  • 3 weeks later...
Some initial thoughts on the woodpecker drill press table.
I like the insert. Finger holes are convenient. There are 4 screws under for levelers. I may change the screws to a bigger diameter. Not enough resistance. 1/2" mdf is recommended by woodpecker. I like the idea but I have none. So I used 1/2" ply. I ripped a piece around 2 ft. long slightly wider than needed. Once I found the perfect dimension on the table saw I was set. Using the same set up I cross cut for a perfect fit. With the set up I cut several.
I have not used the fence or the hold downs but they look adequate. The metal rails are bolted from below. Important as the hold downs are attached to the rails. If it was screwed instead of bolted the hold downs could pull it up.
    26,008
    Bob44
    Bob44
