Coop Posted September 20, 2016 Report Posted September 20, 2016 My ts is wired thru an attached paddle STOP switch. I plug it into a drop down reel style cord with a triple plug. I use the same cord for my router table. Several months ago, the ts would not start and with a jiggle/twist at the plug, it started. I looked and the ts plug had black burn marks on the end, but the router did not. So I bought another cord with a male end, and wired it from the paddle switch. Tonight, in order to unplug my ts to change blades, I had to pry, with a screwdriver (with the reel cord unplugged), the plug out of the extension cord. Same black burn marks but not so on the router cord plug. Anyone have any ideas? Quote
Immortan D Posted September 20, 2016 Report Posted September 20, 2016 Looks like your TS is demanding more power than your extension cord can deliver. 2 Quote
Ryan Grondin Posted September 20, 2016 Report Posted September 20, 2016 What guage wire is the extension cord and how many amps is your ts? Quote
wtnhighlander Posted September 20, 2016 Report Posted September 20, 2016 Does the plastic part of the plug appear burned or melted? That would indicate a high current load. If the metal prongs of the plug have scorching or pitting, especially without melting of the olastic, that might indicate an arcing condition. That could mean a poor connection between the mating parts of the two power cords. Startup current in an induction motor ( like a table saw) is very high, but brief. Universal motors, as are used in routers, also draw a higher startup current, but I'm betting your router table has a variable speed motor, with a 'soft-start' feature that ramos up the speed, and therefore the current, when you power it up. If this is the case, I'd say you need to replace the female plug on your extension. And probably get a fresh male for the TS while you are at it. 1 Quote
Coop Posted September 20, 2016 Author Report Posted September 20, 2016 The cord is 12/3 reel from Rockler, and I don't see the amps but it is a 1 3/4 hp. motor. I have been using this setup for about 4 years with no problem. I don'tknopw how a reel works, with brushes I guess. Maybe the connection in the reel has gone bad? Quote
Brendon_t Posted September 20, 2016 Report Posted September 20, 2016 I had this on my drop down hose reel I'm sure from plugging/ unplugging often. The blades of the male end clearly stretched out or damaged the female end leading to an arching condition. Def replace the cord, try to leave your ts plugged in to one outlet. 2 minutes ago, K Cooper said: The cord is 12/3 reel from Rockler, and I don't see the amps but it is a 1 3/4 hp. motor. I have been using this setup for about 4 years with no problem. I don'tknopw how a reel works, with brushes I guess. Maybe the connection in the reel has gone bad? Most reels are just a spring tensioned cord wrap. No actual electrical components. Just a housing. 1 Quote
Coop Posted September 20, 2016 Author Report Posted September 20, 2016 So replace the reel/cord? Quote
Popular Post wtnhighlander Posted September 20, 2016 Popular Post Report Posted September 20, 2016 You can probably just replace the female end of the cord on the reel. Brendon is right about frequent use making the female side loosen up. No, that is NOT a setup for a punch line.... 3 Quote
Coop Posted September 20, 2016 Author Report Posted September 20, 2016 Thanks guys, appreciate Ya! New female it is! Oh Baby, Oh Baby! Quote
drzaius Posted September 20, 2016 Report Posted September 20, 2016 I agree, it's the female cord end. Things have loosened up enough to allow some arcing and/or heating to occur at the point of contact. 1 Quote
legenddc Posted September 20, 2016 Report Posted September 20, 2016 Might want to add a 1 foot extension cord to the end of the new reel and keep it plugged in. Easier to replace if it goes bad again. Quote
ncfowler Posted September 22, 2016 Report Posted September 22, 2016 most time heat is caused by lose connections, either in the plug and wire connections or by the blades or the connections it's self, I would on both the plug and female end check to see if there is any burnt or discolor wire, if so cut the cord back on both sides to clean wire and replace both plugs, the problem may not be the side that is melted but the opposing side, Also check Ts motor it will have a FLA amp draw, this is what you need to go by when selecting the proper size cord, Length of drop is also needs to be taken into account, also take into account the age of the cord over time the efficiency breaks down due to heat and other processes caused by current, you can check the continuity and resistance with the a multi meter in the ohms setting. lastly the age and ware of the motor may be pulling higher amps than it use to, look for RLA on the motor and use a amp probe to check it check all legs while running with no load, it should be within 10% of listed, if it is too high you may want to check your pulley if belt drive for ware or bearings, also blow out your motor of any sawdust, and check the motor bearings or bushings, too tight or too lose may case high amps, if it is too lose it may be making the armature arch more than normal, both causing excessive heat and amps, I hope this helps. http://donsnotes.com/home_garden/extension-cords.html http://www.homedepot.com/c/factors_to_consider_when_choosing_extension_cords_HT_BG_EL Quote
