I'm trying to make a cross cut sled for my TS ....
How is this even possible?
I can square up my board to the right side of the kerf line, but to the left its out of whack.
https://www.dropbox.com/s/hyql347e4vgpce3/left%20side%20kerf.jpg?dl=0
https://www.dropbox.com/s/y5q1hcny24yykmy/right%20side%20kerf.jpg?dl=0
I don't understand how something can be in square on one side and out so much on the other.
Can someone please explain what is going on?
Have you verified that your square is actually square? Those squares are usually good enough for construction but usually suck for woodworking.
One side of your fence is square to the kerf, the other side of your fence is not. Did you joint the face of the sled fence before installing it?
Yup, lots of potential issues here.  I'd say either the square isn't square, the fence face isn't flat, or the sled runners have too much play so there was side to side movement during the initial cut, screwing up the kerf (i.e., the kerf isn't uniform).
Can you post more details about the sled?  How you built it, more/bigger pics (also embed the pics in the post so we can see them without clicking the dropbox links).
Fence must not be flat.  What does it look like if you hold your square up to it?
What I'm trying to do is put a new back fence on it. The original 2x4 I used was a little off.
I want to use a good piece of hard maple.
I can't seem to bring my photos directly in.  I made them smaller of 512k each and it still said the max is 1.95MB - so I don't know why it won't let me. That is why I linked them over from my dropbox.
The runners are from Incra and they have no slop.
OK, came back in from my shop and the wood fence curves. It's very subtle but it's there.
I want to replace it with something metal on each side of the kerf line. Any recommendations?
Yeah, dont.
Joint the face. Be done
From looking at the photos, I think it's a combination of a crooked fence & a square that isn't square. You can easily spend hundreds of dollars on a good square, but I got one from Lee Valley http://www.leevalley.com/US/wood/page.aspx?p=32587&cat=1,42936,42944 that, while quite a bit more than a cheap framing square, is still pretty reasonably priced & very accurate. That will give you a good starting point. Then use the 5 cut method to get it as crazy close as you like.
A more iffy but possible (and possibly cheaper) solution is Ebay. I bought a Starrett off of there. But you just never know what you may get.
Mitre gauge or square?
Either one,  irrelivant.  If you are building a table saw sled,  I'm going to assume (*) you have the ability to mill your lumber be it a jointer or neanderthal methods.
First,  ensure your registration surface is flat and 90* to the sled by milling that back fence.
Next, square it as good as you can to start, then begin refining it with the 5 cut method. You can start a half inch out and you can still get there.
(*) if this assumption is incorrect,  you should consider priorities
