Ideas for cabinet for air compressor and planer
I've got these 2 tools and I am thinking of stacking them into the same rolling cabinet/frame with the planer on top and air compressor on bottom. I definitely want my planer at arm level  so that is the main reason for this, but having the air compressor in the same cabinet is just a bonus to save space. The best idea I could think of is just a simple frame of construction pine joined with dowels or screws which would make it about 21 inches wide by 22 inches deep. I thought for sure there would be some other opinions so I'm asking here.
You might consider using plywood on the side(s) that could be closed - will add stability.  Be sure to bolt the compressor down so it does not walk on you.
Just looking at the tools, I would orient them 90* to each other, so the extended infeed & outfeed tables of the planer don't restrict your access to the compressor controls. And as Ronn says, closed sides offer increased strength, but just closing 2 of the sides will go a long way.
I've found a couple short (4-6") 45* braces on a classic 2x4 stand makes it rock solid without closing the sides. Wouldn't lose any usable height either for that little compressor. I have my planer on an old plywood flip-top (which no longer flips) and I added corner bracing to get it up to match its 2x4 cousin.
BTW I have that same compressor and absolutely love it.
Can you take a pic of your 2x4 stand so I can see what you mean? I just got this air compressor, too and then I realized the power switch is on the side so I can't enclose it completely.
You need reasonable air flow around the compressor to dissipate heat.  So i wouldn't fully enclose it.  I like the 90* orientation wtnhighlander suggested.  It will also help to keep the air hose out of conflict with the planner.  Consider, too, how you will access the drain valve.  I set my pancake on a square of rubber mat and this dampened vibration a little, but mine sits on the concrete floor.  Might not do much on a wooden base.
  • 26,009 Total Members
  • Joseph b Newest Member ·
