EnduroVar and Titebond III ghosting
I keep having this issue with TB III residue ghosting through when i spray on GF endurovar. Ive had ghosting issues in the past--not unusual to miss a tiny spot here or there prior to finishing--but ive had a problem with EVERY single project using endurovar. Is there a difference between the sensitivity to glue residue between a water borne finish and an oil based finish? In particular, this latest sapele project involved much more thorough surface prep to avoid ghosting. I even wiped the piece down with mineral spirits and did not notice a problem. First coat of endurovar and boom, i have drips and the tiny blips of glue squeeze out along joints. I sanded the first coat thoroughly, applied coat #2, and i am down to a few remaining problem areas. It is so strange that i can stand over the blemish and not see it. I need to walk around the piece and view it from another angle, but from that angle it is clear as day. I need to try and photograph the problem tonight. That and try to sand it out and apply a third coat.
Hard to say without a pic. Perhaps, the wipe with mineral spirits may be doing something. Water based and mineral spirits don't play nice. Wipe the wood with 50/50 mix of water and denatured alcohol. Then be sure it's had ample time to dry.
-Ace-
-Ace-
This is spot on that you should never use MS under waterbornes as even after it evaporates it can still leave a residue. Did you raise the grain and sand lightly before spraying the Endurovar? Even if you did a wet coat sitting on the surface is still going to raise it some.
I know Endurovar's selling point is it ambers the wood like oil varnish does but its downsides are it's expensive and you can't use shellac under it. Since you've been having ongoing problems with TB III and EV, I personally would spray a coat of super blonde shellac and use GF High Performance instead. The shellac will seal and dry fast while also warming the GF HP finish.
I'm also not a fan of TB III as it leaves visible glue lines in certain woods. Unless you need it for water reasons I would use I or II.
Ok, definitely did not know about mineral spirits and waterborne finishes. Im a noob with WB stuff, but it is good to know. The other 3 times i didnt wipe the project down with MS and still had the same glue problem. This particular time the MS had an hour or two to flash off prior to me spraying the enduro var and im confident it didnt disrupt anything. This is 100% glue ghosting through the finish, because the one is a perfect outline of a glue drip running down the face of the board before i laid it down to get it in the clamps.
I buy TBIII by the gallon because i never know when im doing a cutting board or something exposed to water(counter with a sink etc). Ive never had a problem with it until now. It sounds like i may want to reconsider my finishing schedule. I only started experimenting with endurovar a couple months ago. Love how well it sprays(im pretty inexperienced sprayer), and it gets kinda close to the look of an oil finish. Not quite there, but close. So far my only complaint is the problem with glue residue showing through when MS doesnt highlight it. Price is what it is. If the product kicks ass, i dont mind paying $85-100 a gallon.
Well, I think you know what the issue is, the only other thing I could suggest is prior to you sanding, is to spray a very weak black dye over the project. This will show you where you need to give extra attention to sanding to remove any glue residue. Sand all the dye back, you know your good.
Enduro-Var will add color to the wood like an oil. If you don't get the glue residue off, the EV color can't get to the wood, thus showing off.
-Ace-
I had the same problem with my last project.  Used tb3 on waste blocks to clamp a miter closed.  I sanded and card scraped the area, didn't see any glue left, I did use mineral spirits to check the area and it looked fine.  Applied enduro var and could see where the glue had been, could figure out how to fix it because I resanded the damn thing and the problem still existed.
I don't think it has anything to do with the type of glue or finish you're using.  You just need to be more fastidious during glue-up and more thorough during surface prep. :)
I really thought i hammered this top with my sanding regimen. rotex 80, 100, 120 and then my ets at 120, 150, 180, 220. I probably spent 1.5-2 hours sanding the top--most of that with the rotex to avoid this exact situation. I hate to blame the finish, but i feel like it is hypersensitive to TBIII. I havent had this problem with waterlox/minwax/any other wiping varnish. Sure, ive had glue ghosting in corners or something where i clearly didnt sand or anything after a glueup, but this is very unusual.
