kmaukamp Posted March 3, 2016 Report Posted March 3, 2016 I'm in the process of working out the plans and gathering the materials to build a bandsaw mill. Does anyone have and good reference for homemade mills. Still trying to figure out how to make something to adjust blade track and some other odds and ends. Thanks. Quote
Brendon_t Posted March 3, 2016 Report Posted March 3, 2016 I watched a few guys on you tube buidling them. Not sure if any were working from plans as they all were different. Quote
sjeff70 Posted March 3, 2016 Report Posted March 3, 2016 Hope you put up some pics or videos of your plans and progress. I recently passed on an opportunity to bid on a used Wood-mizer at a local estate auction. Not only am I not ready for one I don't have the room to store one. I don't even have the room to store a small trailer. Quote
kmaukamp Posted March 3, 2016 Author Report Posted March 3, 2016 I'll make sure to post pics of the progress. Quote
BobInAustin Posted March 3, 2016 Report Posted March 3, 2016 I can't figure out a good way to adjust the tracking. Quote
kmaukamp Posted March 3, 2016 Author Report Posted March 3, 2016 I'm thinkin as long as I make sure the wheels are straight and dead on in line then I shouldn't have much of a problem. Quote
Gixxerjoe04 Posted March 3, 2016 Report Posted March 3, 2016 I'd check out arboristsite.com they have a lot of info about milling and all that fun stuff. I've been thinking about buying a big chainsaw and a panther mill to mill slabs. My buddy wanted me to go in on a used lt40 last month that was cheap on craigslist. If i lived in the country and had the money i def would have, but since we're looking for a house at the moment, need the money. Quote
Tom Cancelleri Posted March 3, 2016 Report Posted March 3, 2016 for adjusting tracking, make a carriage that holds one wheel and have that carriage pivoting up near the shaft where the wheel rides. Then at the bottom of the carriage, embed a large T nut or something similar and have a bolt with a knob run through the body to the bottom of the carriage (opposite side of the pivot) when you tighten the knob have a second nut on there to lock the angle of the wheel in place once set. Quote
Brendon_t Posted March 3, 2016 Report Posted March 3, 2016 The lt20 I have used in the past uses a thrust bearing behind the blade. Obviously it would be better to have the wheels set so that the blade tracks perfectly alone but the force alone pushing back on the blade requires something supporting the blade. The problem I see with trying to set it up would be it has to be done with the blade under tension. Hard to tension the blade without it welded. Depending on how you are attaching the wheel, maybe mount, try, shim, recheck. Quote
Tom King Posted March 3, 2016 Report Posted March 3, 2016 check on the Forestryforum. Lots of sawyers on there, including a number who built their own mill. Quote
