bradleyheathhays Posted June 19, 2024 Report Posted June 19, 2024 I've got this unusual project going on where I'm trying to produce what I'll call veneer wafers. I'm getting raw veneer from mbveneer.com and the goal is to back it with something very thin for support and to have it come out of the clamps perfectly flat, and as thin as possible. Instead of using the pricey stuff I'm first practicing with maple veneer from Woodcraft and using backer from Flagg that I've been told is phenolic, if anyone is familiar with that company; Wilsonart just bought them. So last night I mate up some .025" backer (pictured below, about 1/3 the thickness of the quarter) with some .020" maple veneer using Unibond800 modified urea resin glue in my newly arrived (!) vacuum bag press. The glue was spread with a 1/16th notched glue spreader, so not too thick but it definitely could've been thinner. After pressing overnight it comes out this morning and immediately curls, and gets more curled with time. The obvious first change in this process to see if I can get the veneer flattened would be to veneer both sides of the backer, which I'll be doing tonight. I got 4" glue roller along with the vacuum bag press so I'll try that out tonight instead of the glue spreader and see what happens. I'd say the glue will go on quite a bit thinner using the roller. So my question is...what other methods and materials should I look into to produce this ever-elusive veneer wafer I'm after? I don't have any experience using rubber cement but if a form of that could be evenly applied with maybe a spray gun or something I think that might be a process to explore. I'm all ears. Quote
Beechwood Chip Posted June 19, 2024 Report Posted June 19, 2024 3M sells spray adhesive in aerosol cans. They have a few different types of adhesives with different properties. Dunno if that would help, but since you mentioned a spray gun I thought I'd mention it. 1 Quote
Popular Post wtnhighlander Posted June 20, 2024 Popular Post Report Posted June 20, 2024 You might also sandwich the veneer & backer between mdf plattens while in thevac bag. You plan to veneer both sides will probably have a significant impact, though. 3 Quote
bradleyheathhays Posted June 20, 2024 Author Report Posted June 20, 2024 Yes, thanks Beechwood Chip, I hadn't thought about those can adhesives. I'll get some and see how it works out. Quote
Coop Posted June 20, 2024 Report Posted June 20, 2024 On 6/19/2024 at 7:15 PM, wtnhighlander said: You might also sandwich the veneer & backer between mdf plattens while in thevac bag. You plan to veneer both sides will probably have a significant impact, though. +1 1 Quote
Popular Post pkinneb Posted June 20, 2024 Popular Post Report Posted June 20, 2024 In my experience I have found you need to veneer both sides of the core at the same time using the same thickness of material on both sides, the core thickness is less important but you want your core to be stable. In my urns I use 1/8" core (just cheap fiber board) and shop sawn veneers about 1/16" thick. While in the bag I place the sandwich down and then put a 1/4" clear taped platen, then the plastic mesh that allows air to suck down on top as shown below. I also leave them in the bag for several hours under pressure. 3 Quote
Ronn W Posted June 20, 2024 Report Posted June 20, 2024 Pkinneb has it right. I would add that for something this thin I would use the same species of veneer with the grain running in the same direction front and back. 1 Quote
curlyoak Posted June 20, 2024 Report Posted June 20, 2024 I know a craftsman that does exotic work with veneers on yachts and planes. The only way he laminates is with titebond 3 and a vacuum bag. 1 Quote
Chet Posted June 20, 2024 Report Posted June 20, 2024 @pkinneb has you on the right track. I think you will find it has not so much to do with the adhesive as keeping an uneven number of layers, the same as in plywood. 1 Quote
