While doing a bit of planning for a future project, I recently happened to stumble upon a YouTube video for "How to Trim Edge Bands" by the good folks at Woodworkers guild of America (WWGOA).  It's less than 5:00, so if you can spare the time, please watch:
Now, I'm still VERY much a notice with hand tools, but to me, this seems like something that could be done very quickly and easily with a hand plane.  In other words, I have a really hard time imagining Paul Sellers or Christopher Schwarz watching this video and saying, "Yes! That's how I would do it, too".
Basically the steps in the video are:
  1. make the mdf jig
  2. attach it to your router base
  3. find the correct bit
  4. attach the bit
  5. find a piece of scrap to test with
  6. do the height adjustments with the paper
  7. do the test cut (if wrong, go to back to step 6 and repeat)
  8. Do actual cut (if still not flush, go back to step 6 and repeat)
  9. Finally sand smooth
It seems like to me by the time I could complete this process, Paul would have finished, laughed at me for a few minutes, then gotten bored and wandered off for a cup of tea.  :)
So, my questions are:
How would you do this?  I'm assuming a bench plane, but maybe a block.  Or maybe you would use a scraper?  Or is there another tool specifically made for doing this time of work?
And finally, just for fun, how long do you think it would take you to complete?
Flush trim bit in a router, or block plane. Small pieces I do with a block plane. If edging a bunch of shelves I put scrap between them and gang then together and use the router. Time depends on the size of the panel and the amount of overhang you have on the edging.That being said the base plate spacer method also works good for flushing pegs in the middle of a work piece if you have a bunch of them to do.
He is using thicker solid wood edgebanding. The tricky part is trimming it flush without scratching up the inside faces. One slip with a plane and you ruin the inside face. That is why they go to the trouble to set up the router table. And once it is set up you can do a bunch of parts very fast and consistent .
I prefer to use a larger plane, usually my #5 or #6 as it gives me more surface area to reference against, skew the plane so the iron is pretty much only on the edge banding and get it super close, then finish with a scraper.
If I have a lot to do I will use e router table to get it close, I use the fence to hold it off the bearing a tad and finish with the way I mentioned above.
Yes its called a lipping planer. Essentially is what he made the only difference is the cutter direction. You can do the same on your jointer.
Blue tape and a block plane.
If I'm understanding you, blue table goes on the main board (not on the banding) and then you use your block plane until you start getting seeing blue table in your shavings.  Correct?  Then remove table and do a pass with a little sand paper to finish it off?
That's basically correct.  The tape creates a barrier that prevents cutting into, scratching, marring or otherwise damaging the primary wood.  At worst, if a small lip is left on the banding it should be no thicker than the tape - easy to remedy.
