Any problems running cyclone briefly with no gates open?
I've had my cyclone for 2 years now and have never ran it with all the gates closed because I don't know if that's bad for it. When I'm done at a machine I'll go to the next and open the gate, back to other machine and close it, then back to next machine and get working. Obviously I can use the extra steps but it's also wasting some time. Are there any issues with having all the gates closed for 5-10 seconds? I don't know if it can put extra load on the motor?
Shoulda Googled before posting! Looks like all gates closed is actually easier on the motor than having them open and it's better to leave machine running with all closed instead of frequent starts (I knew about the frequent starts).
Running any sort of blower with no air to move has two effects. First, the motor will run faster than normal because there is no / less load on it, and second, many types of blower use the same air stream to cool the motor. However, a few seconds running that way is very unlikely to cause damage.
In the case of his cyclone it has a TEFC motor and can run all day with no load which as estesbubba found out is more of less what you have with the gates shut.
I would only worry about collapsing chintzy ductwork. I frequently leave two six inch drops open at once. I don't need to move a full 1000-1600cfm at my jointer or planer for perfect dust control. I'm sure 500-600cfm is adequate and since I routinely use those tools in conjunction, but their drops are frequently open.
If I take a minute between to set up a new cut, and several minutes when moving to a new tool, is it better to leave the DC running or to turn it off and on again?  It seems like the automatic systems like Grngate would be constantly turning the DC off and on.
You can set a 5 minutes delay before the DC is turned off.
My short answer would be no. Having said that I have no technical or scientific data to prove its ok...but I have done it on a regular basis for the last 12 years. I try not to leave it on with gates closed for long but certainly do it when switching machines and longer if I forget. Never had a problem that I am aware of. I have a hobby shop with Oneida dust gorilla with two trunk lines and drops to several machines.
  • Who's Online   3 Members, 0 Anonymous, 68 Guests (See full list)
    26,008
    Bob44
    Bob44
