So, this is a long shot, but something I would like to eventually do one day (add it to the list of things...).
I like to go ice fishing, but I pack pretty light. I've got my one man shanty, small heater, couple rods, and couple tip ups. My truck weighs over 4,000lbs, and I refuse to drive it on the ice. I paid far too much money to see it sink. I don't care HOW thick that ice is.
On most of the days I go fishing, I hate trekking out to the spot because I get exhausted dragging my gear behind me. I tend to go to lakes that are smaller so I can walk a shorter distance. I would like to hit up the bigger lakes.
I would like an ATV, but I'm cheap. So, I thought about building something that would carry me. In simpler terms, a platform with a small gas 5-7hp engine on it. Not looking to fly across the ice, but get to a spot without walking.
So, my question here is not whether I should do this, or the logistics of it as a whole, but how does one get an engine like this to work? http://www.harborfreight.com/65-hp-212cc-ohv-horizontal-shaft-gas-engine-69730.html
Does it idle like a car would? As in, if I fire it up, would it start to move if a brake was not applied? Or, does the shaft not start to turn unless the throttle was activated?
To get it to work, you need to mount it in some sort of frame that has wheels and a steering mechanism.  You might call it an ATV :)
If you don't want to spend on an ATV, then how about an old ride-on lawnmower or tractor from CL?
Lol. I have more of a question of shifting, or lack thereof, for the engine.
when i was 12 or 13 i used to build go karts with engines like those. you don't need a transmission. just a centrifugal clutch that will fit right onto the shaft. it will engage when the engine reaches a certain RPM. so when you idle you sit still, give it some gas and the engine speeds up and the clutch engages. you can get a chain drive clutch. just get a sprocket for your axel, connect the 2 and you are good to go. the size of your clutch and your sprocket will determine your gearing.
I have to agree with Woodsap. Go with a centrifugal clutch and infact, would go with a go kart type frame and maybe pull a sled to carry your equipment.
A small 3 HP engine, air cooled like a lawn mower but, with a horizontal shaft. a solid axle and large traction type tires and you are good to go!  Steering and brakes can be worked out fairly simply by using scrub brakes and copy the steering from a  go kart.
Rog
I have not been impressed with centrifugal performance in sub zero temps. The only vehicles I appreciate in winter that have these clutches also have neutrality engagement properties. While you warm your engine at high idle, your clutch will drag and wear. Low idle is generally not good for oil circulation.
To quote my father, "I'll drive out on that ice when I see elephant (excrement) out there." :)  Don't blame you one bit.
Mini Beep. Google it. :)
More fun than an ATV, but as/more expensive.  It'd be a fun way to find out if it really is amphibious though.  And by fun I mean changing your trousers afterwards. :D
  • Who's Online   3 Members, 0 Anonymous, 34 Guests (See full list)
    32k
    437.5k
    26,007
    FurniCore
    FurniCore
