Michael Fortune #1 Chair Build
Even though the seat is yet to come, it looks like it would be comfortable to sit in. And mentally comfortable to be enveloped by walnut.
  • Replies 139
  • Views 30k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Well it was a busy summer at work, and in my personal life, but I did get a few things done and just returned from my second week at MASW working on the Michael Fortune #1 chair. To date I have about
  • Well fellow woodworkers this one is a wrap!! After nearly 4 years and over 350 hours my attempt at a Michael Fortune #1 chair is complete. Thanks for all your support and for following along on this l
  • This week I worked on the under side of the arms, crest rail shaping, and also fit the first back slat. Shaping the back of the arm with rasps. First I mark the part with marker and then start sh
Posted Images
To be honest I couldn't wait and set the seat blank on it the other day and tried it out, I think it will be great the curved back slats provide nice lumbar support.
  • 2 years later...
...well its been a while but time to bring this one across the finish line.
Did some final blending with a rasp
And final sanding before finish begins
I was going to comment on how neat, I guess you would call it, the arm rest, ties into the front and back legs but then I feel like I would be slighting the beautiful back slats and the seat so I’ll just say the whole darn thing is awesome! Great job!
Today I knocked out the seat cushion platform. First I needed a pattern so I grabbed some paper and taped enough sheets together to fit. Then I taped the blank to the chair and used the side of a pencil to get the outline.
Now lets cut it out and see how it looks. I need about an 1/8" gap for the top foam and seat material all the way around so once I got it in there I took a mechanical pencil and used the chair sides to get my 1/8" line on the template.
With the template done I transferred it to the 1/4" Baltic birch seat platform. I also added some lines I will use to route some 3/16" relief cuts into the platform to provide some flex to the BB.
Since I was using a trim router with no plunge I drilled 3/16" holes at both ends to insert the router bit into. then used a board as a straight edge to cut the slots.
With that done I cut the shape at the BS and then cleaned it up at the edge sander and give it a test fit. Looks good if I do say so myself :). I need about a 1/8" gap between the platform and the seat all the way around for the foam/fabric.
Finally I drilled holes for T-Nuts to hold the cushion to the chair. I will pound them in once the holes are transferred to the chair. Doing this allows you to remove the cushion with two screws should the need ever arise... for say should your wife decides she wants a different pattern cloth.
I would have never thought about the relief cuts. Obviously those are important?
Good idea on the t-nuts.
On 12/30/2024 at 8:07 PM, wtnhighlander said:
The reliefcuts allow air to escape as the cushion is compressed, as well as allowing the seat panel to flex, correct?
Correct. No woppie cushions here :D
...and also helps provide some flex in the seat platform for comfort and the ability to conform to the chair since the seat is not flat.
1/4" plywood seems at first a thin support, but 1/2" (or even 3/8") isn't going to flex much.
I'm just curious, any idea what the weight limit on a chair like this would be?
Mark I am absolutely comfortable that if you can fit your rump between the arms the seat will hold you :D
I'm 187 lbs and you could easily double that without issue but I think if you did the arms would be digging into your sides and be uncomfortable.
Turning out nice. My daughter never understood why the slats went down so far.
First up today was to drill the holes from the platform through the seat rim in the chair
Next I started adding the foam to the platform. First was a layer of 1/4" high density foam applied with 3M 77. FWIW you want to use something ( I used the same construction paper I use in my spray room) under this as it it sticky as heck and gets everywhere.
Then I trimmed it with a sharp knife
I cut some holes so we don't have a large whoopie cushion as discussed earlier. I used a cutter I have for Kaizen foam just becuase its what I had but as long as you cut a few holes you are good regardless of how you cut them.
Next up I cut some strips of high density foam at a 45 on the BS, this worked very well.
I glued them to the edge of the 1/4 foam then cleaned it up with an electric carving knife, again it worked great. It's my understanding that the 45 smooths the transition from the HD foam on the edge to the medium density in the center to insure you do not have an abrupt change that could be felt.
Next up I cut the MD foam 3/8" larger on all sides and then glued it in. Starting with the corners and finishing in the center.
Then using some 100 grit sandpaper I eased the top edge all the way around.
The final 1/4" light duty foam covers the whole platform and is glued only to the sides. Then cut with a sharp knife.
With the foam complete now it was time to add the muslin cover. I cut it oversized about 5" on all sides so I have material to stretch the fabric around the platform.
Here is a shot to show where a staple will need to be pulled and re applied to smooth the side. You can see the material was not pulled tight on the last stapple. I am using 1/4" staples and a pneumatic stapple gun but a hand stapple gun will work as well. FWIW if you need to pull stapples I find a small screwdriver works better than an office stapple puller as they tend to wreck the fabric.
So not terrible for my first try...
...but not liking this. I will need to pull the cover and add some foam so the corners look better. If that doesn't work Ill have to remake the platform and start over :( FWIW its just the corner once the upholstery fabric is added the sides will be good.
While that would be a bummer its only a few hours work and $20 in materials.
Back to the spectator chairs so I can get them out of the spray room and move this in :)
I had an uncle in the uphostelry business, many moons ago. They used a tool like this for adjusting such things:
https://www.hobbylobby.com/art-supplies/painting-canvas-art-surfaces/blank-canvas/fredrix-canvas-pliers/p/6449?gad_source=1&gclid=Cj0KCQiAyc67BhDSARIsAM95QzusTvDQosXW7MD51pdre4G3Z6lvKWAA3iLKrpsooavw4B-I12q8yhcaAoPFEALw_wcB
Dad uses the same sort of tool to stretch his painting canvasses.
The fabric you are showing is probably light enough that these would be of little benefit, but for heavier materials, they can be a life saver.
Thank you for journaling. Something I want to do someday (if it doesn't arise as a household to-do first).
Ok time to see if I can fix the corner gaps or if I will need to start over...
So after jacking around for about 45 min ....
Here is one of the four corners I worked on. It was nearly impossible to get a good result...at least for me
I decided it would be easier, quicker, and a better result to just start over
So I made a new platform in about 30 min :)
Next up I will add foam to the new platform.
That sucks. Sometimes you just have to start over as it wastes less time. The chair looks fantastic.
I agree it was pretty obvious I could not get the result I wanted so take the time to do it right and toss maybe $20 in material :)
At this point I'm 4 years in on this thing so a couple hours is not a big deal LOL
I was thinking it would be fun to have house guest's sit in a beautiful chair just to have it turn into the most expensive whoopee cushion they had ever seen.
Started working on the final finish prep tonight. Sanding with 120 and 150 grits. When I apply the finish layers I will go to 220 and 320 before final top coats.
The last step before finish was to cut the legs flush. I started by marking them at the TS
Then with the chair in a vise using a pull saw I cut them off
Finally I grabbed a rasp and added a small chamfer to each one.
...and with that let the finishing begin...well probably not until Sunday as I have another project in there I am finishing up.
Oh I also cut new foam for the replacement seat at the bandsaw
Finished the new cushion today. Went form these unsightly gaps
To this...much better just need to work out a few wrinkles / depressions with some steam. I will add the top layer of pattern fabric once the chair is complete.
That's a really nice looking chair Paul. I don't remember if you had posted what the pattern fabric will look like, but I'm sure that it will be impressive.
Very nice! I have yet to take on a chair but find all the chair projects on this forum inspirational.
