Work shop design suggestions
I'm wondering if any of you have used an app to help layout your workshop? I just setup a new jointer , planer and router and now I need to kind of get things organized before I setup the dust collection
Depending on the model of your tools, there may already be a 3D scale model of it in the SketchUp warehouse. For my shop I use SketchUp. I find either an accurate model of my tool or modify a close-enough model to match the dimensions of my tool.
Many people use the free Grizzly app on their web site..
The layout apps are great for when you're daydreaming at work and blowing off your responsibilities...but it's just not the same as trial and error in meat space.  Moving machines around sucks, but it's the only way to really organize a shop.  Put them where they seem logical, then start building...shortcomings of your layout will be apparent immediately.  Then rearrange, and repeat.  Your shop will evolve until you have a fluid workflow and/or you run out of space.  I've moved things around dozens of times over the years, but now I'm done.  Many hours of work and pondering have gone into my space, and I always enjoyed it as a kind of sub-hobby.
Spot on advise!  I'd bet my next paycheck that if you found anyone here truly happy with their shop layout and flow that they followed this method.  I know I did.
I started with a design on my current shop and have changed a couple things but not much. For power i made sure to include extra outlets (including 220) for future growth or changes and my DC hasn't really changed other than I have added a couple addl y's over the years. Having said all of that I did work in a single stall shop for many years prior to building my current shop so I pretty much new my flow like Eric and TIODS refer to above.
As far as apps VS. real life, look up my thread about effeciency in the power tool section.  The last few diagrams show my space and a couple changes.  The diagrams are very close to scale, but the real life impact VS the impression given on paper aren't comparable.  The shop seems empty now there is so much free space, but the diagram barely looks like anything changed.
That said, the grizzly free app is a good place to start.
As you look at other shops pick out areas that might work for you. It's not likely you will find something to copy in its entirety.
The 30 x 36 shop was my inspiration. The jpg is a sketchup export of my plan. I borrowed the idea of a central tool cluster and for me it worked out great. I'm able to have one dust collection run with branches and some floor outlets serve those 4 machines. This one idea was a big space saver rather than the traditional around the wall layout.
I'm a hobby shop so it's about space more than production. Everybody else may hate the cluster in the middle of the floor but I wouldn't do it any differently.
Btw I got the tool cluster and the table saw right. The other items shifted around some from the plan. But I planned everything else around those items anyway.overhead perspective jpeg.JPG30x36shop.pdf
Sent from my SM-N920V using Tapatalk
I think this is the way to go.  You don't know who things will work for you until you get in there and work with that set up.
I am currently on version 6.0
Think of workflow. Wood comes in, gets stored. Wood then gets processed/milled (joiner and planer). Wood then gets final dimensioned and ready for joinery (table saw and bench). Project gets assembled (clamps) final sanding (workbench?) and finished. Then, the piece goes out. On top of that, you want to have adequate dust collection throughout.
As others have stated, tools like the Grizzly shop planner are a good starting point, but you really wont know what you need until you get things in there and start building. Most of my stuff is on wheels because I've changed the layout 3 times in a year already.
I used the grizzly layout tool and sketchup. Once my equipment was delivered I didn't actually like what I planned. I ended up moving things around quite a bit.
  • 26,009 Total Members
  • Joseph b Newest Member ·
