Beta folks,
Looking to buy a dedicated full kerf crosscut blade for my table saw. I have a ww2 combo and a ww2 24tooth rip blade.  Looking online a lot of companies either don't offer a dedicated crosscut for table saw or only sell thin kerf models. Forrest has the duraline sp? line but it costs almost 200$. I was looking for something cheaper if it exists but wanted comparable quality.  Anyone have any suggestions?
On my table saw I have been using the Freud 80 tooth ATB ultimate cutoff which is a full kerf blade that I have been real happy with.  On my miter saw I have had a (12inch) 80 tooth Freud Diablo that also cam from the same fine emporium that Ace got his.  The cheaper Diablo does seem to dull quicker then the other Freuds that I own.
I have 2 freud 80 tooth Ultimate Cutoff blades one full kerf one thin kerf. I really like their cut quality though i use them in my sliding miter. In my table saw i have a Freud Combination and it makes pretty clean crosscuts but not nearly as nice as the ultimate cutoff.
I don't notice a cut quality difference between full kerf and think kerf.
I typically use a 40t woodworker for cross cuts.  If I need an especially clean cross cut on my table saw I use one of these from carbide processors.  It is designed for sheet goods but does a nice job on solid wood cross cuts.
http://www.carbideprocessors.com/melamine-saw-blade-10in-x-80t-hatb-popular-tools-lm1080/
I own a bunch of their blades and they seem very close to forrest in quality and in many cases the cost is much less.  I am sure they have a blade that is a similar configuration as the duraline you are looking at.
Thank you for the heads up about carbide processors.  I had not heard of them before.  Unfortunately their crosscut blade costs 157$ which is not much of a savings off of the Forrest blade.
I am trying to avoid blades used for miter saws or radial arm saws. That means no negative hook blades which eliminates quite a few options. I have found a cmt blade which fits the bill but no reviews on it and frankly the reviews I do find on cmt suggest they make good budget blades but don't compare to the likes of forrest, infinity, or ridge carbide.
The ultimate cutoff blades that ace and a few others mentioned are positive hook angle blades. Having used negative hook angle blades i agree with you an avoiding them. Mine has a 10 degree positive hook.
Have you tried your ww2 for cross cuts?  In my experience it works great.  I am surprised you need something "better".  If you are have problems with the ww2 then maybe it needs to be sharpened.
I looked at the ultimate cut off blade but unfortunately it is a thin kerf according to the description at .116"
The ww2 combo is ok, but having used dedicated crosscut blades before I definitely notice a difference in cut quality.  We are not talking a huge difference but I recently upgraded my saw and now I want to raise my personal level a bit.
My ultimate cutoff is a is 1/8 it is probably .116.  you are most likely loosing some thing in the metric conversion, I believe they are made in Italy or something like that.  I think the thin kerf are labeled 3/32 or .091 or .093 something like that.
This is the one I have-
http://www.amazon.com/Freud-LU85R010-10-Inch-Ultimate-PermaShield/dp/B0000223KU/ref=sr_1_1/179-1815819-3936160?ie=UTF8&qid=1457988184&sr=8-1&keywords=freud+ultimate+cutoff
This is the same blade but thin kerf
http://www.amazon.com/Freud-LU74R010-10-Inch-80-Tooth-PermaShield/dp/B0002H49ZS/ref=sr_1_2/179-1815819-3936160?ie=UTF8&qid=1457988184&sr=8-2&keywords=freud+ultimate+cutoff
IME, CMT Industrial blades are pretty comparable to Freud's Industrial line.  Their ITK and ITK Plus lines aren't quite to that level.
What are you trying to accomplish by avoiding anything with a negative hook?
For cleanest cut, I'd be looking at the Infinity 010-080, Freud LU80, Forrest Duraline, CMT 210.080.10.  For a really clean cut and a little better edge life, the Freud LU85 is a solid choice too.
I don't think its a metric thing. .125 is the same as 1/8. Anything smaller then that and its thin kerf. The top link you have in the description says .116. The thin kerf blade is even thinner. Either the description is wrong or the blade is not a full 1/8 kerf.
Basically I have 2 things against thin kerfs. One the scale on my saw is set to the full kerf thickness. So if I switch blades I need to either, reset my scale, not use my scale, or have cuts that are off by whatever the blade thickness difference is. I prefer to avoid that whole issue and just use blades all the same thickness The second issue I have is stability. Thicker kerf blades cut cleaner but require more power out of a motor. My new saw has a 3hp motor so I am not worried about the increase in power needed.
These are the blades I use. I have both but use TK for almost everything now. I also use their glue line rip blades and find them to be very good quality for the price. I also have a couple of WWII blades but I use those primarily for plywood these days.
Thank you! I was considering the at the Infinity 010-080 and the Freud LU80. The CMT  210.080.10 is the CMT blade I found and mentioned earlier. Both the infinity and freud call themselves plywood or laminate blades, while the CMT calls itself a fine cutoff blade. The Infinity and the CMT are very similar/the same blade design in that they have a 5 degree hook and a 40 degree (some cmt descriptions say 38 degree) bevel on the atb grind. The Freud on the other hand has a 2 degree hook.
Any thoughts on which of the three might be the best?
As to why I am avoiding a negative hook. I have read online (not sure how true it is) that a negative hook while a good thing for a miter or radial arm saw is actually dangerous on a table saw more likely to result in kickback. I don't know about that but I have experienced a difference with using the wrong blade on my old unisaw which was 1 hp. The negative hook definitely was more difficult to push material through then positive hook blades.
  • Who's Online   2 Members, 0 Anonymous, 64 Guests (See full list)
    26,008
    Bob44
    Bob44
