The plunge stop mechanism came off my router while routing a mortise. Lucky the only damage was one small part of one mortise slightly deeper than what i was aiming for.
Need to double check this in the future before hitting that power switch...
  • Sad 5
I think the reason the pieces are threaded is to provide for "fine" adjustment of the depth.  The O ring must be there to provide friction when turning the knob.  Is the O ring oily?  Correctly positioned?
  • Thanks 1
You're on the money on both. Yes the o ring is correctly positioned. I added a little petroleum jelly to it.
I think vibration must be loosening it. I've had that router for 10 years but it's seeing a lot of use in this bench build. I'll try some lock tight today. I thought about thread tape but the threads are a little too fine for that.
My thinking is the O ring needs to create friction to hold the knob in position when the router is running.  So I wouldn't want to lubricate it.
Maybe the O is worn?
+1 - I'd put on Locktite and compress the O-ring when tightening.
I don't see how the stop can stay in contact with the O-ring if you lower it, so I don't think it's meant to be adjustable.
  • Thanks 1
On 8/11/2024 at 3:38 PM, pkinneb said:
Great looking bench! I suspect you will wonder how you got by without it once you're using it on a regular basis, I know I did.
I sure hope so! My former bench left a lot to be desired. :)
Looking good.  Those peek-a-boo holes will fill fine.  I would get the vice mounted before I filled.  BLO and wax has worked as a bench finish for me for 20 years.  Refreshes easily and endures marks, scars, and tattoos.
  • Thanks 1
  • 3 weeks later...
  • Who's Online   1 Member, 0 Anonymous, 37 Guests (See full list)
    32k
    437.5k
    26,007
    FurniCore
    FurniCore
