Hammer5573 Posted January 19 Report Share Posted January 19 Does anyone know of any type of “wood glaze” that can be applied as a filler to eliminate small scratches and dents prior to applying a finish..? Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted January 19 Report Share Posted January 19 That depends. Clear finish, or opaque? There are grain filler products designed to provide a smooth surface under clear finishes. Aquacoat comes to mind, and I think Crystalac may be another. These will not hide scratches, though, only fill them so they don't telegraph through the finish. For opaque finishes, as in "paint", Bondo works magnificently. Buy their "wood putty" product if you prefer, but as far as I can tell during use, it is the same product as their auto body filler. I've used both, and can't tell a difference in the results. Quote Link to comment Share on other sites More sharing options...
JohnG Posted January 19 Report Share Posted January 19 On 1/19/2023 at 12:50 PM, wtnhighlander said: Buy their "wood putty" product if you prefer, but as far as I can tell during use, it is the same product as their auto body filler. I've used both, and can't tell a difference in the results A knowledgeable person told me that they are indeed the same. 1 Quote Link to comment Share on other sites More sharing options...
Mark J Posted January 20 Report Share Posted January 20 What caused the scratches and dings? How bad? Quote Link to comment Share on other sites More sharing options...
Wimayo Posted January 21 Report Share Posted January 21 If the scratches and scrapes are indeed minor, probably a light sanding to give the original finish some tooth and then a new coat or two of finish will do the job. If you don't know what the original finish is then apply a coat of dewaxed shellac and then a couple of coats of new finish. Quote Link to comment Share on other sites More sharing options...
krtwood Posted January 21 Report Share Posted January 21 Small dents can often be repaired, or at least minimized, by wetting the wood. Some people wet it and then use an iron to steam it or you can just keep it wet for a while and then let it dry out thoroughly. Quote Link to comment Share on other sites More sharing options...
gee-dub Posted January 21 Report Share Posted January 21 I'll take a whack at this. I assume we are talking about damage caused during assembly and prior to finishing. Towels, rag-rugs or old pieces of carpet on working surfaces can help prevent the damage in the first place as can pre-finishing certain parts. As stated, for mild scratches a card scraper or additional sanding should do the trick. Deep scratches are another matter and would need to have enough material removed to eliminate them if translucent finishes are to be used. For heavy pigmented stains and paint that will cover repairs . . . I like the Bondo idea. I have pulled pretty severe accidental dents out of material with the damp paper towel and clothes iron trick. The main difference being that dents contain bent, but not broken, wood fibers. These dents become invisible with moisture and heat. Torn or broken fibers will absorb finishes differently than the whole fibers around them and so become obvious. 1 Quote Link to comment Share on other sites More sharing options...
Hammer5573 Posted January 21 Author Report Share Posted January 21 I appreciate all of the informative responses; however, I don’t think that I explained the situation completely. Im making a Newport Blockfront cabinet using cherry. The cabinet has curved drawer fronts and requires extensive sanding and the use of a spokeshave. The scratches and dents that I’m referring to are very small ( less that 3/16” long and the dents are less than 1/32” deep). This may not seem like much; however, when trying to remove them it requires extensive sanding which then changes the contour of the curved surfaces. I’ve done auto-body work on the past and would simply glaze over the area with Bondo. I was hoping that there was a product for wood out there which served the same purpose. Quote Link to comment Share on other sites More sharing options...
Wimayo Posted January 21 Report Share Posted January 21 As mentioned above, put a drop of water on the dent and/or scratch and keep repeating enough to keep it wet for a while. Let it dry and the wood will likely swell removing the dent or scratch. Sand and finish. If that doesn't work, apply enough clear epoxy to fill them. Sand smooth. The epoxy will be thin enough to look like your clear finish and be virtually invisible. I've done this numerous times to hide small chip-outs. Works great. If you plan to stain it, gel stain will work better over the epoxy "patches". 2 Quote Link to comment Share on other sites More sharing options...
Hammer5573 Posted January 23 Author Report Share Posted January 23 " I have pulled pretty severe accidental dents out of material with the damp paper towel and clothes iron trick." I did the water-hot iron trick and it worked better than I expected. Thanks Gee-Dub..! 2 Quote Link to comment Share on other sites More sharing options...
