Hello Everyone,
I just received a Dewalt 735 planer (brand new) and set it up today in my shop.  I am a hobbyist and have practically all the other major power tools, but I have no experience using a planer before.  I was able to unbox everything and set it all up, but after running a few boards through the planer, I've encountered two different problems.  These problems occur similarly on both pine boards and oak.  They also appear on both speed settings of the planer.
The first problem, which I am calling problem A, is as follows:  many fine but somewhat deep scratches are appearing, all perfectly straight, in a 1-½ inch band running the entire length of the right side of my boards, about 2 inches in from the outer edge of the board.  If I use boards that aren't as wide and run them through on the left side of the machine this doesn't happen - it only occurs when a board passes under the right part of the machine.
The second problem, Problem B, is as follows:  about 2 or 3 inches from the end of the board, on the end that went through the planer FIRST, I'm getting a horizontal, very smooth depression/gouge in the board.
I have attached an illustration of problem A and problem B.  Hopefully it will be clear as to what I am talking about.  Since I have no idea about planers, I don't know if this is a real problem or a simple adjustment that I haven't set up properly.  Can anyone help out?  Sorry if this is a simple question, but I really have no idea as this is my first planer.  Thank you very much.
post-6579-0-87546700-1388787988_thumb.jp
Problem A is nicks in the blade(s) transferring through to the board. Problem B is snipe and this occurs to some extent on all planers. None of the problems are major issues as problem A can be planed away with a smoothing plane or simply sanding. Problem B can be circumvented by making an allowance for the depression by cutting the board longer than you need. Then simply crosscut the snipe away when you cut the board to length. Snipe normally occurs to varying degrees both on the infeed and outfeed sides of a board when passed through a planer.
Snipe can be minimized by taking measures to ensure the stock stays flat on the bed as it goes in and out. Bed extensions can help, as can butting a sacrificial board against each end of your stock. The snipe occurs when the stock tilts a bit when only one feed roller is holding against the bed.
I believe the infeed and out feed tables are an option for that planer. Did it come with them? If not they will certainly help. Also, supporting the board beyond the tables will also help minimize the snipe.
Mine did come with the tables.   I will try to support the stock better as it comes in and out.  I'll also definitely open up the planer and check to see if one of the blades appears to be damaged.  That's pretty disappointing if that's what is going on because it is brand new and I certainly didn't break it (it did this with the first piece I ran through it), but at least the planer came with a set of replacement blades.
Thanks for the help, everyone!!!  I really appreciate it.
Do your tables slightly angle up from the main table? That's key to help avoid snipe. With the tables, except on long stock, you shouldn't need to do more than support the piece as it nears the end of the cut by raising up slightly. Without the tables, I've seen lots of stories about snipe.
The blades should be able to be flipped over.
Also, how much material are you removing with a single pass? Snipe can be reduced by taking lighter cuts.
When I first starting woodworking years ago, I took a class from a local college. The had a MASSIVE planer, that could handle material 25 to 30 inches wide. It was a beast and could easily make a heavy, smooth cut. The mistake I made was thinking my lunchbox planer could do the same, and I bogged it down the first day I bought it. It mad a mess of my boards.
After taking light cuts, with sharp blades and some indeed/out feed support, I have all but eliminated the issue. Sometimes I still get a little snipe, but that's the nature of the planer I'm afraid.
As for the nicks, there are really only a few options. First, change the blades. Second, avoid that spot on the planer. Third, sand or plane away the ridge afterwards.
Let us know how it goes!
Hello EG, i have the same planer with the same issues. It can be annoying, but i have learned to make lemonade with it. I leave my boards extra long to deal with snipe, i simply cut it away after milling. I think this takes the stress out of the equation for me. Also check that your outfeed roller is clean. They get gummed up and a hard piece stuck on it can leave marks in your work. Wipe them with mineral spirits. As for knives, I've been on the fence for a while now of whether or not to install a shelix in the dewalt. Costly, but a great upgrade for a small shop where i don't see fitting a 15 or 20" any time soon. Good luck!
For the nick in the blade, move one of the blades left or right just a fraction.  For the snipe, feed one end of the board into the planer and lift up slightly on the other end as it catches and begins to feed itself in.  Lift slightly on the out feed side as it finishes the cut.
Since the scratches are described as "sometimes deep grooves" I don't think they are from the knives (nicks) at all as those would leave raised ridges rather than grooves.  I think there is something in the head of the machine, perhaps a screw that isn't tightened all the way or that was installed crooked, that is leaving the marks.  Make sure everything on that side of the head is flush and smooth but be careful when doing so not to run your hand into the knives.
As suggested, worst case scenario is to stay away from that side of the machine when planing but it would be a shame to give up being able to use the full width of your machine.
The snipe question has been adequately answered by pretty much everyone else.
Thanks so much everyone.  I've checked the blades and indeed there was a defect in the blade that was causing the scratches.  I agree with Byrdie that I would have thought this would leave raised lines instead of grooves, but yet, grooves they are.  This problem as has been fixed 100% by flipping over to the fresh side of the blade.  I'm now very happy with how this planer is performing, as it seems that snipe is a common and not totally unavoidable problem.  I'll definitely try lifting up the boards as they enter/leave the planer the next time I use it.  That sounds like a great solution that shouldn't be too hard to accomplish.  If all else fails I guess it's not THAT big a deal to leave a little extra length on the boards to trim away the snipe later.
@Cochese:  I'm not sure about the tables.  I'll have to take a look at them more closely and adjust them up slightly, if necessary.
@Franklin pug:  I've been taking very light passes to start with (~1/32) which is why I was so surprised to see the scratching issue in particular (problem A).  What would you say the most is that is reasonable to take off per pass?  I see that the planer can go up to ¼ inch but that seems WAY crazy to me.
@Freddie:  thanks for mentioning the rollers.  I never thought of that.  It's not the problem here, but I'll have to keep that in mind as I use this thing more.
I often run a scrap before and behind the board being planed and the snipe ends up on the scrap. Clean square trimmed ends helps with this technique. I set up my lunchbox planer with an infeed and outfeed table flush with the bed. Both are 8 ft long and it makes a big difference in the quality and ease of planing a staticky of boards.
  • 2 years later...
On 1/3/2014 at 9:47 AM, Egraff said:
"as it seems that snipe is a common and not totally unavoidable problem.  I'll definitely try lifting up the boards as they enter/leave the planer the next time I use it."
I have made DW734 and DW735's snipe-free for most stock.  the "ten cent solution" of raising the outer edges of the table about a dime thickness high is common.  On one DW735 I had the outer table edges raised to where a straight edge laid through the machine was a full 1/8" off the platen.
The success of this fix is somewhat based on the length of your stock.  If the stock is not engaged by the table outer lip while the cutterhead and rollers are in play it cannot influence the cutting path.  It can help to picture what is causing snipe:
  • Who's Online   0 Members, 0 Anonymous, 47 Guests (See full list)
    26,008
    Bob44
    Bob44
