On 6/25/2024 at 1:46 PM, drzaius said:
Get a dado set without the full body chippers, which is what SawStop recommends.
  @drzaius
IMG_20240625_143042370_HDR.thumb.jpg.a52a0ff55758b66b29698cf03684cddb.jpgWhen you say "without full body chippers" - do you mean like this?
This is what i had previously and just rebought.
@Ron Swanson Jr., in your previous where you stated “the roof caved in” your first pic. Is that blade one of your two outside blades? Mine are typical 40t or so blades.
SawStop or not, I would add a sacrificial fence to your miter bar and cut extras to be used with the dado set. You would not only have eliminated this problem but it will also provide you with a zero clearance backing for cleaner cuts. Not that your cuts on this bench don’t look pristine as it is!
@Coop yes, those are the outside blades. They each have 12 teeth. The only issue with what you prescribed is the dado cartridge on a Sawstop will only work with an 8"stack. It won't accommodate a 10" blade, which is what i think you're using?
I was preparing to cut the tenons on top of the legs when this happened. I do have a 2nd miter gauge with a wooden fence on it but used this miter gauge today because the longer fence for the longer legs. Still though, you're absolutely right - the zero clearance sacrificial is a winner. Thanks!
  • 3 weeks later...
The new bench is coming along nicely.   The old bench it's sitting on doesn't look too shabby either.  How do you have your dado blade set up?  In the picture it looks like a single blade with two chippers?
Thanks @Mark J. I'm not using the dado blade to as the cut quality was terrible so I'm using a box joint blade. Which is similar to the 2 outer blade s in a dado stack with no chippers
Learned a lesson about trusting your intuition yesterday. I wasn't in the usual mindset that i am in when I'm in the shop. I had an argument with my wife and a few other things were diverting my attention and i remember thinking that i should just shut it down for the day.
But I'm very limited on shop time and had been looking fwd to this day all week so i decided to keep at it. And sure enough....
Bam. Huge mistake.
I didn't double check my layout against the plan and laid out these dog holes from the BOTTOM of the leg and not from the top. So they're now way out of position.
 I can plug the dog holes with dowels, or i can just live with them out of place.
Crap.
Should've listened to my intuition.
  • Sad 4
On 7/21/2024 at 11:34 AM, Von said:
Sorry. It's frustrating how easy I find such mistakes are to make. Unsolicited $.02: I find in the long run I feel better when I challenge myself to do the best fix possible.
Thanks @Von. That's a great philosophy/strategy to have.
You've got me thinking.
My first thought was to plug the holes with dowel stock, but that end grain is going to stick out like a sore thumb.
But.... If i filled with dowel stock and then covered with a veneer piece.....
Hmmmm. I'm have to think this through. I'm not rebuilding the leg.
Thanks!
On 7/21/2024 at 3:43 PM, Von said:
Plug cutter? If you have some scrap that is close, plugs from it will blend well.
Thanks for the suggestion. I think you just nailed it. I have plenty of scrap to match this. Ordering one today!
On 8/5/2024 at 7:59 PM, wtnhighlander said:
Vise looks great. I am still amazed at the holding power a leg vise develops. That one should serve you quite well.
Thank you, i think so too. Benchcrafted did not mess around making this thing. It's built like a US tank.
On 8/6/2024 at 8:59 PM, Coop said:
 I see the split as an ideal depository for these items. I know, I should clean as I go.
That's the idea for the gap stop. It will have slots to hold a few chisels,a small back saw, maybe a marking knife and pencil.
  • Who's Online   3 Members, 0 Anonymous, 31 Guests (See full list)
    32k
    437.5k
    26,007
    FurniCore
    FurniCore
