat of Johnson's paste wax and probably some dry gun lube that I have lying around for the internals. Quote
Trip Posted February 23, 2013 Report Posted February 23, 2013 ==>probably some dry gun lube that I have lying around for the internals You may want to go easy on the internals. I'm not sure what current best practice is, but I've always been told that when it comes to stationary tools, 'less is more' because lube also attracts dust/gunk/etc... Some of tools like wide-belt sanders, edge-sanders, planers, etc have specific lube points with a maintenance/lube procedure outlined in the owner's manual... So I've taken the position that if the manual doesn't say to lube, then I don't... I review the tool's manuals and use my computer's calender/scheduling feature to create a 'meeting' once a quarter, monthly, etc for the machine maintenance schedule -- it's a bit anal, but it works... OK, it's a lot anal... ==> I have some T9 that I am going to put on the top, followed by a coat of Johnson's paste wax As far as the cast iron top, i think you really don't gain much by 'multi-lubing'. I think it's more important to develop a routine and stick to it. Quote
jmaichel Posted February 23, 2013 Author Report Posted February 23, 2013 ==>probably some dry gun lube that I have lying around for the internals You may want to go easy on the internals. I'm not sure what current best practice is, but I've always been told that when it comes to stationary tools, 'less is more' because lube also attracts dust/gunk/etc... Some of tools like wide-belt sanders, edge-sanders, planers, etc have specific lube points with a maintenance/lube procedure outlined in the owner's manual... So I've taken the position that if the manual doesn't say to lube, then I don't... I review the tool's manuals and use my computer's calender/scheduling feature to create a 'meeting' once a quarter, monthly, etc for the machine maintenance schedule -- it's a bit anal, but it works... OK, it's a lot anal... ==> I have some T9 that I am going to put on the top, followed by a coat of Johnson's paste wax As far as the cast iron top, i think you really don't gain much by 'multi-lubing'. I think it's more important to develop a routine and stick to it. I will check the manaul again and see what it says but I am pretty sure that it recommends using a lubricant for some of the moving parts. I think T9 tends to get a little tacky even with a light coat and adding the paste wax on top will ensure nice smooth table top. Quote
Trip Posted February 23, 2013 Report Posted February 23, 2013 ==>I think T9 tends to get a little tacky even with a light coat it does, but i typically buff-it-out after it dries... not too bad... To be honest, i use what's ever closest at hand [edit: as long as it compatible with finishing]... J&J, T-9, Renascence, whatever. If I notice things drag a bit, I just grab the 1st thing I see on the shelf... I'm not all that convinced that one is all that much superior to any other -- as long as you use something.... . Quote
Byrdie Posted February 24, 2013 Report Posted February 24, 2013 I live in a definitely more humid climate and I'm happy using paste wax. I may be a little different, however, because I'm content with the understanding that the surfaces of my equipment will unavoidably develop some "patina." Quote
davestanton Posted February 24, 2013 Report Posted February 24, 2013 I use turpentine or degreser, then protect with silverglide. Quote
TRBaker Posted February 25, 2013 Report Posted February 25, 2013 Triple h, I would be careful about grabbing whatever lube you find on the shelf. I used some silicone lube on the table saw and it was an absolute disaster. It wasn't that it didn't slick up the top, but it left a residue on the plywood I was cutting and ruined the finish. Silicone and finishes don't mix well. Quote
Trip Posted February 25, 2013 Report Posted February 25, 2013 ==> I would be careful about grabbing whatever lube you find on the shelf yea, i should have clarified that.... I grab whatever appropriate product... I went through this phase where I was reading about (and buying) every anti-rust product review and/or a 'new-and-improved' article would appear in FWW/PW/etc -- I ended-up with about 6 different products... After about a decade, I just came to the conclusion was that they were all about the same in my shop -- now, I just grab which ever I see first... I am careful about compatibility with finishes -- I'm also very careful about applying lube to the machines themselves for the same reason... It's one of the reasons that [almost] every finishing schedule in my shop starts with a seal-coat of shellac... Quote
Spencer_J Posted February 25, 2013 Report Posted February 25, 2013 When i got my used unisaw, it had not been touched for 3 or 4 years so all the sliding and moving gizmos were very jammed. I used a brass brush, to cut the rust and resin gunked from all the use over time. I only had a teflon based dry lube at the time when i cleaned it. I have noticed that my moving parts arent so slippery any more and its due for a something different. I used minwax finishing paste wax for the top and it turned my table saw into a slip an slide! BE CAREFUL WHEN YOU HAVE A VERY SLICK TABLE SAW TOP. Things tend to slide way more than your average work surface. Add a spinning blade and it gets dangerous!!!! Quote
