I have slowly upgraded the tools in my shop to a point where I am happy. The last upgrade is a better planer. The finances won't allow big purchase right now. I found a used Jet JPM 13 planer/molder which looks to have been well taken care of. About the same cost as a new Dewalt 735. Any advice in which would be a better path? Hobby shop use primarily.
I have a Jet jpm13cs that I use for moldings and as a back up planer.  I would prefer the jet over Dwalt lunch box but that being said the guys here that have the Dwalt seem to love them.  Do you have room for the Jet and do you have anymore info on it?
I love my 735, just be aware it needs a DC system.  Either a regular Dc system that you can attach a 4" hose to, or a catch can that also use a 4" hose, or a bag.   Or you can use it outside.  It will blow chips 30' out the exhaust port on it's own.   It's not like other lunch box planers which seem to keep their mess in the general area of the planer.
But since you are looking at the Jet also, I'd assume you already have the DC hookups necessary.  To me it's a no brainer, if the Jet is good condition, and you have the floor space for it, go with the Jet, since it also does moldings.
I have the Grizzly equivalent that I found on CL for about 400 bucks with a bunch of molding cutters, and an extra set of planer knives.  I keep it as a finishing planer, being careful not to run anything through it that hasn't been run through another planer first.  With the rubber covered feed rollers, the piece comes out perfect enough not to have to do anything else to it.
I've only used it as a molder once, but that was on a run that was not long enough to get an order from a millworks place, but too long to do with molding planes.  It did okay on the molding, but it did need some sanding cleanup.  It wouldn't be worth the setup time for one or two pieces of furniture.
If you have the space, and the Jet is in good condition, I'd suggest the Jet. The 735 is a great machine, I own one. But it is still a mobile planer, no match for a cast-iron floor model.
Plus it screams like a cougar in a bear trap.
Posted (edited)
I can't speak to the Jet unit.  If you have need of a molder, then it does what the dewalt cannot do.
I have the Dewalt 735 and it's absolutely served me well.  Great planer, IMO.
Edited by Jfitz
I have the 735 and I am real pleased with it.  Both machines look to have about the same foot print.  And where as the 735 is considered portable I wouldn't really put it in the lunch box category, its a beast to lift at over 100 pounds so a permanent stand is ideal and it does a much better job then lunch box planers.  If you are going to use the the molding feature then the Jet is the way to go.  If you don't think it is a feature you will use then I would weigh the value of used (Jet) versus new with warrantee (735)
  • Who's Online   4 Members, 0 Anonymous, 54 Guests (See full list)
    26,008
    Bob44
    Bob44
