Coping crown and base with a grinder
Does anyone else do this? Even on finer woods I seem to be able to just tear most of the waste out fast with a 40 grit flap wheel.  I keep getting strange looks around here though
I have done this many times, mostly with MDF base.  I use an angle grinder and a thin disc (best to do this outdoors - makes an awful mess).
I truly don't understand why you would do this.  Lay off the weed yo.
I do it with a grinder too (and jigsaw). 2 diablo sanding discs back to back without the plastic backer thing so it has a little give. Works amazing. My new cordless grinder has made it even more practical.
That said i only cope where i have to (base landing on cabinets or the face of door casings, crown hitting cabinet crown, etc) Corners all get mitered.
Sent from my SAMSUNG-SM-G890A using Tapatalk
I cope all corners when running baseboard.  I used to mitre, but its a pain to get the angles right every time.  Coping is so much faster, and the results are perfect.
That's what coping saws are for.  Other than a coping saw, on some crown molding, I will also use a jewelers saw on the tight turns if the wood is not going to be painted, and you want it to fit perfectly.
I have heard of the flap sander trick.But like anything in life. Once you do it a time or two with a coping saw, you get pretty good at it. I'm sure using a flap sander has a learning curve as well and you still need to tweak by hand sanding to get the finish profile. So what is the gain?
-Ace-
I remember several years ago FHB posted this "technique" as a video on April Fool's Day. I never thought anyone would actually try it.
And WTH is this posted in "The  Wood" forum anyway?
Years ago, I was called to look at a house not too far from where we live to see if I could figure out some weird electrical problems they were having.  There were two young redneck carpenters working on trimming out the inside of the house.  One was cussing because every time he nailed an inside corner of baseboard that had been mitered, it would open up the joint....duhhhh.
I went to the truck and came back with a coping saw.  I showed them how to miter cut only the second side, and cope the waste away.  I'll never forget their reaction.
They both got down on their hands and knees with their faces as close as possible to the joint.  One of them turned around, with his mouth hanging open, and said, "DAYAMM!!  It looks like it's done growed together!!!!"
I said, "Yeah, that's the way it's supposed to look."
To each his own. I have my tricks like anyone else. Ive torn out so many badly coped base jobs. It seems like the method used to be... sloppily cope the base, squirt caulking all over the cut end, smash joint together, wipe. Good copes look great but i see bad ones far more often around here.
Havent used a coping saw on a job in years. Aint nobody got time for that!
10 hours ago, sheperd80 said:
We deal with the real bad inside corners during prep (which is still a problem if youre coping), PL dot in the bottom corner as a shim and nail the top only (we PL all our baseboard to the wall).
What is "PL?"
Its a really thick construction adhesive. I think it stands for Pro Line.
Here's my question about installing baseboard...
Do y'all pros just nail to the bottom plate, or do you try to nail into each stud as well?  If it's the former, how do you keep the top of the baseboard from kicking out because it's only nailed at the bottom?  I've had that issue in the past.
I keep a string of 3/8 magnetic balls in a brass tube. They stick to the drywall screw heads and give me quick visual of where each stud is. Inside corners should be coped. Years from now if the wood dries out & shrinks any gap is facing along the baseboard instead of straight towards the middle of the room. Same goes for crown.
Paint grade trim is for carpenters. I do stain grade trim, usually to match my cabinets so it's all finished in the shop. Neat copes ,tight glued miters and a few nails & some color putty is the way to do it.
I always nailed into each stud, but if there is going to be a separate base cap, the top nail is toenailed down from the top where the cap will cover. A base cap not only looks more elegant, and makes it easier to use a taller baseboard, but by nailing this way, and installing the cap with 23 ga. pins, it eliminates puttying holes for painting.  If there is going to be a shoe molding, the bottom nail goes behind that, and the shoe is put on wiht 23 ga. pins.  A base cap also means the only coping to do is the cap.  The premade, one piece base has always looked nothing but cheap to me.  I never had any desire for the houses that I built, and sold to have anything to do with "cheap".
I never followed anyone else, and no one follows me, so every detail of each step is planned for the next one, including easiest, and best quality finish.
