Anyone build post-frame building shop?
We live on 2.25 acres and eventually I want to build a post-frame building for a woodworking shop, maybe sooner than later. Anyone on here have this type of shop? I'm going through the early research stages but looking for any advice - size, heating, shop considerations, etc. Any input and/or links would be appreciated.
I've built 2 of them.  One of which is my shop.
I'd be happy to answer any of your questions.
What is a post frame building?
I think it and pole barn refer to same type of building
At this point I'm looking more for advice but I do have some questions
- what size did you build and would you change the size if starting over?
- how do you heat and/or cool it?
I completely finished the inside of one of mine (the larger of the 2) and used it for many years as a recording studio.  Part of that building is now my woodshop.  I'm sure that I have some pictures tucked away if you have some specific questions along the way..
Sorry, I was posting this as you typed your reply..
I have a 30 by 48 which was the first one I did and then attached a 24 by 28 garage (pole construction) to it in an "L" shape.
I heat part of it with electric - 220 wall heaters.  The rest (shop) - I heat with pellets. - The garage portion is not heated.
Would I change the size?  For me, that wasn't really an option.  It's the biggest I could fit on my property.  As a rule of thumb, figure what you "need" and add at least 10%.
My shop is 36x60, 36x36 of it is shop the rest is storage and a bathroom mine completely insulated and dry walled it is heated by a wood stove
post-2926-0-33004700-1381804596_thumb.jp
post-2926-0-11216400-1381804321_thumb.jp
I built pole structures for years and even had my own business building them. A pole barn is a structure that is built off of posts rather than off a foundation the poles that are dug into the ground 4' and setting on a pad of concrete poured into the bottom of the hole. Instead of vertical studs you have horizontal girders usually 2x6s on 2' centers.
post-2926-0-75778400-1299113298_thumb.jp
post-2926-0-87776500-1299113339_thumb.jp
post-2926-0-29465700-1299113400_thumb.jp
post-2926-0-38313300-1299114101_thumb.jp
post-2926-0-52191500-1299113513_thumb.jp
post-2926-0-18439100-1299113591_thumb.jp
Our shop is in a 42x72 pole barn built by Farm Buildings Incorporated, half is shop and the other half is barn. Concrete floor under the whole building and the walls and ceiling are insulated. Shop is dry walled and the barn has ply nailed on the walls. Building is heated with a forced air furnace, and has a half bath.
The shop is raised about 3' so we could run electrical, mechanical, have some storage, and install a t&g wood floor. Didn't want to stand on concrete all day. A cyclone will be installed in the next month or so and the duct work will be under the floor too. 200 amp service and compressed air is piped throughout the whole building.
Building has 2 man door's, garage door, and 12' wide floor to ceiling sliders on the back. Really like the big sliding doors, and recommend putting a set in if you have the space.
The only thing I would change is to make the building bigger!
I have construction pics too if you want to see some of those.
post-6871-0-21059900-1386436065_thumb.jp
post-6871-0-34890400-1386436085_thumb.jp
post-6871-0-60189700-1386436097_thumb.jp
I love it.
Can you live in one of those?...I could sleep next to my tools.
  • 4 weeks later...
I have two pole buildings:
30x40 with a 20x40 lean to structure on the back
Insulated with spray insulation ( cheapest and most efficient ).
I can warm the shop at -10 to 70 degrees with little effort from the hanging propane furnace.
One door on each end of the shop.
48x64 ( not 100% certain on this one )
Not insulated but concrete floors and 4 x 13'-0 doors
If I were doing it over again:
1. Barns on separate electrical service. ( mine is jumped from the house )
2. The wood shop has an open ceiling and that eats a lot of heat. I would have done like some of the others and put metal on the joists to lower the ceiling volume.
3. I would have built the first barn higher off the ground ( i get a little run off water through the shop when it rains heavy ).
4. I would have put floor drains in ( see above )
5. I would have put tray drains in front of the doors.
6. I would have split the larger barn in half and finished the space vs leaving it open for storage.
Im attaching a photo of the smaller barn pre-wood shop.
sjeff70 a lot of people finish off guest apartments etc in pole barns.
post-14983-0-06939300-1389197427_thumb.j
post-14983-0-95365400-1389197447_thumb.j
I started my building of a pole barn build in March 2013 and completed it in October 2013.  I have an existing shop that is 8' wide x 16' and 10ft high with a 30" high rafter at the peak.  Anyhow......  I did this all by hand.  I have never poured concrete, so the slab I poured is by far not perfect.  Interestingly enough it took 123 bags of concrete to pour a slab 17x17.  Don't ever pour concrete over 9sq feet is my recommendation.  Leave it up to the pro's.  I though I would save money by doing it myself.  Not worth the back pain and time it took to complete.  I did it in 5 seperate pours and it's uneven, but I can work with it.  It's solid and it's not going anywhere.  So again.....  Get a concrete crew to pour a foundation slab.  I sank post hangers into the concrete for my 4x4's.  After that I put the posts in and put the cross members in place.  Put my header board up.  Doubled up my 2 x 10's on the exterior wall for the rafters to sit on.   Put up the rafters....  20ft length cut down to size individually because I didn't have a square shop to work off of.  I then drilled the rafters on the exterior boards and lag bolted them to the posts.  I then put my LVL beam in place.  I used 2 brackets I had to buy.  It took 2 people to do this.  I put the blocking on the 2 sides for the overhang on the rafters.  Put on the roof and rolled aspault roofing material.   Put up foam 4x8 sheets.  Put up hardiboard on the walls over the foam.  Put up the hardiboard trim on the overhang.  Installed a barn door sliding hardware.  Framed out a door and put that on the sliding hardware.  My existing shop has it's own power, so I tapped in to the electrical box and ran my wiring for power and lights.  I painted the hardiboard prior to installing it, so I don't have to paint it again and that is a plus.  Sealing the shop still needs to be done, but I will wait until spring to do that.
           Stuff I leanred.   It's a lot easier to build, but the same amount of money as if you did a 2 x 4 framed out wall.  The LVL beam I used is my pride and joy.  I stopped in a rafter/truss company and they told me the LVL beam I would need.  $149.00 plus the $55.00 delivery fee, but I did get a load of lumber, so the delivery charge was off set.  My shop stays about 10 degrees warmer then outside temps so far this winter.  I live in central Texas.  So far we have had 18 degrees here at my house and my shop was 33 degrees.  The concrete keeps it warmer.   The beauty is I feel it's more open then a 2x4 wall framing.  I can insulate further.  Sliding barn door I sealed using garage door seal and sealing roll foam gasket.  I have to shim all my tables to keep them from wabbling, but that's an easy fix with some shims.  I built my first shop by hand and was knowledgeable from my experience on that.  Many things are easier on a pole barn then 2x4 walls.  Sure I am no carpenter, but this is my shop built by my own hands with nothing but pride and joy.  I have space to work in.  You might say 16x16 isn't enough shop space, but moving from an 8 x 16 to a 16 x 16.  I still have that 8x16 shop for storage, so the 16 x 16 is not cluttered.
           I do acrylic plexiglass fabrication for a living self employed.  Since I have the space I want to give woodworking a try.  So far wood is very messy/dusty and I don't understand much of it.  Trial and error will be my motto.  I am here because I have many questions.  I saw Marc on YouTube as a guide rather then a teacher.  I have to be the teacher as Marc isn't here.
Thanks Marc
Zak from Liberty Hill, Texas
           Nothing more satis
If you're looking to adopt I'll volunteer myself.
