Builtin Fireplace and Cabinets - Doors torqued
I finished building my fireplace builtin and surround. I would like to know if anyone has a recommendation to keep the cabinet doors square after installation. In my shop everything was perfect but during installation the floor and walls of my new house torqued the cabinet just enough to mess the doors up. I have attached a photo of the final project as well as a link to my blog that shows a few more photos of the cabinets in my shop http://www.philipmillerfurniture.com/blog/2016/2/10/custom-builtins-part-1-of-3-the-cabinets I would greatly appreciate any advice on how not to do this again and a way to fix it now.
I see what you're talking about by blowing the picture up.
Did you build it all square and layer goint the surrounding walls not to be square?
Did you build then slide the units into the cubby? Did you have to force it in?
If it were me, I would consider shimming the right hinge to square the door to the opening with a consistent reveal. If the reveal isn't right, you may need to finesse the fit with a plane then re paint
Not to do this again:
Create the units slightly undersized for the space, shim and attach them to the structure/walls level/plumb and scribe the piece of trim that fits the surround.
Fix this now:
Either shim the hinge as the previous poster suggested, or plane just the edges of the doors to make them 'fit'...repainting would only be the edges if done carefully.
Brendon_t
The issue is that the walls and floor are not perfectly square. I slid in the cabinet into the wall and even though I gave myself room it ended up being a tight fit...I didn't have to force anything in.
tedfmcm
Thanks for the advice. I will see if I can shim the hinge, just makes me nervous, I think I will try and avoid planing the door as I would have to do that by hand as I don't currently have a planer.
52 minutes ago, MillerFurniture said:
Brendon_t
tedfmcm
I have this style of hinge on our face frame overlay doors without stiles and they are adjustable. But if you have a square door and an un-square opening, they won't do you much good.
 http://www.hardwaresource.com/hinges/cabinet-hinges/blum-european-hinges-grass-european-hinges/standard-european-style-hinges/generic-european-style-hinges/european-inset-hinges-generic/full-inset-110-degree-euro-hinges-plates
Looks to me like you need to shim the cabinets until they are square. Inset doors are a nightmare ! I charge 30 -40 % extra for inset door jobs . If the case and door are out of square it looks awful. The face of the cabinet needs to be perfectly plumb, level and square on all 4 inside corners.
Just shimming the hinges might not fix the problem.
thank you for the additional input. It is just frustrating to have it perfectly plum and square in the shop to have the space screw it all up.
I would have put a long level (or a level on a long strait edge) on the floor and both walls before I started. Check this twice...once where the front sits once where the back sits. You can then do the math and figure out with the bottom shimmed level the max width of the unit. Then you have a choice to either trim it out or scribe.
If the cabinet was square in the shop and now isn't. You did one of two, or possibly both wrong. Made it too big and it racked going in, or didn't shim it properly.
Otherwise, you did a nice job making it and hope you find a fix thats acceptable to you.
Philip, with everything in place as is, trim paint etc., if it were me, I would rebuild the doors with an overlay and European style hinges and be done with it. No more the wife having to listen to you beat yourself up. Otherwise, great looking wall.
I like this idea. If you go with Coops suggestion I would do all 3 doors hinged toward the outside walls on each side so the knobs all point toward the fire box. The odd number of doors leaves that one knob and hinge set out in left field and throws off any balance.
Over time the structure moves especially if there are significant changes in relative humidity so your inset doors will forever draw your eye to the inconsistent gaps and shadow lines.
I'd make new overlay doors just as the experts Coop, Janello and wdwerker recommended.
When I build inset casework I plan for plenty of room for shimming and leveling. I also make the face frames as stiff and square as possible. Usually use 5/4 stock unless the design allows wider FF stock. Domino or M&T joints in FF , kreg screws are not a ridgid enough joint. These issues are why I charge so much extra. Interior decorators want tiny but perfect gap around doors but don't want to pay for the time it takes.
The style looks good but few clients are willing to pay to do it right. Overlay shaker doors with the right trim at walls and in corners looks pretty close. Just don't leave any FF exposed if possible.
Just a question because in the near future i plan on making all the cabinets for my kitchen.
Would a viable option be to finish the carcass first install it and fit the doors after the fact? If I'm doing all the work myself i don't need doors installed for cabinets to be functional.
wdwerker - Thank you for this great advice. I should have done a bit more research on building face frames before building mine. At least it is in my house and most people don't even notice it because they are not woodworkers. The advice on the jointing method is great. Thanks.
If that picture is accurate, your framing below that floor is severely over span. Your joists are deflecting severely and need to be reevaluated. Check for missing supports below. (Follow their cabinet advice in any circumstance, but have the home evaluated.)
I seen that too but I think its just a camera that can't hadle wide lens shots. If it were truly that bad the face frames would have to be tapered like arrows.  Where's Collin when you need him?
