Immortan D Posted May 4, 2017 Report Posted May 4, 2017 I need a good sharpening guide for my knives, including those short ones in my multi tools. After doing some research, looks like the Apex system could do a fine job: Apex 4 Kit – Apex Model Edge Pro Sharpening System but I'm not sure. The Apex also has an attachment for chisels, hand plane blades, scissors, etc, available separately as an accessory. I was about to order both items but I'd rather ask here first Recommendations? FTR I don't want an electric sharpening system, just a foolproof sharpening guide. Quote
Woodenskye Posted May 4, 2017 Report Posted May 4, 2017 Here is another option, this looks similar in concept. http://tsprof.com/?lang=eng 1 Quote
Immortan D Posted May 4, 2017 Author Report Posted May 4, 2017 3 minutes ago, Woodenskye said: Here is another option, this looks similar in concept. http://tsprof.com/?lang=eng Good option. I saw a Wranglerstar video about that system and looks solid. Quote
gee-dub Posted May 4, 2017 Report Posted May 4, 2017 Wow, that really takes this system to the "nth" degree. I've actually worn out stones and replaced them on my Lansky. I think it was $18 when I bought it. 1 Quote
Al Capwn Posted May 4, 2017 Report Posted May 4, 2017 I have the Spyderco Sharpmaker as well as an Edge Pro Apex knock-off. Both do a pretty good job; quality of the stones of the Spyderco Sharpmaker are higher, the kit is very portable, and it is quick and simple to setup for use. Downsides are that the grits are limited out of the box and you won't be able to reprofile an edge. It also relies on you maintaining a consistent vertical angle while sharpening. The cheap "Edge Pro Apex" clone stones that I have are meh. What I do like about the EPA is that you have a lot more consistent and precise control on setting the degree of a bevel. Pros are that you can really obtain a very keen edge, and even "make" your own stones for it to get whatever edge you want. Downsides are that the setup takes a bit longer, and you must set the jig/holder per knife. You can't really "batch" sharpen knives. If you decide on the EPA, either get the original Apex kit, or if purchasing the knock-off, use the saved cash to buy genuine stones (Shaptons/Chosera I hear are nice too). No experience with the scissor/chisel attachment for it; I would be interested about that as well. 1 Quote
Immortan D Posted May 5, 2017 Author Report Posted May 5, 2017 Thanks Al. I will follow your advice if I go with the Apex. 4 hours ago, gee-dub said: Wow, that really takes this system to the "nth" degree. I've actually worn out stones and replaced them on my Lansky. I think it was $18 when I bought it. Actually I'm also considering a Smiths kit LOL. It's about $40 and apparently it gets the job done, according to the average youtuber. Plus I don't even have to order online, a local hardware store carries them and I can return it if I don't like it. I think I will go get one tomorrow, pick the dullest knife I have and give it a try. Quote
Miles11we Posted May 5, 2017 Report Posted May 5, 2017 Iv actually been looking to get a system like that too but keep telling myself i should just get better at hand sharpening considering i do everything else free hand. Just cant seem to get knives down... or at least consistently. Whatever you choose to pull the trigger on, if you remember, let us know how it goes. Quote
wtnhighlander Posted May 5, 2017 Report Posted May 5, 2017 I find knives much easier to free-hand than chisels or plane irons! Quote
Tpt life Posted May 5, 2017 Report Posted May 5, 2017 I find knives are moving toward insanely hard metallurgies vs easy to hone. Pay attention to that. Sometimes you don't need a jig, you need a different honing media. Quote
Tom Cancelleri Posted May 5, 2017 Report Posted May 5, 2017 https://www.wickededgeusa.com/ This is king dick for knife sharpening. Quote
Immortan D Posted May 5, 2017 Author Report Posted May 5, 2017 I just picked up the Smiths kit. I have this ridiculously big and completely dull 440 stainless steel knife I will use to test the kit. Quote
Immortan D Posted May 5, 2017 Author Report Posted May 5, 2017 The kit worked out fine. It's definitely not comfortable to use but I ended up with a scary sharp knife from end to end of the blade and an absolutely parallel cutting edge. I still have to do some polishing with a leather strap. So it's a keeper! Quote
Immortan D Posted May 6, 2017 Author Report Posted May 6, 2017 After sharpening half a dozen knives, my recommendations for this kit: * Use the 25° setting for pocket knives and hunting knives. I wasn't able to get a sharp edge with the 20° setting. I haven't tried the other two settings though. * Finish up with a ceramic sharpener or stone. I used the Victorinox ceramic pen, I got excellent results with just a few passes. Quote
ghost Posted May 6, 2017 Report Posted May 6, 2017 i have that same "kit". i don't like it. long blades it is - okay,- shorter blades will test your patience such as a pocket knife - <4" blade had it for 7-8 years now, it does make blades sharp, but i don't feel it is very user friendly Quote
Immortan D Posted May 6, 2017 Author Report Posted May 6, 2017 2 hours ago, ghost said: i have that same "kit". i don't like it. long blades it is - okay,- shorter blades will test your patience such as a pocket knife - <4" blade had it for 7-8 years now, it does make blades sharp, but i don't feel it is very user friendly Agreed. Not comfortable to use. Clamping small knives is a PITA. But since I'm not going to use it for kitchen knives, just for my hunting and utility knives, and considering I don't have many of them, the kit is a good bang for the buck. It won't damage my blades like other cheapo solutions would do. And it's compact and fairly easier to setup when compared to the top of the line kits. Quote
