What else do you use an air compressor for?
I know I should get a separator for my HF DC + Wynn 35A filter, but in the meantime I'm looking for a way to efficiently clean the filter. The primary suggestion seems to be hitting it with compressed air. I don't currently have an air compressor and while $60 and a trip to HF should take of that, is there anything else I can use the air compressor for?
I don't use many brads, staples, or any fasteners for that matter. And I believe I'll need a proper HVLP system if I branch out into spray finishing.
I seems a shame to spend $60 to clean a $180 filter. Any ideas?
Once you have a compressor, you'll find many uses for it.
I use it for lots of different air tools not just in the wood shop.  I use if for about every tire around the house from vehicles to kids bicycles.  Works great for blowing dust off a project before finishing..  The list goes on..  I've never regretted purchasing a compressor!
Spray painting, inflating tires, blowing things off ( pants, sanded pieces, getting gunk out of places you can't reach) and, that's just off the top of my head, you will find a lot of uses for yourself.
Sorry Toids I posted than saw you said essentially the same thing (jinks, you owe me a Coke).
I like to take the hose and make fart noises with my elbow.
Guess my age really kicks in here...
With a small compressor like the one you're referring to, you can pretty much take spraying finishes off the table; it just won't be able to maintain enough air to properly drive the gun.  The only exception would be if you're air brushing :).  I use my little pancake compressor for that all the time..
Other than that, the rest of it's uses have been mentioned (blowing off tools, dust for pre-finishing, tires, etc).  On really dirty shop days I'll use it to blow the sawdust on the floor and channel it out the garage door :P.  Faster than sweeping..
  It certainly won't be a purchase that you'll regret!  They are handy little things
That little compressor won't move enough air to clean more than 15 seconds and hold any pressure, much less produce enough volume to do much work with.  I use compressed air every day, if nothing more than to blow the sawdust off of me.
When anyone does get one, you will not only need a small blow gun, but this thing is well worth it's cost so you can stay out of the fray, and also blow stuff off the floor, and out of cracks without having to bend over:  http://www.northerntool.com/shop/tools/product_200512855_200512855  It gets used to finish up behind the leaf blower when the wind is blowing the right direction for final cleaning of the shop-doors front and rear specifically for that.
Along with all the regular shop stuff, from nailers to impact guns, I also blow golf club grips on and off with compressed air.
It's a must have as far as I'm concerned. I have a Senco (Thomas)oilless pancake that we have used for nailers, a little twin tank Emglo that I would highly recommend as the smallest if you are going to have just one, a 30 gallon single stage that runs off of 110 from Home Depot for blowing out cracks in old houses, and a 5hp 2-stage 80 gallon that since I stopped using a step van for work, has a stationary spot outside the shop under a shed.  I wouldn't advise wasting any money on one any smaller than the Emglo.
Not necessarily from these people, but here's the little Emglo:  http://www.tylertool.com/emglo-e810-4v-1-1-hp-4-gallon-oil-lube-twin-stack-air-compressor/emgne810-4v,default,pd.html?ref=tylercipla&zmam=31282435&zmas=47&zmac=667&zmap=emgne810-4v&srccode=cii_17588969&cpncode=34-139835958-2
My favorite thing is to take my filter from my shop vac after i bang the dust out, I go outside and blow all the fine dust off, basically creating a dust bomb on the entire block. Works like a charm.
I use a cheap air drill from HF to spin an abrasive finger mop for sanding moldings. Brad guns and micro pin guns are cheap nowadays and handy for quick jigs and shop stuff even if you don't use it on projects. A bead of glue and a couple of micro pins from the back side can save you from a difficult clamp up.
Using compressed air to blow dust out of power tools can extend their life. I use a pencil type blow gun it provides a much stronger stream of air.
I have an air ratchet and a 1/2" impact wrench for work on machines and vehicles. When you have a stubborn bolt an impact wrench is your friend. Made a quick job of getting the blades off my riding mower this summer. Driving lag bolts in deck or garden structures is a breeze. These run on my little pancake compressor, but sometimes you have to wait for it to build back up.