Ive read 100 different opinions on this topic. Wipe the wet glue up, dont wipe the wet glue up, you will drive it into the wood and cause a mess. Scrape the glue as it gums up. Dont scrape the glue while its still fluid because it shrinks as it dries and cures, which means you could have a slight depression when its fully dry. I scrape my glueups about 2 hours after they are in the clamps. The glue is semi hard and comes off pretty easily with a chisel. Obviously, by this time the glue has already had the chance to creep into the wood. Maybe i should start wiping it up with a wet rag immediately? Im up for whatever works.
Lol nothing fastidious about a 60x110 glue up. Applying glue to 8 edges with dominos and clamps is a made scramble within the glue's open time. I think the real problem here is not having an enormous widebelt. Although, in this situation i dont know if a wide enough wide belt exists, so id still be damned...
For a glue up that large, I would do it in stages, for that exact reason.  Then you aren't sweating the open time and can focus your attention on cleaning up glue.
I don't have experience with endurovar...but can I make a suggestion if you're looking for ease of spray but an oil appearance?  Apply one coat of ARS (or equivalent), then spray GF high performance as a top coat.  I did this with walnut recently and was very happy with the result.  You get the "oil" look but with the ease and quickness of a spray.  And yes it's a *little* bit more work, but not much, and the first coat of oil is so damn easy to apply, and GFHP is dead easy to spray.  Just something to think about for next time.
Appears the wood you're using has some deep grain. So the grain will pull in the glue just like a finish. If you let the glue setup to scrape off later,  the glue dries down in the grain pocket. So sanding, you need to remove a lot of wood to get that glue out.
 I'm not a let the glue setup and scrape off later fanboy. I will use a damp rag and get at it. The water helps to thin the glue and make it easier to sand out.  I will also use masking tape to help with glue squeeze out on sloppy glue ups and in all cases, inside corners.
There is no magic bullet. The devil is in the details. As I mentioned above, if you use a trace coat, (old auto body trick for sanding primer smooth and showing imperfections) it shows everything, swirl marks, dents, glue...........just saying. Glue is a finishers nightmare.
-Ace-
How long did you let the ARS cure before spraying the GF High Performance?
if your going to use an oil to color the wood, specifically ARS. Thin it first or just use Seal-A-Cell. SAC will tone the wood and dry somewhat faster and you don't have all the solids to deal with.
Wait a few days before going over top with HP. Longer is better, don't rush it. It needs to dry.
-Ace-
4 hours ago, Eric. said:
Unfortunately, glue residue shows up under ARS, too. :(
Yeah I was more responding to his desire to get an oil "look" with a WB topcoat.  The glue problem is a different issue entirely.
I left it less than 24 hours (inside at 70*).  Didn't have an issue.  I applied with a foam brush and then wiped it entirely dry with a clean cloth.  Ideally, as others have noted, you'd wait as long as possible, but for this particular case it worked out fine.
Few things to get caught up on. One, thank you for all the info, i need to pick ace's and mike's brains about finishing schedules sometimes. After these latest incidents, applying some type of sealer/base and then topping with sprayed WB makes a lot of sense to me. Especially if the base/sealer coat ambers the wood and i can switch to GF high performance. It is $30+ cheaper a gallon! And yes, from all my searches i read a couple threads on woodweb about professional finishers and their hatred for glue. Next project this weekend im wiping the wood with a wet towel and hopefully avoiding the mess to behind with.
I am spraying the final coat tonight, i hope.  I spot sanded my problem areas with 180 grit, then 220, then the whole piece with 320 and blended the spot-treated areas. So far, so good. I have a few joints that exhibit faint ghosting in spots from really acute angles, but it's so slight im not worried about it. It appears this one will be behind me and no worse for wear. Certainly a smack in the face to change process or products. Then again, it might be worse with sapele. Similar issue with walnut resolved itself pretty quickly the weekend before.
