daviddoria Posted May 31, 2014 Report Posted May 31, 2014 I broke the pilot bit in my countersink. I got the set years ago so I don't remember what brand it is. The twist bit slides into the countersink and is fastened with an Allen screw. As hopefully you can see in the attached picture, there is a long flat spot on the bit so that the Allen screw will prevent the drill bit from spinning. Does this type of bit have a name? Can I just use a normal twist drill bit without the flat spot? It is a "6" countersink - does that mean it should be used as a countersink/pilot for #6 screws? Or does it mean that it is a #6 twist bit? (or are those the same, i.e. would you use a #6 bit for a pilot for a #6 screw?). Thanks, David Quote
Tpt life Posted May 31, 2014 Report Posted May 31, 2014 I am not sure if there is a downside I did not notice (because at the time I was working on rougher projects than furniture) but I swapped out several twists in a set like that while installing exotic decking. The bit would get hot and fail quickly under forced speed (I know better now) and it was easy to keep five or six bits on hand. Short answer, not sure it is Right, but you Can. A few passes with a file will give you a flat. Quote
wdwerker Posted May 31, 2014 Report Posted May 31, 2014 They make a soft set thread locking material, sold at automotive stores, that you can use a tiny drop of to keep the set screw from loosening. I got a huge set of drill bits at Costco, made in Asia and not very good on hard steel, but great on wood. Especially when the get broke faster than they get dull. I think the set was $40 - $50. It has hundreds of bits, fewer bigger bits and bags full of the tiny ones. It's an investment but replacement small bits can be several $ each. An accurate drill card to identify the size of a bit is very handy, or you can use a pair of calipers. I use a diamond paddle to touch up the countersink before I replace the bit. I'm also a fan of Glide Coat and Blade Coat sprays. The blade coat helps keep resins from building up on bits and saw blades. The Glide Coat keeps tablesaws, jointers and the like smooth and slippery. Quote
wtnhighlander Posted June 1, 2014 Report Posted June 1, 2014 I have a similar countersink, and have used standard replacement bits with no flat. It is a little easier to spin then loose, but it mostly works just fine. For replacements, I found that Lowes carried a Hitatchi brand, blister packed with the bit ( with flat side) and a replacement set screw. I haven't needed it for a while, so I am not sure if they still sell those. Quote
T-astragal Posted June 1, 2014 Report Posted June 1, 2014 Just measure the drill size and replace with the correct drill. Touch the shank to a grinder or gelt sander to create a flat and you are good to go. Steve Quote
Byrdie Posted June 2, 2014 Report Posted June 2, 2014 Not sure where you're located but I buy similar countersink sets at Menards in their Vermont American line for less than $2 each. I have #6 and #8s that I use a lot. I've broken a couple but at that price I just replace the whole unit. Quote
Trip Posted June 2, 2014 Report Posted June 2, 2014 ==>soft set thread locking material, sold at automotive stores LocTite 222 -- purple -- low-strength (good for this application) http://tds.loctite.com/tds5/docs/222-EN.PDF Other popular strengths worth having around the shop or in the garage: LocTite 242 -- blue -- medium-strength (general purpose -- bolts on stationary woodworking machines, etc) LocTite 262 -- red -- high-strength (garden equipt, high-vibration, gas motors, etc) typically needs to be heated with a torch to remove There are about fifty more threadlockers and another 200 thread preps/gap fillers/release agents: high-temp, low-temp, UV hardening, fast cure, slow cure, perminant, food safe, pre-assembly, perminant, ultra-high strength, conducting, non-conducting, etc, etc. It's easiest to shop by color: http://www.henkelna.com/industrial/Loctite-Threadlockers-by-Color-14023.htm LocTite is probably the most expensive of the threadlockers, but you use so little, one bottle will last years... It's worth getting actual LocTite -- consistancy across mfg lots, highly stable and a shelf-life of years (I've got some speciality formulations that are a decade old and still work fine). BTW: 290 is also very useful in the woodshop. It's basically 'gummy' and retains nuts/bolts/etc, but allows for minor adjustments -- it's specifically designed for things like set screws, carbirator adjustments, etc... It's between 222 and 242 but doesn't quite cure hard to allow for future adjustments... Very useful for eccentric pressure bar adjustments on planers, cam adjustments on bandsaws, jointer gibbs, etc. Quote
