William Russick Posted July 16, 2013 Report Posted July 16, 2013 So I'm picking up my first table saw this week. And I'm wondering, how do I choose my blade? I see so many different kinds of blades and some getting VERY expensive. I imagine horsepower of your tablesaw has something to do with choosing your blade. I think mine is somewhere around the 2/2.5 horsepower range. I'm going to be cutting general hardwoods and possibly plywood as well. Any information is appreciated, folks. Thank you all very much. Quote
Byrdie Posted July 16, 2013 Report Posted July 16, 2013 You'll find my different opinions as to which brand is best (I currently use Freud) and I'm not going to get into that debate. I will, however, recommend you get at least two types of blades - one for ripping and one for crosscutting. There's lots of people how like to get a "combination" blade with a middle of the road tooth count. They think it means they don't have to change blades as often. I used to be in that camp. Then I invested in a better table saw - a big investment for me. I need to make my investment last and I've heard good arguments for using a rip blade with a lower tooth count in that it produces less stress for the motor. Type of blade, carbide vs. good hardened steel, again is up to you. You will know the advantages of each and how it fits your work flow. Pretty much any blade you find will work for your saw. Quote
EdgewaterWW Posted July 16, 2013 Report Posted July 16, 2013 Like Byrdie said You will get a "different opinion" from every woodworker. Same as if You asked what running shoe or hammer should I buy. I use most a "combination" blade, Irwin Marples 10'' Saw Blade, 40T ATB. I started with that blade and the type of cuts it didn't work well on I got a blade for that type of cut. Thin kerf blade like above are good for low power table saws (like my 2HP). I now have 4-5 blades that I use all the time. Basic rule of thumb and I'm sure guys may have a "different opinion", 24T rip, 40T/50T combination, 60T/80T crosscut. This chart from Freud will help, http://www.freudtools.com/images/SB-Sel-3000x2164.jpg Freud and Forrest are the top brands, but with top brands You pay top dollar. When I made the jump from a $10-20 blade to a $40-50, I could feel the change making the cut and feel/see difference on the cut. Good luck William picking 1 (or more) out of 100's Quote
knotscott Posted July 16, 2013 Report Posted July 16, 2013 1. The ABC's of Picking Saw Blades 2. Bargain Saw Blades Quote
wtnhighlander Posted July 16, 2013 Report Posted July 16, 2013 Being a weekend woodworker on a budget, I find the Irwin Marples 50 tooth combo blade from Lowes works quite well. I have an older contractor type saw, rated at 1.5 horses. The blade gives me a smoothly polished cut in hard and soft woods. Rips and crosscuts nicely. Lists for around $45. Quote
wdwerker Posted July 16, 2013 Report Posted July 16, 2013 Best piece of advice I can add is keep your blade clean! Resin builds up in the teeth and body of the blade which increases friction. Friction leads to heat, which dulls your blade. Regular cleaning will extend the time between sharpenings. I pay attention to the face, top and both sides of every tooth. There are several brands of blade cleaner, just follow the directions. I use a stiff plastic brush and a laminate sample chip to scrape the stubborn stuff on the face of the teeth. Rinse well and dry carefully. Quote
dwacker Posted July 16, 2013 Report Posted July 16, 2013 To put it in perspective. A average to small kitchen worth of materal is about 10,000 inches of cutting a mix of hardwoods and plywood. A Forrest WW2 will start to decline enough to start tearing out maple ply at about 20,000 inches. A Freud Diablo same tooth count will start tearing out the maple ply at around 7000 inches. 1 Quote
Beechwood Chip Posted July 16, 2013 Report Posted July 16, 2013 Also, the Forrest WWII can be re-sharpened more times than a Freud Diablo. Freud makes more expensive blades that an be re-sharpened more often, but Diablo is their low cost line. Quote
Darren66 Posted July 16, 2013 Report Posted July 16, 2013 I'm curious, I recently replaced the blade on my Makita MLT100 (small contractor/ bench top style) with a Freud LP30M combination 40 tooth. It seems to cut quite well, leaves a few saw marks but nothing that won't plane out. Is it worth putting a better blade in a relatively cheap saw? The saw marks don't overly concern me as I can't think of an occasion when I would not finish with a plane or sandpaper or both... Quote
Tpt life Posted July 16, 2013 Report Posted July 16, 2013 If I were ripping all day without crosscutting, I would move to a dedicated rip to do my best at preserving the life of a limited HP saw. I am not sure I am qualified to answer on quality but rather just purpose. Quote
dwacker Posted July 16, 2013 Report Posted July 16, 2013 I'm curious, I recently replaced the blade on my Makita MLT100 (small contractor/ bench top style) with a Freud LP30M combination 40 tooth. It seems to cut quite well, leaves a few saw marks but nothing that won't plane out. Is it worth putting a better blade in a relatively cheap saw? The saw marks don't overly concern me as I can't think of an occasion when I would not finish with a plane or sandpaper or both... Check your fence alignment before spending money on a more expensive blade. Most of the time its rear of the blade clearance issues. Quote
knotscott Posted July 16, 2013 Report Posted July 16, 2013 I'm curious, I recently replaced the blade on my Makita MLT100 (small contractor/ bench top style) with a Freud LP30M combination 40 tooth. It seems to cut quite well, leaves a few saw marks but nothing that won't plane out. Is it worth putting a better blade in a relatively cheap saw? The saw marks don't overly concern me as I can't think of an occasion when I would not finish with a plane or sandpaper or both... I'm not familiar Freud's line in the UK, but their 40T blades here are capable of glue ready edges directly off a well tuned saw....even from their lowest cost Diablo line. (There's not a blade I know of that will leave a finish ready edge). I'd double check the blade/fence alignment on yours. I'd also make sure the blade is clean. It also helps if the wood is straight and flat. If you're still not getting glue ready edges, it could be time for a new blade, or it's simply caused by the runout of the saw. 1 Quote
woodieboy Posted July 16, 2013 Report Posted July 16, 2013 I believe that Freud blades are always on the top list. Just one tip, check the alignment on your fence, it is an important for your safety. Quote
Darren66 Posted July 17, 2013 Report Posted July 17, 2013 Everyone, thanks I'll check the fence at the weekend before I next use it. Quote