No way that a grinder is faster than a coping saw in good hands.  Cut it right to start with, and there is no need for anything else.   The only place I miter base is outside corners, and those are marked with a preacher, and cut with a handsaw-fit perfectly the first time, and no trips back and forth to a miter saw.  Base to casing is also marked with a preacher, cut with a handsaw, and fits perfectly first shot, with no caulking needed.
I use the Locktite PL construction adhesive for some things, but one trouble with it is that it expands ever so slightly as it drys.  The 8X expands more than the lesser X's.   I do use Power Grab a lot sometimes.
This coffered ceiling has no exposed nails to have to fill because it's almost completely put together with PowerGrab.  Raised panel tapered edges are separate pieces. PG shrinks a little as it dries, so it will pull something together tighter, if anything.  The inside crown corners were mitered because they were well contained inside the coffer MDF boxes, so this is ibe case where mitering an inside corner is okay, with no chance for the joint to open up like on a sheetrock wall.
Nothing I ever did, or do, considers fast and cheap as factors.  Efficient, yes, fast and cheap, no thanks.
Can you give us a pic of a completed baseboard run?  I am interested to see your approach!
I am not arguing that mitered or coping is superior, just different ways to do the job.  I am never in a hurry, as its a hobby for me.  So i take the time I need to cut, cope, and then grind away the material I need for a nice job.
I agree that there are a lot of terrible coping joints out there, as well terrible miter joint.  It seems that builders think they can flawlessly hide any gap of 1/4" or less with caulk.
I too use a magnet to find studs. On long runs i usually just find 1 then eyeball the layout on the rest and have pretty decent accuracy that way. If theres a miss ill drop back with the stud finder again.
And same as tom said, if theres a base cap and shoe, the tall flat base doesnt show any nails at all and the cap n shoe only show micro pins. Most houses i do have these 3 piece setups around 10" tall or so.
woodwerker you got a picture or source of that tube full of magnets we could see?
No one asked but heres some pics anyway because this recent project has just been insane. So much challenging woodwork. We have to make these crazy ideas work, usually in the wrong order because the contractor is always go go go dont wait till the right time do it now. Heres just a few examples.
Some 3 piece base. Each piece of shoe is scribed to the horribly uneven floor throughout 10k feet of house.
Flex base. I know, the joint is visible. All i can say is its damn good for how bad the walls and floor are.
Base made out of a few different mouldings and 8/4 alder. Nevermind the ugly stain job. Im hard at work to break this perception here that stained alder is "as good as walnut."
1 of several coffered ceilings.
Heres a better pic of the theater. So much cool woodwork tainted by stain. I cry a little each time i see it.
Cope chisel textured crown... i dare you! Lol
That is very nice craftsmanship, sheperd...but I gotta agree with Mike...gaudy as all get-out.  Your clients have too much money and not enough taste.
I prefer a quote of my grandmothers, admonishing a relative for her gaudy house "You've all of this taste, and none of it is good"
Thanks and i agree completely. But i gotta give the designer some credit. He does over the top gaudy better than the others ive worked with. In person its stunning but most who see it agree "beautiful but not my style". This designer is very ecclectic and the owner wanted alot of Morroccan styling.
These people entertain alot of important folks so its a "look-at-my-money" house.
I like looking at this woodworking allot.  I must say my stile is old farmhouse. :)
Pug, sorry, I haven't done any new construction since 2007.  Even then, I just put a sign out front to sell the house, and never took many pictures.  Here on the lake, there is a lot of traffic in the Spring, even through years when the economy was supposed to be bad.  I never used a realtor, never put a price on one until I was ready to sell it, and never kept one for longer than 2 weeks once I put a price on it.
 In 2007, it looked like to me that all the other builders had gotten smarter than me, so I went to work on very old houses full time.  I wasn't worried about selling a house-just worried about where the prices were going.  I could build a house for half of what I could sell it for.  I started one in the Fall, finished the inside in the Winter, trimmed up the outside in the Spring, sold it, and played all Summer.  That was building start to finish with my hands, and not a telephone.  I did that for 33 years, but had gotten a bit bored with it by then anyway.
Shepherd, that's some nice workmanship.   I probably would have given that molding a go with a coping saw.  If the inside corners are good, there is no reason not to simply miter.  I never worked for anyone else though, so would have had no reason to build something like that.
The coffered ceiling I posted earlier is in our TV room, so no comparison to that theater room.  I'm more comfortable living with simple.
