I've noticed that I've been getting a bit of an issue with my table saw (not that I get to use it much as it's so cold out there). Edges of things I'm cutting aren't coming out quite straight. There appears to be a slight curve to the edges I'm cutting - perhaps not even 1/64" over a foot of material, but it's enough that when gluing up there's a small gap between the boards in the middle.
The fence needs a bit of an adjustment as the front and back aren't always perfectly parallel to the blade when I lock it down so I'm now checking the gap every time I change the fence. But I'm still getting the problem.
Is it my table saw setup or my technique?
Do you have a Biesemeyer style fence with the UHMW plastic sides bolted to a steel tube?  If you do, that could be the problem.  Mine is Grizzly garbage, and the UHMW is slightly bowed...the material follows that bow and telegraphs to the cut.  So I always use an auxiliary fence of jointed 8/4...until I get my new superdupercoolfence.
Everything I cut - plywood, jointed and faced hardwood
It's the extruded aluminium fence that comes with the table. I don't really know how good that is, but it seems straight. I've not held a straight edge to it recently. That might be a place to start
I have the same saw, and I am going to take a look at the manual to see if I can find a solution to the issue. If you have them time, you may want to head over to ridgidforum.com and repost the question. There a lot of guys in there that have every nut and bolt position memorized for their tools.
This may seem obvious, but almost every issue I've has with my TS has been the result of build up dirt and dust. Give everything a good vacuum, and then blow it all out with compressed air or a shop vac on reverse - including the underside of the fence.
I'll look in the manual and repost later.
I had to replace the arbor and arbor bearings on my TS3650.  Take the belt off and try wiggling the arbor pulley.  If you have any movement you need new bearings.  What happened with mine was the arbor actually started to spin inside the bearing and wore itself out so not only did I have to replace the bearings I had to replace the arbor as well.
Did it make much noise when that started? There's no grinding noise from the bearings, it sounds pretty smooth. That said, this is a second hand saw and may not have been put together right in the first place.
Also, I've not noticed any play in the blade when I've been changing them.
It's hard to say because mine also has a bad bearing in the motor that likes to make a squealing noise that I still haven't dealt with.  The arbor bearings were actually fine on mine.  The only explanation I've been able to come up with is that the arbor was machined too small from the factory so it able to start spinning inside the bearing.  The arbor isn't hardened so there is no contest between the bearing and the arbor, the bearing is going to win.  In any event, it only takes a minute to check but you have to take the belt off to be able to see it.  It seemed totally fine when the belt was on.  Took it off and I was shocked at how much I could get the blade to wobble around.
How'd the fence look against the straight edge?
I've not yet had a chance to check it, but I don't entirely trust the straight edge I have, so I'm going to need some paper I can draw on. I'll draw a line along it's length, flip it over and draw again and compare the two lines.
I'll check that out when I go up to the barn workshop to get the fence.
That sounds like a good plan!
You could also lay it flat on its side on a jointer fence, if you have one. Looking at the manual now for adjustments. Do you have a copy?
Did you get this repaired under the LLSA?
So it's not the fence. As I mentioned above, I took the fence apart and then used it to draw lines along a piece of paper, flipped it around and all four lines lined up perfectly. (Incidentally I did the same test to reassure myself of the straightness of my levels).
It was too dark to see in my barn, so I've not looked at the arbor but I'll have a look at that next.
What else could it be? Is there something in my technique I could be doing wrong?
The only thing that I could think of that would cause that is if the side the rides along the fence isn't straight. The curve will somewhat telegraph to the cut side.
That, or your allowing the wood to drift away from the fence.
I'll stick with the fence theory and that it is not well aligned to the blade.  I have a similar saw and fence and it takes real careful adjustment and maintenance to keep the cut square.  A better beisemeyer style fence is definitely in my future.
I've had issues with the alignment of the fence recently where it was pushing the work piece into the back of the blade. I might have mis-adjusted it in the wrong direction. At least it's not that my fence is bend or worn!
I'm still going to check out the bearings on the arbor, though I'm not convinced as I'm sure I'd hear vibrations and noise from the arbor.
The saw needs a damn good clean and a major tune up, but I can't do that until spring arrives. -20c makes it hard to do fine work without gloves on. At the moment, I'm going out there to make a few cuts I don't fancy using my bandsaw for, and my winter shop doesn't realistically have the space for a 4x8 sheet of ply.
Which curve is on the off cut, concave or convex?
Is the curve even or just a bad spot? If you bind a blade slightly, fast motion will flex the blade slightly. If you pause to change grip or grab a push stick, the blade can wear into your work and create a bad "spot."
  • Who's Online   2 Members, 0 Anonymous, 57 Guests (See full list)
