So I'm brand new to woodworking to start off, my "shop" which is just a little 12x12 shed in my back yard is not even done yet and the only tool I have is a circular saw. Fortunately my wife has given me the opportunity to get a new tool or two so I can venture onto bigger projects.
So I've chosen a table saw, my question. Is should I get the $550 ridgid one from home depot? Or for my first saw should I grab a cheaper Ryobi or Dewalt one and maybe pick up a planer with it? The only reason I have been looking at the ridgid is because the reviews are outstanding.
I plan on making furniture just in case that changes things.
Thanks for the advice and sorry ahead of time for being a little long winded.
This topic has been covered a few times here so, some reading might give you the insight you need.
Since you're brand new to woodworking and not sure if you're going to stick with it, a less expensive saw might not be a bad idea.  If you know for sure that this hobby is for you, then buy the best saw you can afford.
Get the best table saw you can afford.  Personally, I would stay away from the cheap ones....You will end up paying more in the long run buying another saw.
Go with a good full size saw with a belt drive induction motor...preferably with a good fence, but fence upgrades are feasible on standard full size saws.  The cheapo portables are generally more expensive in the long run, because eventually you'll end up buying the saw you should get now.
It's kind of a dilemma.  If you can afford a better saw now, you'd rather not have to buy one twice, but if you're not sure about sticking with the craft a less expensive one might be the way to go.  Early on, most of your work is going to be done with dimensional lumber so you could probably hold off on the planer.
I've see a lot of nice work done on one of those plastic body $100 jobsite saws.  Did it myself for my first table saw.  On the other hand, the second $100 TS I got had such terrible run out that I couldn't get a confident cut with it.  I like WTNHiglander's suggestion.  You'll need something mobile in that small a space and the Ryobi contractor saw gives you something decently made if carefully assembled and might be resaleable if you move up or on.
If I only had a 12x12 shop, I might consider forgoing the table saw altogether and just get a nice bandsaw to start with.  Add the table saw at a later date if you end up with more space one day...even a small one is gonna eat up a huge footprint in your tiny shop.
   You got that right... I'm in a 9 x 12 shop, and 1/3 is table saw.
My saw takes up 62" x 40 just in area. Personally I would buy the new Delta over the Ridgid which has had alignment problems for a couple generations. But really I would recommend spending $1000 plus and buying a saw that will keep you happy for the next 15 - 20 years.
- sent via Tapatalk
Lots of guys seem to be making nice stuff on those Rigid/Delta big store version saws (Steve Ramsey (woodworking for mere mortals) and Izzy Swan come to mind). I picked up a $100 plastic ryobi. thought it would be fine to use.. it cut wood, but safely and comfortably are not words that came to mind. I used it for two projects, let it sit for 6 months, then sold it. Just didn't feel too safe with it. I eventually bought a used contractor saw for $400. Cast iron with a real fence.. what a difference! I don't agree you need to spend big $$ to get going, but something that you won't be worried about tipping over, and give you a stable fence to hold material against are key imho. best of luck.
Looking at some of those posts about a bandsaw... I think that's a pretty good option to consider given your space. You can do all kinds of things with a decent bandsaw.
I've noticed that most you-tubers using the lightweight jobsite saws end up building them into some sort of table / fixture to give them stability and working space. Having owned one myself, I work certainly recomment holding out for something with a cast iron table, a belt drive, and a decent fence. I would rather go pure handsaw than to use one of those benchtop saws again.
  • 1 month later...
Thank you guys for your input, here is what I went through since I posted my question. First of all I didn't even get a table saw which was a HUGE mistake. I went ahead and finished the shop which took most of my funds, so I went ahead and just got a Ryobi 9" bandsaw. After playing with that for like 4 hours I packed it back up and took it back.
I then went to my local woodcraft store and picked up the 10" rikon bandsaw. Unfortunately I am dissapointed again, I decided to keep this one just because my wife wants me to make her some little seasonal crafts with it, but it was a waste of money for me. Now I'm stuck not building anything until I can get my table. Now I'm just wondering if the contractor saw from grizzly is a good one? That's the one I'm leaning towards now.
You're disappointed because you're buying tiny tools.  14" is the minimum for bandsaws.
That is exactly what I have learned in the past month. Lessons don't come cheap I guess haha.
I work in a small basement shop so I have a Grizzly contractor style on a mobile base. Also In a small shop you can cut and keep a peace of MDF or plywood that you can put on top of the saw and use it as a table, if needed.
The one question I think about when someone who is just getting started in wood working and asking for advice in what tools to buy is this. What type of wood working project are you wanting to do? Think about what you really want to make and then think about what tools are needed to build it. It's just that I have bought tools thinking I had to have it but then found I could do what I wanted with something I already had.
But after all of that a table saw in a pretty useful tool. You may want to consider if the unit your looking at will take a dado blade. Some will not and you may want that ability sometime. And my last two cents worth is don't buy one of the cheep plastic case saw. My first saw was one of those and well you get what you pay for. Now a days I would rather buy a track saw over a cheep table saw.
Ok I'm done, sorry for rambling.
I would say, do your research, read a lot about different saws, take a look around craigslist for a table saw see what's available, sometimes you luck out and get a damn good saw for cheap. I bought my first table saw which was a Jet JWTS-10JF 1.5 HP cast top with cast wings and 32" Xacta fence, the top just had some surface rust on it that I got off with some elbow grease and maroon scotch bright pads for $320 bucks. The footprint is fairly sizable, but you could probably make do your entire woodworking career with a saw like that in a 12x12 shed.
I got power to my new to me Unisaw tonight. I needed to make a 1-1/8" x 3/4" deep cut for the band saw mobile base that I am finish. The difference between it and my DeWalt 746X hybrid saw was eye opening different. I always worried using my DeWalt saw to make rip cuts because the back of the fence would flex away fromt the blade bringing the front of the fence into the blade when you got passed the center of the fence. I had learned over the years to ease up my pressure when I got to passed the center of the fence. On the Unisaw it was rock solid the entire length of the fence. The difference in power was such that I was able to make the cut with so little pressure that it was like just sliding the wood across the table with no back pressure at all.
My advice after finally using a actually cabinet saw is to save up for the best saw you can get. You can get an amazing saw from many outlets for just above $1K. Become a Craigslist hawk and get a used saw if you have to but don't waste your time or money if you are serious about about woodworking.
  • Who's Online   0 Members, 0 Anonymous, 52 Guests (See full list)
    26,008
    Bob44
    Bob44
