Eric. Posted May 20, 2017 Report Posted May 20, 2017 20 minutes ago, wdwerker said: I was told that Minwax pre stain is all the basic ingredients of their stain but colorless. Then what's the point?...out of curiosity... Quote
Guest Posted May 20, 2017 Report Posted May 20, 2017 6 minutes ago, Eric. said: Then what's the point?...out of curiosity... it partially seals the wood to prevent blotch. Personally I don't think it is necessary on oak... but it might help prevent too much pigment from getting into the pores and cathedral grain. Quote
wdwerker Posted May 20, 2017 Report Posted May 20, 2017 The pre-stain soaks into the thirstiest grain which evens out the absorption of the stain color. Minwax stain base has resins in it. If you read the label it says not to wait too long after pre-staining before applying the stain. Quote
Eric. Posted May 20, 2017 Report Posted May 20, 2017 Got it. Y'all know how much stain experience I have under my belt. 1 Quote
Steve B Anderson Posted May 21, 2017 Author Report Posted May 21, 2017 Thanks everyone for the great comments. I plan in the future to use some better wood in my projects that I will not color the wood. For now I'm going cheap until I build up my skill level. It was the pre-stain and the stain that bleed so bad. Neither were applied in heavy coats nor a long soak time, about one minute. The seal coat with shellac did not bleed. Quote
Eric. Posted May 21, 2017 Report Posted May 21, 2017 Nothing wrong with oak if you like A&C/Mission/Craftsman style furniture, but white oak is superior to red in every imaginable way (aside from cost...which is a negligible difference...at least flatsawn). Better color, better texture, better fleck when quartersawn, better smell (still not great but I'll take burnt popcorn over dirty underwear any day). White is slightly harder than red but I find it still works better due to the more splintery nature of red. Finished end grain looks better, too. Quote
Steve B Anderson Posted May 21, 2017 Author Report Posted May 21, 2017 I am planning on using white oak on my next project. Mission style end table with two drawers, the drawers will be another first for me. Quote
Steve B Anderson Posted May 23, 2017 Author Report Posted May 23, 2017 Glue Up Time Finally finished up enough components to glue up the sides. I did one more dry assembly just to make sure everything fit together properly. I used an acid brush to apply Titebond III into the mortise and on the tenons. I wish the pics were better but I'm trying to do this by myself. Assembled the components and clamped, wiping any squeeze out with a damp paper towel. I had very little squeeze out probably due to that I left clearance on the face cheek and made the edge cheek snug. I left the assembly in the clamps over night. 1 Quote
Steve B Anderson Posted May 23, 2017 Author Report Posted May 23, 2017 Removed the clamps from the side assembly today and to my surprise, nothing fell apart, joints were tight with no cracks, and the floating panel was still floating. I did put the cathedrals pointing up as TOIDS suggested here and I do think it looks better this way. Thanks for the great tip TOIDS. Bottom Joint Top Joint If you notice, the location of the top rail is about 1/32 below the top of the leg. This is an error on my part but not sure where it happened. I cut the mortise without stops due to the length of the legs so each mortise was slightly different in length. I probably chiseled a little too much off of the top edge cheek of the tenon. Something I'll have to work on in the future. 1 Quote
RichardA Posted May 23, 2017 Report Posted May 23, 2017 On 5/19/2017 at 10:05 PM, Steve B Anderson said: Tenons done now its time for the floating panel slots. This is where my first mistake happens, not a bad one but still a mistake. I had milled the thickness of the wood heavy planning on sanding to size. I did not take this into account when setting the location of the slots. I set my fence at a 1/4" and made sure I put the outer showing faces against the fence so I would have a constant reveal on the outside of the piece. Well I accomplished that but the slots were not centered on the boards as planned. Lesson learned. More to come It's only a mistake, if it can't be corrected, then it's firewood. We all, everydamnone of us make mistakes, the trick is making it work, or hide. 1 Quote
RichardA Posted May 23, 2017 Report Posted May 23, 2017 On 5/19/2017 at 10:54 PM, Steve B Anderson said: Finishing Time Everything fits together so on to the finishing chores. I call it a chore because it is my least favorite process. Waiting on stain/dye and top coat to dry is about as exciting as watching grass grow. But I am happy that things are now in the final stages and are getting closer to final glue up. That's when BEER comes into play! Quote
RichardA Posted May 23, 2017 Report Posted May 23, 2017 On 5/20/2017 at 11:04 AM, Eric. said: Then what's the point?...out of curiosity... $$$$$$$$$$$$$$ 1 Quote
RichardA Posted May 23, 2017 Report Posted May 23, 2017 2 hours ago, Steve B Anderson said: Removed the clamps from the side assembly today and to my surprise, nothing fell apart, joints were tight with no cracks, and the floating panel was still floating. I did put the cathedrals pointing up as TOIDS suggested here and I do think it looks better this way. Thanks for the great tip TOIDS. Bottom Joint Top Joint If you notice, the location of the top rail is about 1/32 below the top of the leg. This is an error on my part but not sure where it happened. I cut the mortise without stops due to the length of the legs so each mortise was slightly different in length. I probably chiseled a little too much off of the top edge cheek of the tenon. Something I'll have to work on in the future. Build yourself a longer fence for the router table, then adding stops becomes easy, and makes accuracy consistant. 1 Quote
