Hammer5573 Posted February 5, 2024 Report Posted February 5, 2024 I’m working on a project made of poplar and I’m planning to stain it (cherry). I would like to apply dewaxed shellac as a wood sealer, followed by a coat of stain, followed by additional coats of (waxed) shellac as a finish. Is it possible to apply wood stain over dewaxed shellac? Quote
Chet Posted February 5, 2024 Report Posted February 5, 2024 I am not sure but I would think that the shellac would keep your stain from penetrating. I would suggest trying it out on a scrap piece of poplar. You might also mixing you own shellac flacks and using it to get you color instead of the stain. 1 Quote
Popular Post Ronn W Posted February 5, 2024 Popular Post Report Posted February 5, 2024 It is my understanding that you can stain over one coat of dewaxed shellac but the stain will not penetrate as much and so the coverage will not be as good. I agree - you have to try it on a practice piece. To paraphrase a friend the restores furniture -- The appearance changes with every step of the finishing process. So the best practice pieces are the ones whare you go through the entire process from sanding to finished coat to be sure you know what it will look like. 3 Quote
wtnhighlander Posted February 6, 2024 Report Posted February 6, 2024 A 'wash coat' of thinned shellac is fairly common practice to limit stain penetration on blotch-prone species. Just be aware that you may need to apply multiple coats of stain to achieve a dark color. And beware that the green tint often seen in poplar will offset the stain color. Maybe some of the more experienced finishers can suggest a tint to neutralize it so that the cherry stain looks more like cherry. I'm not that great with colors. Quote
Hammer5573 Posted February 6, 2024 Author Report Posted February 6, 2024 On 2/5/2024 at 7:46 PM, wtnhighlander said: A 'wash coat' of thinned shellac is fairly common practice to limit stain penetration on blotch-prone species. Will a wash coat of shellac eliminate any glue spots that I may have produced..? 1 Quote
wtnhighlander Posted February 7, 2024 Report Posted February 7, 2024 I doubt adding shellac is going to improve the glue smear situation, other than to prevent the glue spots from being quite so obvious after one coat of stain. You might experiment with gel stains. They tend to leave more pigment right on the surface. Hides the boo-boos, but obscures the wood grain, too. Always a comprimise. 1 Quote
Wimayo Posted February 8, 2024 Report Posted February 8, 2024 On 2/6/2024 at 7:47 AM, Hammer5573 said: Will a wash coat of shellac eliminate any glue spots that I may have produced..? No. You've got to remove the glue. Sanding and/or scraping probably the best way. For blotch prevention, a coat of thinned shellac is what I read about the most. However, I have had good results using a single application of danish oil. I apply jell stain after the danish oil cures about 8 hours. It works for me. Quote
