Dust collection piping help
I understand some people are concerned with static electricity when using PVC pipe for your ducting. What is the best material to use for your shop, PVC or something else?
The best material for me would be Nordfab ducting just for ease of application, but any type of heavy gauge metal ducting is going to be about equal as far as durability. Until I build the shop I want I will make due with pvc. There is no reason why pvc cannot be safely and effectively used as duct work.
your shop size has a lot to do with what you can get away with for ducting, steel is better and sometimes can be gotten used for a bargin price. i have PVC and some steel.
I use 4" PVC with metal gates.  Ground the gates or you will get shocked.
I'm yet to hear one credible accounting of not grounding pvc ducting leading to an explosion.  I've gotten a few good shocks but I'm not on a pace maker so ooh well.
Explosion is a nonissue, but as Brendon says, shocks can be annoying (but not dangerous). I've even gotten a good zap off a shop vac hose. The dryer the air is, the worse the problem.
I am not experienced enough to make a recommendation of one over the other.  I had PVC in my last shop, and am planning steel in the new shop.  My decision is purely economical though.  Last shop was all 4" with a single stage DC.  New shop is planning to be 6" with a 3+ HP cyclone setup.
When I priced it out, the steel is actually cheaper, since the lowest grade PVC I can get my hands on readily is Schedule 35.  I've read about folks getting good buys on schedule 20, but you have to luck into it.  Its sub-code, so not super easy to find.  PVC Piping is cheaper but the accessories are absurd for 6".  Steel is the opposite, with the piping being more per foot, but the accessories are substantially less.  I've also found steel is easier to "manipulate" when something isn't perfect.
I agree with Brendon and drzaius about the explosion hazard.  I have a relatively simple set up with 4" runs and I used home depot round metal duct (inexpensive) and PVC fittings from Wood craft put together with pop rivets and/or good duct tape. Works OK.  Be sure to support the line on each side of each blast gate it they are the plastic gates because if the line flexes it can affect the gate operation.
I have my Dust Collection System setup with SDR 35 piping. The main header is 6" and it necks down to 4" for each drop to a tool. I used SDR 35 partially because it was pretty cheap, but also the hub connections make it easier to perfect the setup as you build it, since it can turn. The 6"x6"x4" Y fittings were tremendously cheaper at a contractor supply. The 6" piping was ~ $2/ft, 4" piping was ~ $1/ft and the 6"x6"x4" Y fittings were $25 each. I had seen those fittings as expensive as $50 each. Good luck!
For the main run. I use the 6" heating and cooling round steel from Home Cheapo. They also have the reducers to 4" I used those to run the flex pipes to the machines. Blast gates are steel from Rockler.
-Ace-
-Ace-
Ace, what kind of DC unit do you have?  I planning to go with the 30 gauge HVAC steel (Typical Home Depot HVAC round), but one concern I had was that it might buckle under pressure.  I plan to use a 2-3 HP cyclone system rated around 10-15 max static pressure and ~1500 CFM.  I am guessing this is one of those internet fables (like DC explosions), but I can't seem to find any indication of what type of pressure these can handle.
-Ace-
Home Depot sells 26 gauge hvac 6" snap lock pipe. I'd go with that.
Sent from my 831C using Tapatalk
Ya know I will have to check on that. It's a Delta......I want to say its 1250 CFM something like that, I have had it for years.
I did use the 6" snap-lock pipe.
Thought never crossed my mind of the pipes collapsing. I guess if you're worried about that you can always leave a gate partially open down the line. But my set up, it's just not an issue.
-Ace-
Has anyone thought about or used Black Stove Pipe from Home Cheap'o?  I see they have 24 gage snap lock piping. Might be a better product for dust collection and it's just a few dollars more than the 26 gage.  Good idea or over kill?
http://www.homedepot.com/p/Master-Flow-6-in-x-24-in-Black-Stove-Pipe-BAP6X24/202191783
  • 26,009 Total Members
  • Joseph b Newest Member ·