I have a small 6gallon pancake compressor.  It was the Porter Cable combo deal from Home Depot that came with a finish and a brad nailer.  I have used it for inflating lots of stuff over the years, car tires, bike tires, kiddie swimming pools.  I also keep it handy when clearing out mortises as the blower cleans out dust a debris very effectively.
I also use it for HVLP spraying.  Conventional wisdom says no way, but for small projects (the largest being a cradle) it works fine.  I largely spray shellac with this setup.  The biggest thing is making sure the motor is given time to cool so that it doesn't over heat and risk burning it out.  That said, I will eventually get a turbine sprayer when the budget allows.  :)
You can always combine multiple air compressors down the line if you don't have the funds now for a proper one but need the air. Do you have any friends or neighbors that you could borrow from? Also many pawn shops and tool repair shops have used air compressors too. Don't forget about craigslist. The wand that tom king suggested is one of the best cleaning tools ever!!!
Sent from my thumbs
We always fabbed our own wands with a cheap blower and steel brake lines. They could be formed to go around corners... oh the pranks.
Me thinks we have a consensus.  I echo everyone.  One of the best things I ever did was buy an air compressor - the smaller portable AC from Lowes.  Something like this.  Trust all of us...once you have it, you'll say "I should have done this years ago" and you'll wonder how you got along without it.
I totally agree with this and all the rest of the comments above .....except for one part .
I started with a small 25ltr compressor and it worked perfect for my stapler and small pinner but not much else. I wanted to start spraying my finishes and I knew I needed something bigger so I got my current 150ltr 3hp and I was so sorry I wasted the money on the small compressor. If you can hold out and increase your budget to buy a bigger compressor I'd highly recommend it.
And thinking of it now it's the lowest maintenance and highly used tools in my shop !!!
I think if you want to get good atomization out of an HVLP I would just get a full sized compressor. I have the little emglo posted above. It has one issue and that is when its cold it will pop its own breaker if left on. From what I understand this is pretty common so I wouldn't have it in an unheated work space unless you shut it off at night manually. I also have a 5hp 80gallon champion industrial compressor and its ok but even at that its won't keep up with hvlp atomizing properly unless you go slow. I also have a 10hp rotary screw that is actually made to handle an hvlp and it does quite well. I wouldn't use the champion to spray very much I did my truck and it kicked its butt even being an industrial compressor. The emglo won't spray anything except very thin lacquer stains  which are 99 percent lacquer thinner with a very good lvlp gun.
No Marco...if you're looking toward spraying anything, my suggestion on a compressor is the wrong one.  Go with something much larger like what Particle is suggesting.  I just use mine for nailers and such.
I'm sorry Tim I didn't mean anything negative :(
Particle board is right and Kranzpj probably isn't even thinking about spraying so he has no need for a big compressor.
It's like the whole 6" V's 8" jointer, the 6" does its job perfectly until you have that 1 wide board.
My apologies again Tim
I use a compressor a lot for turning.  I first got it so I can blow out the shavings from hollow vessels when I am hollowing out the interior.  But, I use it now for every project, especially at the sanding stage and especially on wood like mahogany with large pores.  By blowing off the sanding sawdust I can really see if I have done a good job sanding.  And I blow it off again before finishing, and after intermediate sandings of the nibs.  I also blow the sawdust off of me as someone else already mentioned.  I love the idea of blowing out the filter of the shop vac.  I'm going to do that from now on!
No No Marco....no offense taken.  I was thinking on a small scale with a compressor...more of a general use application - bicycle tires or like Cindy said using air to blow off a project in the lathe or blowing off the table.  On my table saw, the dust collection isn't great.  I remove the throat plate, turn on the dust collection and spray air from the top.  It gets the sawdust out of the corners.  If you've getting into spraying paint or stain, you probably need a lot of air...I don't think my compressor could keep up.
