First crack at a cabinet
wouldwurker
Having never built a cabinet, I figured the best way to learn would be to 'build a cabinet'.
Been working on this on and off for the past week or so. Big thanks to Steve for steering me away from potential pitfalls.
Just wanted to get the photos up when I get a chance I'll add commentary.
Door complete.
Some work to be done on the case and shelves yet.
Vinn, With a biscuit jointer, you would have a tad of lateral movement for slight adjustments on your miters. As I'm not a Domino owner at this moment, do you find this to be a problem with dominos, obviously not from your photos on this project, but it looks like there is no room for error?
Ken,
For that you can adjust the mortise width to slide it into position. I did this for my face frames and it worked flawlessly.
Like Tom said, you can...but I didn't. Really because I didn't have much room in there for the wider mortises.
Lots of test cuts on scrap, so when the time came everything was lock and load.
  • 3 weeks later...
For all intensive purposes, I'll call this one done.  Maybe I'll edge band the shelves if I happen to make the right sized scraps one day.
Sprayed on 3 light coats of GF high perf.  Might add a top coat if I happen to be spraying something else.
Thanks to wdwrker for inviting me to his shop and helping out with the hinges.  There was certainly a lot more to them than I ever could have thought.
My door twisted despite the F&P and my face frame was a not too quite square, but I'm glad they were out of whack, so I know what to do different next time.
Didn't want to add a knob or a pull, so we had the bottom of the door proud by design.  Plus if the cabinet ever winds up close to the floor/toekick, I can open it with my foot (thanks for that one too, Steve).
Edit - Realized I didn't add any detail in the OP.
Cheap ply and leftover poplar from the WW toybox project.  Used sanded dominos for the shelve pins.
post-15261-0-20769500-1424709512_thumb.j
post-15261-0-31043400-1424709513_thumb.j
post-15261-0-42414600-1424709514_thumb.j
