Michael Fortune #1 Chair Build
With my other projects out of the way its time to finish this chair. I cleaned up the finish area after my last project it was a bit of a mess. Then I raised the grain for the first time, I will do this twice with sanding after each time so that when I start the finish process it does not raise the grain. I do not want to sand again until the top coat.
The ebonizing mix is still good but I will need to make a new batch of bark tan. Thought it best to try them out since its been a while since they were made. Glad I did given the results I found tonight on a test piece.
Hope to have the chair ebonized on Saturday.
  • Replies 139
  • Views 30k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Well it was a busy summer at work, and in my personal life, but I did get a few things done and just returned from my second week at MASW working on the Michael Fortune #1 chair. To date I have about
  • Well fellow woodworkers this one is a wrap!! After nearly 4 years and over 350 hours my attempt at a Michael Fortune #1 chair is complete. Thanks for all your support and for following along on this l
  • This week I worked on the under side of the arms, crest rail shaping, and also fit the first back slat. Shaping the back of the arm with rasps. First I mark the part with marker and then start sh
Posted Images
On 2/13/2025 at 10:48 PM, fcschoenthal said:
Glad you're able to get back to it. We've been waiting a long time for this.
What do you mean its only going on 4 years since I started :P
Lol having said that it will be complete in Feb 2025. This has definitely been a challenging project I figure I have about 250 hrs into it but it should have never taken 4 years :).
Second grain raising is complete and once dry I will sand at 320 for the last time
As a reminder I am following the Brian Boggs process for ebonizing this chair (easily found online)
As discussed my Iron Vinegar solution is fine but I need to mix up a new batch of bark tea so started there first. Just mix a heaping teaspoon of Bark Tan into hot water and stir.
With that complete I taped off the seat and grabbed a piece of foam for the chair to sit on as it was to big for my turntable by about an inch
Then I brushed on a liberal coat of bark tan making sure to hit every spot on the chair.
Then I waited until the wood was dry but still damp, blotting any pooled spots with paper towel. With that done it was time to apply the Iron vinegar mixture. Again this is done with a  clean brush I also use different containers and pour into smaller containers to brush out of. You do not want to contaminate the mixtures and you want the reaction to take place in the wood fibers which is why you want the chair damp but not visibly wet its also why you use two different containers, brushes, etc. The minute the Iron solution touches the chair its presto black :)
I will wait a few hours and then take a cotton t shirt and wipe any left over iron deposits off prior to a final a rinse coat of bark tea before a final water rinse.
And here it is with the final two rinses one with bark tea and the other with plain water. I will  let this set a day and then start applying the top coats.
I can tell you the water provided a taste of what's to come and I think I am going to be very happy with the final finish. I also need to finish the seat but that will take a bit as we are heading to Chicago Friday to see our kids and their new home. Still on track to have it 100% complete this month though.
So after rinsing and leaving the chair for a day I noticed a problem. the back of the left arm as you look at the chair did not get the proper treatment of ebonizing and was lighter then the rest of the chair. I wrestled with this for over a day I mean at this point I probably have north of 300 hours on this chair do I really want to muck it up? Ultimately my OCD got the best of me and using Boggs advice I took just that spot down to bare wood with the hopes I could repeat the process as suggested.
To say I was nervous would be a monumental understatement but in the end I was able to fix the area. Once this dries I'll be able to buff it out and proceed with the top coats.
Had I been using a raking light I'm pretty sure I could have identified this much earlier, lesson learned!
Great save. This thing is beautiful!
So today I started applying the oil finish
Its hard to tell in the full size shots but as you can see in the close ups the wood grain radiates through the finish and looks really nice if I do say so my self :)
Also knocked out a pair of bow bars that are bigger than the seat radius. This will allow me to get the cloth tighter and thus eliminate wrinkles when removed.
It looks like yer taking chair building to the next level. The lines on that chair are fantastic. And...the close up pics showing the grain add a nice touch. The far back pics don't do it justice. Can't wait to see it with the seat all done.
After seeing the chair coming together, I had to google Michael Fortune. An article in FWW (Oct 2012) said that he had made over 300 of them since the first in 1979 and used 38 separate jigs. The picture they showed was Madagascar Ebony, with pure silver and mother-of-pearl inlays. Wonder how many more he's made in the last 12 years?
Well it looks like another deadline will be missed...Wanted to finish it this month but the finish is taking longer to dry between coats then I expected. Oh well should still have it complete by Saturday :)
In the mean time I did finish the upholstered cushion tonight
It turned out decent and I like the way it looks in the chair but you all are going to have to wait until final pics for that :P
WOW! This is going to be amazing. Is this for your house or for a fortunate recipient?
Thanks Coop! This one will stay with us :)
Next to an armoire I made nearly 25 years ago definitely the most involved piece I have made.
I think you need to make them dining chairs and make another 7 of them.
That is never going to happen LOL, I would like to make one more but not sure it will happen either :)
Next up on my list are a hanging tool cabinet (already begun), need to do some repair work on my wife's pool house, replace the decking on our decks, build an outdoor kitchen, and hopefully this fall I can start on a game table for our basement but we shall see.
Got the seat bottom dust cover installed today and applied the second to last coat of finish, just one more and this chair will finally be a wrap! Should have final pics up this weekend.
On 2/27/2025 at 10:31 PM, wtnhighlander said:
Paul, are those pleats I see in the dust cover, or the slots in the plywood showing through??
Those are the slots showing through.
The "anti-whoopie" slots
The slots help the seat base flex but you are correct the anti- woopie holes are in line with those slots to allow air to pass freely :)
Well fellow woodworkers this one is a wrap!! After nearly 4 years and over 350 hours my attempt at a Michael Fortune #1 chair is complete. Thanks for all your support and for following along on this long ride :)
