So before anyone bashes me about this topic, yes I know this isn't about wood per say but there's a lot of knowledge here and I'm in need of some, folks.
I recently got a job at a huge machine shop ( http://www.h-pproducts.com/ ) and today I was using a belt sander on some metal tubing getting the burrs off. While using it, I called the video where Mark talks about super tiny saw dust in the air and breathing them in can be harmful without a proper respirator. Does anyone know if this could be harmful to me sanding steel? It's a good job, but I don't want to risk my health so I'd like to buy what's necessary to insure a long life.
Again, sorry this post isn't about wood, next time, I promise.
Thank you all for any information given. All opinions are respected and appreciated here, folks.
Wear a dust mask. I don't think metal creates super fine airborne dust like wood can but a dust mask and face shield are a good idea.
I saw a guy get a metal splinter in his eye and the doctor had to use a powerful magnet to get it out. Kinda makes me wish there was a wood magnet, I have had plenty of wood splinters over the years.
Ask questions about safety gear and proper ways to use the tools . My grip slipped for just a second today and I sanded my fingertip down far enough to just barely bleed. Hurt like hell but I heal quick. Sanders might seem safe but they can bite just like any power tool.
Respirator, eye and ear protection are all most likely OSHA requirements for that task. It isn't so much the metal particles, but the rust, dirt or coatings that sanding removes which are likely to stay air born and enter your lungs.
Having worked in metal shops, I've never seen requirements to include a respirator and if it were much of a danger, you can believe OSHA would be on it.  As far as airborne metal particles, it's not logical but I can tell you, run a grinder for any length of time and you have a nose full of schmutz.  You nose will tell you what kind of airborne stuff is there.  Eye and hearing protection is entirely different.  The shop probably issues ear plugs and eye wear - use them.
Grinders dont require a respirator but they do require full face protection which work two fold by keeping the crap out of your snout.
And the particles from the sand paper itself.
As someone who works as a Safety Technician in a refinery, I will tell you that we don't typically require respiratory protection for a belt sander on clean metal.  Now, with that said, if they're going to be doing if for 8 hours, I would probably require a respirator with a Hepa filter.  Or, if the metal being sanded was dirty with something that is harmful, I would also require the same respirator.
The face shield and the ear protection are always required for this tool.
Hope than helps.
Hope than helps.
Than you're the professional to talk to in this case. I'm just grinding burrs off the edges for 8+ hours each day. There is a little dust or whatever on the 100's I sand along with the grease/oil lubricated from them being bend into the shapes desired. Anytime we're in the shop, we're required by the shop to always wear glasses and ear plugs, and when grinding to always wear the face shield and gloves. Thank you for advice and wisdom, I'll be sure to pick up a respirator with the Hepa filter.
Haha, right, I caught myself a couple times on the belt sander, thank god I was wearing gloves. They really are quite the machine. People underestimate them because they don't have blades, but they can bite just the same.
To be honest, if you're just removing the burr, I would prefer a peanut grinder with a flapper wheel but, that's me.  The reduction in weight would be nice if doing if for long periods of time.
Good luck!
some of my buddies own a metal + wood shop. they do the metal in a sectioned off part of the shop away from the wood. they use the full face shield with respirator built in. Why don't I have one of those?! so smart. they mostly use small grinders with the diablo flap sanders for grinding burrs and welds. i would not want to breathe that crap for 10 minutes!!! the whole room is just dark tinted from the metal dust....
  • Who's Online   1 Member, 0 Anonymous, 35 Guests (See full list)
