Hi guys... im from Panama and im new here as well.. im struggling with something atm regarding my jointer.
SITUATION:
My grizzly jointer is 8" and im trying to flat a 12" wide board. Its going to be a cutting board so i need it to seat flat on a glass (my quality standard) and i have done it before with this same machine...
You might know how im trying to accomplish this but i will say it anyways.. will run de board in the 12" face through the jointer, of course there are 4" that wont be cut. i do this until that 8" seat flat on a glass top without any tilting... once i got this i run it in the planer over a 8" plywood base and then flip it over and get both sides parallel and flat! I am guessing anyone that can help me will understand this regardless my bad english/explanation
PROBLEM:
Today i started a new batch of boards and this method is just not working... boards are not getting flat on my glass when before i accomplished this with 2 or 3 passes in the jointer. I already checked my knives and tables to be well set up but my problem remains...
Not trying to make you feel sorry at all, but this is my only income atm and im not 50 years old of experience...im 26 still :D so i really would appreciate any advice... idk if somebody might had the same problem.
Thanks in advance guys.
1 minute ago, Eric. said:
Are you trying to run end grain cutting boards over your jointer?  Please for the love of god say no.
Hi Eric.  Im NOT running end grain cutting board. is a regular 12x18 hardwood board...
Okay, good.
There are a million variables that can cause problems on the jointer.  I don't have the strength to go through them again but the other guys might.  I'd start with checking for coplanarity...after making sure your blades aren't dull like AJ said.
FYI, you don't need to check flatness with a piece of glass...if your board lays flat on the outfeed table of the jointer after you joint it, it's flat.
My advice would be to rip those 12" boards into two 6" boards, joint, plane, and glue back into 12" board. I like to use bandsaw to rip rough boards plus it has a small kerf and once you mill and glue back up no one will notice.
Someone please correct me if I am wrong.  Most jointers have an infeed table extension or arm where the blade guard is mounted.  That arm moves with the infeed table.  Fine for your first pass.  But on subsequent passes the unplaned part of the board rides on this arm while the planed part of the board rides above the infeed table.  If I keep the pressure on the unplaned part and then on the outfedd table this technique works but since the arm and infeed table are one in the same it is possible for your board to tip if you put downward pressure on the part of the board that is still over the infeed table.  I have found that, in order to be accurate, I need to take one deeper pass rather than several thin passes.  The more warped the board the more the potential problems.
That's how my 6" General is, but it works for some jointers. I'll do 1 deep pass & then hand plane the remaining part before doing a second pass on the jointer.
I am having trouble visualizing this but it frankly does not sound good. In order to plane a board wider then the cutter knives I take off the guard completely. This is of course more dangerous but its the only way to do it with any kind of accuracy. That way your 8" section is properly riding on both the infeed and outfeed tables.
I've used this method before.  It can be a little nerve wracking with the guard removed, but it works.
I also suggest re-checking the alighment of tables and sharpness of knives.  Joint a narrower board to see if the issue is the jointer or something wth the wider board.
One possibility is that the board has a curve to it.  so as you run it along the fence, it moves or shifts laterally (left to right).  This might cause some of the unjointed face to slide onto or off of the jointer bed.  Having that unjointed face slip onto the bed will screw it up.
When you say it's not working....can you describe what you're seeing with the board?  is it just getting thinner and thinner on one edge (like a wedge)? is it just taking more material off in the same location? is it not taking ANY material off?  does the board also have a cup, or a bow to it?
  • Who's Online   4 Members, 0 Anonymous, 54 Guests (See full list)
    26,008
    Bob44
    Bob44
